3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Control a Schlage electronic deadbolt with an arduino!
This instructable will walk you through the process of dismantling and hacking a Schlage electronic deadbolt in order to control it with an arduino.
Step 1Purchase the lock and unpack it
I got mine on sale for $99 at Lowe's.
Remove it from the box and take a look at what's there. The construction of the lock is really great. Anywhere that could even remotely see any moisture is surrounded with rubber sleeving or a rubber o-ring. The lock has 3 basic parts:
outside portion: This portion has a regular key cylinder, a knob for the deadbolt similar to what you normally see inside of a house, and a keypad for entering the code.
inside portion: This portion has a knob to operate the deadbolt, a housing for a 9v battery, and a switch to tell the electronics in the front of the lock when the lock is in use.
deadbolt mechanism: This portion is similar to any other deadbolt on the market.
13 comments
Mar 4, 2012. 6:51 PMbizshop says:
How would I connect two schlage digital locks so a correct combination in one will open both?
Jun 1, 2011. 9:13 AMtinker234 says:
wow this is nice
Jun 1, 2011. 10:13 AMtinker234 says:
hey could you program it to respond from a code like 4y456364762
Feb 10, 2011. 12:57 PMsmk8383 says:
Nice hack but I think it would be easier if you started with an RF controlled deadbolt. All you do is hack the fob which has lock and unlock buttons and you can put anything you do in a box within about 30 ft of the lock. You don't need to actually touch the lock or the door. If you screw up you've only messed up the fob.
Feb 18, 2011. 12:30 PMsmk8383 says:
Frys.com has the Morning Industries RF deadbolt for $70. As you say, it's only a Grade 3 lock where the Schlage you used is a Grade 2. In my application this doesn't matter since there is a window right next to the lock. Who would bother breaking the lock when they can break a piece of glass?
Jul 22, 2010. 10:24 PMerikdv says:
Thanks for the info! I'm looking at hooking up the motor leads to a small 9v relay which in turn would be hooked up to a wireless DSC home security contact. The N/C or N/O trigger can than be used to disarm my alarm using the keypad on the Schlage. No need to type the same code when getting in the house!
Mar 28, 2010. 9:16 AMkool1zero says:
okay, so i have a couple questions about the lock itself. i see the numbers thew key hole and what not. so you can enter a code to get in, unlock it with the key, or with the arduinmo that you're adding?
Oct 16, 2009. 10:37 PMMACKattacksnipe says:
Now only if you have a remote control to use on it Wireless Entry
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:quadmasta(Cribbs Technologies)
