Step 6Next Steps
Once your Web Clicker is up and running, you'll probably want to tweak it / play with it! Here are a few ideas to get you started;
Local File Storage
The Propeller Platform USB has a microSD / microSDHC card slot so you can add up to 32GB of local file storage. You could serve MP3's, pictures or whatever else. You could also use the SD card for data logging. To start playing with the SD card, grab the fsrw object.
Multiple IR transmissions with a single command
Take a look at the source code - towards the top, there's a section of 'Elseif', which tell the Web Clicker what to do when a command request is received. You can make the device do anything in response to a command, including sending several IR blasts.
Controlling a motor, switch, light, or anything else
Why not use the Web Clicker to turn on a motor, change a light, play back a wav file or something else? It's the same process as adding multiple IR transmissions - look at the code with the Elseif commands - instead of playcommand(x), change it to your newly created method.
That's it! I had a lot of fun putting the Web Clicker together - let me know if you've got any questions or comments!
One question: Do I have to have the SD card? e.g. when I program the device does it go into volatile storage, requiring it to be reprogrammed every time power is lost, or is there some on-board flash?
Also, I am having the problem where it crashes after recording 5 codes, or sometimes on playback.
One more thing, any advice on how I could rework it so that I can mimic holding a button like Vol+ instead of clicking it a bunch of times to raise the volume a lot?
If there's an Infrared command that switches videos, then certainly. If there's a computer that controls the currently playing video file, the Propeller Platform USB can interface with it over the USB connection - but it's beyond the scope of this instructable.
Hope it helps!
