loading
Step 4: Arduino Code
"Arduino Code:"
This project requires to peices of code. 'Firmware' that is loaded onto the Arduino microcontroller. And 'Software' that is run by the Processing program on the PC.
The chain of command goes like this - Processing -> Ardcuino Board -> Steppr drivers -> stepper motors -> X-Y stages.
Here is a little more detail of the communication that will be happening, based on my understanding of the way things work....
The Processing software will send commands to the Arduino board over the USB cable. T The Arduino board will take the command and set the specifed output pins to high or low logic states (5V or 0V). The stepper drivers are wired to the Arduino board outputs. So when the drivers see the high and low signals, they send power to the approriate coils in the stepper motors, making them go.
The code below sets up the Arduino board to listen for the commands sent from Processing and then take actions.
You can cut and paste the code in the Arduino IDE. Then verify the code by clicking the 'Play" button. If there are no errors you can then upload it to the board by pressing the upload button - which looks like a right arrow.
// Arduino code:
// Read data from the serial and turn ON or OFF a light depending on the value
//and control stepper motor on RepStrap
char val; // Data received from the serial port
int ledPin = 13; // Set the pin to digital I/O 13
#define XstepPin 10
#define XdirPin 7
#define YstepPin 2
#define YdirPin 3
void setup() {
pinMode(ledPin, OUTPUT); // Set pin as OUTPUT
pinMode(XstepPin, OUTPUT);
pinMode(XdirPin, OUTPUT);
pinMode(YstepPin, OUTPUT);
pinMode(YdirPin, OUTPUT);
Serial.begin(9600); // Start serial communication at 9600 bps
void loop() {
if (Serial.available()) { // If data is available to read,
val = Serial.read(); // read it and store it in val
if (val == 'H') { // If H was received
digitalWrite(ledPin, HIGH); // turn the LED on
digitalWrite(XdirPin,HIGH);
digitalWrite(XstepPin,HIGH);
delayMicroseconds(2);
digitalWrite(XstepPin,LOW);
if(val == 'h') {
digitalWrite(YdirPin,HIGH);
digitalWrite(YstepPin,HIGH);
digitalWrite(YstepPin,LOW);
if (val == 'L'){
digitalWrite(ledPin, LOW); // Otherwise turn it OFF
digitalWrite(XdirPin,LOW);
if (val == 'l'){
digitalWrite(YdirPin,LOW);
delayMicroseconds(1000); // <<<<<< USE TO CHANGE SPEED <<<<<<<<
<br>If anybody wants to buy this, let me know. <br> <br>-Marc <br> <br>
<p>You're a genius! Very nicely done!</p>
For how much?
I'd have to say $200 for the mechanical structure - Or $600 for the full set- up, there is quite a bit of hardware involved. <br> <br>You may be better off with something from Makerbot, it debends what you have planned.
