introControl a Schlage electronic deadbolt with an arduino!
This instructable will walk you through the process of dismantling and
hacking a Schlage electronic deadbolt in order to control it with an arduino.
Remove these ads by
Signing Up.
step 1Purchase the lock and unpack it
I got mine on sale for $99 at Lowe's.
Remove it from the box and take a look at what's there. The construction of the lock is really great. Anywhere that could even remotely see any moisture is surrounded with rubber sleeving or a rubber o-ring. The lock has 3 basic parts:
outside portion: This portion has a regular key cylinder, a knob for the deadbolt similar to what you normally see inside of a house, and a keypad for entering the code.
inside portion: This portion has a knob to operate the deadbolt, a housing for a 9v battery, and a switch to tell the electronics in the front of the lock when the lock is in use.
deadbolt mechanism: This portion is similar to any other deadbolt on the market.
To Download the PDF or View All Steps, Become a Pro Member » |
4
comments
Add Comment
Jul 22, 2010. 10:24 PMerikdv
says:
Thanks for the info! I'm looking at hooking up the motor leads to a
small 9v relay which in turn would be hooked up to a wireless DSC home
security contact. The N/C or N/O trigger can than be used to disarm my
alarm using the keypad on the Schlage. No need to type the same code
when getting in the house!
REPLY
Mar 28, 2010. 9:16 AMkool1zero
says:
okay, so i have a couple questions about the lock itself. i see the
numbers thew key hole and what not. so you can enter a code to get in,
unlock it with the key, or with the arduinmo that you're adding?
REPLY
Oct 16, 2009. 10:37 PMmackjr
says:
Now only if you have a remote control to use on it Wireless Entry
REPLY
Oct 17, 2009. 6:43 AMquadmasta (author)
says:
I just found out Arduino/X10 communication is fairly simple and
straightforward. I may take some time and interface an X10
remote with this. Good idea!
REPLY
Add Comment
