Control an LED over the Internet via Arduino with Teleduino
 by nathanknz
There is something cool about making an LED glow via an Arduino. What could make that even cooler? How about making that LED glow from anywhere in the world via the internet? Now we're talkin'!
This process is made really simple using the Teleduino sketch for your ethernet enabled Arduino. Haven't heard of Teleduino? That's cool, you may want to take a look at Arduino Control via a Web Service with Teleduino to get yourself started.
This tutorial will guide you through the process of attaching an LED to your Arduino, and provide some example Teleduino API calls to:
  • Define the pin mode of a pin
  • Turn on the LED
  • Turn off the LED
  • Set the brightness of the LED (using one of the PWM supported pins on the Arduino)
If you get stuck on any of the steps, or if you feel that there is a step that could be explained better, please leave a comment so that we can improve things.
Let's begin!
Step 1: Prepare an LED
In this step we put together an LED that we can easily connect to our Arduino.
Parts needed:
  • An LED (we decided to use a 10mm white LED because they look neat)
  • A 1K Resistor (or similar)
  • Some hookup wire (we chose to use some single strand ethernet cable because it's cheap, and connects well to the Arduino pin sockets)
  • Some heatshrink (optional, but makes it look nice and tidy)
Steps:
  • Take the LED and shorten the lead on the flat-edge side (the shortest lead).
  • Shorten one of the leads on the resistor.
  • Solder the short lead of the resistor to the short lead of the LED.
  • Shorten the other lead on the resistor so that it's the same length as the remainder lead on the LED.
  • Solder the hookup wire to the two leads, and apply heatshrink. Take note of which lead is soldered to the resistor (we chose the white wire for this).
  • Strip the other end of the hookup wires and connect to the Arduino. The white wire (the wire connected to the resistor) connects to a GND pin, and the other (our green wire) connects to a digital pin (we chose pin 3 because it also supports PWM).
Awesome!
Step 2: Control LED via the Teleduino API
Here are some example API calls that you can use to control your LED. You need to replace {key} with the unique API key you obtained when you completed the instructable Arduino Control via a Web Service with Teleduino. Just chuck the URLs into your browser's address bar and you should see some magic happen on that LED.
Define the pin mode of digital pin 3 (Must be done once per boot prior to setting digital outputs. 'pin=3' mean pin 3, 'mode=1' means OUTPUT):
http://us01.proxy.teleduino.org/api/1.0/328.php?k={key}&r=definePinMode&pin=3&mode=1
Set the output of digital pin 3 to HIGH ('pin=3' means pin 3, 'output=1' means HIGH):
http://us01.proxy.teleduino.org/api/1.0/328.php?k={key}&r=setDigitalOutput&pin=3&output=1
Set the output of digital pin 3 to LOW ('pin=3' means pin 3, 'output=0' means LOW):
http://us01.proxy.teleduino.org/api/1.0/328.php?k={key}&r=setDigitalOutput&pin=3&output=0
Toggle the output of digital pin 3 ('pin=3' means pin 3, 'output=2' means toggle):
http://us01.proxy.teleduino.org/api/1.0/328.php?k={key}&r=setDigitalOutput&pin=3&output=2
Set the PWM value of pin 3 to 32 (LED will glow dull. 'pin=3' means pin 3, 'output=32' means PWM value):
http://us01.proxy.teleduino.org/api/1.0/328.php?k={key}&r=setPwmOutput&pin=3&output=32
Set the PWM value of pin 3 to 255 (LED will glow bright. 'pin=3' means pin 3, 'output=255' means PWM value):
http://us01.proxy.teleduino.org/api/1.0/328.php?k={key}&r=setPwmOutput&pin=3&output=255
Pretty neat, huh?
Step 3: Further Reading
Controlling an LED is just a very simple example of what can be achieved by using the Teleduino Arduino library/sketch.
To view the full API reference manual, take a look at http://www.teleduino.org/rtfm/api/328.php.
Have fun!
leonardsla3 says: Apr 26, 2013. 11:11 AM
This is great. I'm relatively new to arduinos,coding and electronics in general. I got this to work within an hour very good step by step guide. I have so many questions though mainly about the URLS and addresses.
---Define the pin mode of digital pin 3 (Must be done once per boot prior to setting digital outputs. 'pin=3' mean pin 3, 'mode=1' means OUTPUT):
http://us01.proxy.teleduino.org/api/1.0/328.php?k={key}&r=definePinMode&pin=3&mode=1------
When you say that it has to be done once per boot does that mean that this will have to be done every time you turn on the teleduino.
nathanknz (author) in reply to leonardsla3Apr 26, 2013. 2:17 PM
Hi leonardsla3,
Thanks for your comment, and great to hear that you get everything up and running nice and easy.
You're right about definePinMode having to be called each time the Teleduino is turned on, HOWEVER, you can set preset values on your Teleduino device which means that this can occur automatically and you'll no longer have to call definePinMode.
To set preset values on your device, pop over to https://www.teleduino.org/tools/manage-presets. Your device needs to be online for presets to be set (the values are stored in the Arduino's EEPROM).
Thanks for trying Teleduino!
Rainbowjeremy says: Jan 29, 2013. 1:53 PM
Great Instructable! I hooked up my Arduino running Teleduino to my Garage door opener using a Relay, and everything works fine, you just have to access the link that activates the pin and then quickly refresh the page to simulate a button push on the door opener. Is there a way to change the settings in the Teleduino API that will turn the pin on then off with one hit on the URL?
nathanknz (author) in reply to RainbowjeremyJan 29, 2013. 4:00 PM
Hi Rainbowjeremy,
Thanks for the comment!
Absolutely, the output time can be set. There is an optional parameter expire_time which sets the expiry on the output in milliseconds. If you set it to output=1&expire_time=1000 then the output will go HIGH, then go LOW after 1 second.
Thanks!
Nathan.
moleface says: Dec 17, 2012. 3:28 PM
Hi Nathan, this is really great. I will definitely be trying Teleduino. I notice that you said that it is possible to download the PHP class and host it directly on the Arduino/Ethernet shield. Are you able to provide any more details about how to host it directly on the arduino/ethernet shield?
Thanks again. Love your work.
nathanknz (author) in reply to molefaceDec 18, 2012. 12:21 AM
Hi Moleface.
Thanks for the comment.
The PHP class isn't for running on the device itself, it's for running on an external web server that supports PHP. The PHP class contains the methods required to communicate with the Teleduino.
Hope that helps! Let me know if I can help any further.
atalat says: Jul 29, 2012. 4:03 AM
Hi Nathan! This is a very good implementation...i have been searching for exactly this: a solution without port forwarding.
Do you plan to share your server code so anyone can implement their own web service using your library?
nathanknz (author) in reply to atalatJul 29, 2012. 12:27 PM
Hi Atalat,
Thanks for the interest and for the kind comment.
There is no intention to release the server code into the public domain at this stage, however there are ways to interface with the device without needing to use the proxy server. If you download the PHP class from the Teleduino website, and use the Web Server example sketch, then you can interact directly with the device. This does, however, require port forwarding.
Enjoy!
kenkoknz says: Jul 3, 2012. 9:16 PM
Hi,
I am getting an error on upload "Teleduino was not declared in this scope" can you advise.
Thanks,
Ken
nathanknz (author) in reply to kenkoknzJul 4, 2012. 12:48 AM
Hi Ken,
Thanks for making contact.
I suspect the problem is due to the Teleduino library not being extracted to the correct libraries folder under your Arduino IDE. If you're certain it's in the right place and you're still having trouble, please advise what version of the IDE you're running.
Incase you haven't seen it already, there is an Instructable which guides you through the installation process: http://www.instructables.com/id/Arduino-Control-via-a-Web-Service-with-Teleduino/
Please let me know how you get on, it could be of great benefit to others who may experience the same problem.
Thanks!
kenkoknz in reply to nathanknzJul 4, 2012. 2:28 AM
Hi Nathan,
Thank you for your prompt reply, you were correct, In my haste to see what happens next, I just copy the code, drop the library into the library folder but forgotten to reload the ide hence the library was not extracted even though it is in the right directory (i am using ver1.01).
I slowed down and followed your instruction carefully, the sketch loaded ok this time but i still have no joy. I did changed the api key to the one u sent me; the mac addr (to the one on the label on the ethernet board); after loading, the light flashed few times but not a steady pattern, and I cant make out what sequence it is. then stop for about a minute, then flashed a few times again.
Its a bit late in NZ now, i will try again some other time. Need to check my ethernet board or may buy one of those integrated arduino with ether on board, I will try to use a static ip (dhcp=false) next.
Anyway, you are doing an excellent job.
Many thanks,
Ken
nathanknz (author) in reply to kenkoknzJul 4, 2012. 3:30 AM
Hi Ken,
Great to hear you're getting a little bit further, and thanks for the kinds words about the project!
Is it possible to take a video of the flashing sequence? Sounds like it's trying to get connected but it's hitting a block somewhere.
Great to see a fellow NZer getting involved with Teleduino.
Thanks again,
Nathan.
kenkoknz in reply to nathanknzJul 6, 2012. 2:03 AM
Hi Nathan,
Finally got it going! I will share my experience ... the problem is with the Vodafone hg556 asdl router, even though the lan ports and the modem works perfectly when pcs are hooked up to it, the router does not recognise my ethernet shield for some reason. It took me a long time to work this out as the router lan port was working perfectly with other devices.
In the end, I did the following to make it work
I hook up an old router (dl524) as a hub and plug the ethernet shield to the dl524 and link it to the land port in the hg556. To do this I have to disable the dhcp on the dl524, reassign the ip address on the dl524 to the same network config (192.168.1.123 ), ensuring that it is outside the dhcp assigned range in the hg556.
I change the sketch by disabling dhcp (dhcp=false), setting a fix ip address for the shield, again making sure it does not clash with the hg556 dhcp range, in this case 192.168.1.180.
to further make sure, I defined & added the “gateway” pointing to the hg556: Ethernet.begin(mac, ip, gateway, subnet);
So all good, now. Thanks Nathan.
Ken
nathanknz (author) in reply to kenkoknzJul 6, 2012. 3:37 AM
Hi Ken,
Great to hear you got it up and running - enjoy!
hankenstien says: Jun 16, 2012. 11:09 PM
Hi I love your idea, I design and make web host as well as sell them at supercheapwebhosting.net , but im not here to advertise, I have been tring to find a script i can host on my server that will let me run these commands, without ruining everything off of my home computer, id rather leave my home network mostly out of the connection as much as possible, although, I know i will need to use a service like dydns or something similar, but, are you going to be opening up your scripts source code? it may a jumping off point i need?
any way good day to you, and cool idea, ill be watching.
nathanknz (author) in reply to hankenstienJun 17, 2012. 2:55 AM
Hi Hankenstien. Thanks for the comment.
There are some resources available at http://www.teleduino.org which include the Arduino library with example sketches, and also a PHP library to interface with them. There are a few different ways that you can interface with the device. You could either use the proxy server (which is demonstrated in this tutorial and doesn't matter if you have a dynamic IP), or you can interface with the Arduino directly using the web server sketch. Using the web server sketch means you need to configure port forwarding, dyndns etc.
I hope that answers your questions. Thanks!
urosepsis says: Apr 23, 2012. 9:56 AM
Thanks Nathan,
Easy as pie, as promised. I have tried other methods and failed, at least without paying for DDNS service. I have an SSR at the ready, bring on your next instructable....not like you're busy with a new server and new web page and, and, and....
nathanknz (author) in reply to urosepsisApr 24, 2012. 2:06 PM
I found this discussion on the Arduino forum which discusses SSRs, http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1293105899/all
They'd just be treated as a digital output as far as the Teleduino is concerned (same as this LED tutorial).
I haven't integrated an SSR before, perhaps you could post a Instructable about it? :)
nathanknz (author) in reply to urosepsisApr 23, 2012. 12:06 PM
Thank you for the comment. Keeping it simple has always been the aim of the game.
Can I ask what sort of SSR you have there? The circuitry may be different than a standard relay. Do you have a datasheet?
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