Excellent work and progress!!! I&nbsp;think I&nbsp;read your instuctable a year ago, and you just add your progress to the same instructable?<br /> <br /> I&nbsp;just want to clarify something... You have ONE arduino with a ATMega168 controlling 3 steppers and the extruder?&nbsp;<br />
<em>&nbsp;You have ONE arduino with a ATMega168 controlling 3 steppers and the extruder?</em><br /> <br /> Nope - I tried that, but I ended up using two &nbsp;Arduinos. &nbsp;One to control the X,Y,Z steppers and the other to control the 4th stepper on the extruder.<br /> <br /> Thanks for your kind comments!<br /> <br /> -Marc<br />
Thanks that helps a lot! <br /> Which firmware did you use?&nbsp;I am using this:&nbsp;<br /> http://sourceforge.net/projects/reprap/files/Arduino%20Firmware/v1.3<br /> <br /> Thanks
<em>Which firmware did you use? I am using this: http://sourceforge.net/projects/reprap/files/Arduino%20Firmware/v1.3</em><br> <br> Hi OuZo -&nbsp;<br> <br> I've been offline for a bit, so I am replying almost 2 months late!<br> <br> I do&nbsp;believe&nbsp;that is the firmware I used, I found it&nbsp;necessary&nbsp;to&nbsp;disable&nbsp;all the&nbsp;end-stops.&nbsp;<br> <br> Also -&nbsp;<br> For the extruder I used a stepper motor controlled by it's own Arduino. &nbsp;The RepRap code was meant for a DC motor controlled by a PWM driver. &nbsp;I simply wired the PWM output from the Master Arduino an input on the Slave Arduino. &nbsp;Whenever the slave saw anything on this input it would turn on the stepper motor. &nbsp;I did not adjust the speed at all, but you certainly could.<br> <br> If the code would be useful for you, I could dig it up. &nbsp;It is not on the machine I am currently using.<br> <br> I hope you are having great success!<br> <br> -Thanks,<br> Marc<br> <br> <br>
There is a book coming out from the creators of Processing - <br /> <br /> Getting started with Procssing<small><big> <span> ~ </span></big></small><span><span class="contributorNameTrigger"><a href="http://www.amazon.com/Casey-Reas/e/B001JRWKOC/ref=ntt_athr_dp_pel_1" rel="nofollow"><small><big>Casey Reas</big></small></a></span><small><span class="contributorNameTrigger" /><big> </big></small> <div class="buying" id="contributorContainer1" style="margin: 0.0pt;padding: 0.0pt;display: none;"> <div style="float: left;"> <div><small><big><b class="h3color">Casey Reas</b> (Author) </big></small></div> <div><small><big><b class="h3color">&rsaquo;</b> </big></small><a href="http://www.amazon.com/Casey-Reas/e/B001JRWKOC/ref=ntt_athr_dp_pel_pop_1" rel="nofollow"><small><big> Visit Amazon's Casey Reas Page</big></small></a></div> <div style="margin: 1.0px 0.0pt 0.0pt 1.0em;"><small><big><span>Find all the books, read about the author, and more.</span></big></small></div> <div class="tiny" style="margin: 10.0px 0.0pt 0.0pt;"><small><big> See </big></small><a href="http://www.amazon.com/s/ref=ntt_athr_dp_sr_pop_1?_encoding=UTF8&amp;sort=relevancerank&amp;search-alias=books&amp;field-author=Casey%20Reas" rel="nofollow"><small><big>search results</big></small></a><small><big> for this author </big></small></div> <div class="tiny" style="margin: 2.0px 0.0pt 0.0pt;"><small><big>Are you an author? </big></small><a href="http://authorcentral.amazon.com/gp/landing/ref=ntt_atc_dp_pel_1" rel="nofollow"><small><big> Learn about Author Central</big></small></a></div> </div> </div> <small><big> (Author), </big></small><a href="http://www.amazon.com/s/ref=ntt_athr_dp_sr_2?_encoding=UTF8&amp;sort=relevancerank&amp;search-alias=books&amp;field-author=Ben%20Fry" rel="nofollow"><small><big>Ben Fry</big></small></a></span><small><big><span> (Author) </span></big></small><br /> <br /> http://www.amazon.com/Getting-Started-Processing-Casey-Reas/dp/144937980X/ref=sr_1_7?ie=UTF8&amp;s=books&amp;qid=1273194179&amp;sr=8-7<br /> <br /> <br />
&nbsp;How does a processing code works?
If you want to write code to make stuff - check out<br /> <br /> <a href="http://openscad.org/" rel="nofollow">http://openscad.org/</a><br /> <br />
PLA filament is available here:<br /> <br /> <a href="https://ultimachine.com/" rel="nofollow">https://ultimachine.com/</a><br /> <br />
MAKERBOT&nbsp;FTW!<br />
Yes - I should have included a makerbot link<br /> <br /> <a href="http://www.makerbot.com/" rel="nofollow">http://www.makerbot.com/</a><br /> <br /> -Marc
need&nbsp; processing-arduino library for this step to work<br /> <br /> <a href="http://www.arduino.cc/playground/Interfacing/Processing" rel="nofollow">http://www.arduino.cc/playground/Interfacing/Processing</a>
It draws things! (?) Good job!
Yup!<br />
congratulations, this is an authentic science homemade lab!, the great innovations starts on sites like yours, go ahead, and we will follow closely your advances, great work!!!.......<br />
I'm not sure why you are going to all the trouble of writing such basic firmware and/or processing code when you can use the tried-and-tested firmware from the reprap project, with full support for G-Codes!.&nbsp;&nbsp; see http://objects.reprap.org/wiki/Getting_Started_with_the_Arduino_GCode_Firmware&nbsp; you can then have your repstrap draw anything that you want with a STL file, or any format that can be converted to GCode instructions.&nbsp;&nbsp; <br />
<em> <div><span style="font-size: 9.0pt;">Good point!&nbsp;&nbsp;&nbsp;</span></div> <div><span style="font-size: 9.0pt;">The RepRap project is inspirational and fantastic.&nbsp; But I have been having some&nbsp;trouble running their Firmware and Host Software.&nbsp; &nbsp;I&nbsp;decided that in the short term, I would&nbsp;rather work&nbsp;on some basic functionality then wrangle with the complete RepRap toolchain.<br /> <br /> Also &nbsp;-</span></div> <div><span style="font-size: 9.0pt;">Drawing on a piece of paper with a marker doesn't serve much of a purpose.&nbsp; But it shows that the system is working.&nbsp; <br /> <br /> So what is next? <br /> I haven't decided if&nbsp;I will move forward with the development I've documented in this Instructable, or go back to using existing RepRap code.&nbsp; I am not an experienced programmer, so I may continue on this path to gain some understanding.<br /> <br /> Also - <br /> I think there is a tremendous potential for crossover between the RepRap project and Instructables.&nbsp; I'm hoping that this will draw more people to the RepRap webpage <a href="http://reprap.org/bin/view/Main/WebHome"><font color="#800080">http://reprap.org/</font></a>&nbsp;.&nbsp; Imagine if there were 50,000 hobbyists working on this?<br /> <br /> Thanks again - <br /> Your question made me&nbsp;think!<br /> -Marc</span></div> </em>
Hi, I'm watching your instructable with much interest. Is very good for learning the principles. Look also here:<br /> <a href="http://www.sensi.org/~svo/motori/" rel="nofollow">Motori the plotter</a> - maybe you will find good ideas there.<br /> <br /> Vasi<br />
Thanks Vasi - I&nbsp;am glad you have found this useful!<br /> -Marc
A friend of mine is working with the XMEGA.&nbsp; This would be an awsome micro for projects like this.&nbsp; His dev board is here: http://cgi.ebay.com/Atmel-AVR-XMEGA-ATXMEGA-Development-Evaluation-Board_W0QQitemZ260488815978QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item3ca657e56a<br /><br />
Thanks for mentioning my humble little board! I'm working on an instructable for it. I'll probably need your help navigating the site and making it as AWESOME&nbsp;as all of yours. ;-)<br />
No problem - although it might not help much.<br /> <br /> Your webpage suggests you are planning to build a girl robot to take to the prom (although I didn't read any of the text).&nbsp; &nbsp;<a href="http://www.bostonandroid.com/">http://www.bostonandroid.com/</a>&nbsp;<br /> <br /> Also - Congrats on the new baby!!!<br /> <br />
About This Instructable
57,867views
99favorites
License:
Bio: Married to Domestic_Engineer (but I call her Meghan).
More by marc.cryan:How to by a cell phone for an 11 year old girl Cheapest, Bestest computer around, in beginning of 2015 Cryan Family Gothic Green House
Add instructable to:
