Control and Automate Window Shades With INSTEON
31,285
63
16
Posted
Introduction: Control and Automate Window Shades With INSTEON
For as long as I have been into home control and automation, I have wanted to control every aspect of my home. While there are certainly professional solutions to automating your window shades, none of them have ever approached affordability. After stumbling upon a company selling tubular motors for reasonable prices, I decided to wire up something that might just do the trick.
Step 1: Parts List
What you will need:
Motors
Tubular motors from RollerTrol.com are affordable (at least in the world of tubular motors for shades), relatively quiet and easy to work with. The motors require 2A 12V DC power and can be reversed just by changing polarity. They even have an included rotation counter so that the up and down limit on your shade is managed by the motor itself.
Rollertrol.com DC Motors
Controller
My home is controlled with INSTEON so, naturally, I have come to an INSTEON automation solution. INSTEON recently released a new module, the Micro Open/Close controller which is essentially a dual-relay module. One relay responds to an UP command, the other to the DOWN command. The only cumbersome thing is that the relays operate at 120V AC, not the 12V DC we need for the motors. INSTEON does offer a dry-contact relay module, the I/O Linc, but you would need two I/O Lincs to control a single shade (one to control up, the other to control down).
INSTEON Micro Module
Power Supply
Any 12V DC, 2A power supply will do. My solution will require two supplies for each shade. More advanced hobbyists can probably wire up a polarity reversing switch that only needs one supply. I happen to have a bunch of 12V adapters around, so we're going to just use what is on hand.
12V DC 2A Power Supply
Relays
Because we will be wiring both supplies to the motor at the same time, we need a way to break the circuit. Any 12V SPDT relay should be more than adequate. I used automotive relays as they were easy to wire but certainly overkill.
12V SPST Relay
Step 2: Installation
Mounting
Mounting the motor is rather straightforward. The RollerTrol motors ship with mounting brackets that screw to your window frame and mount via a small metal flange. As for tubing, if your window distances are shorter (4' or less), SCH40 PVC pipe works rather well. I would probably take a motor mount to your home center and test the fit though. I found enough inconsistency that I had to try several different pipes each time. If your distances are longer, RollerTrol suggests metal electrical conduit. Make sure your mounting is level or your shades won't hang properly.
Route the two motor wires through the mourning bracket and out of the way of any rotations. The last thing you want is for your shade to somehow catch the wires and rip them out of the motor. If you are placing multiple motors near each other in a bank of windows, you might consider using ethernet to gang together different motors. With one ethernet cable, you can pass power to four motors. Ethernet is cheap, easy to run and should be more than adequate for powering your motors. Keep length in mind though and always test before you commit anything to drywall.
Step 3: Installation - Wiring
Follow the included wiring diagram and you should be fine. You should always use caution around 120V and since this project uses both 120V and 12V, now is no exception.
In a nutshell, connect one 12V supply to each of the two relay terminals on the micro module. Wire the relays so that they will be powered by the 12V supply and the normally open contact will close to send power to the motor. It may seem wacky, but without the relays in the mix, power doesn't flow properly to the motor.
Step 4: Almost Finished
The hard part is over. If everything works, pressing down on the Micro Module will lower the shade and pressing up will raise the shade. I suggest you become good friends with a seamstress and leave the sewing of your shade panels to them.
Controlling the shades is the best part. You can keep it simple and pair your Micro Module to any other INSTEON controller or you can go off the deep end and build a custom interface for just your solution. My home is powered by Perceptive Automation's Indigo using their webpage-based control pages to build a custom user interface for my shade setup.
    • Microcontroller Contest
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    16 Comments
    Please forgive my limited understanding of electrical diagrams, but can someone confirm MarioR3's diagram for a one power supply version would work?
    Also, baughhumbug, are those circuit boards you attached to the wood plate just the guts of 12v power supplies or something else?
    Thanks!
    M
    Great idea, I really appreciate these instructions. I wired up my setup following your diagram and when the micro open/close switch is triggered the Rollertrol does not move. Can you confirm your wiring plan. Any changes to the micro controller settings? I've checked my wiring against your diagram and it matches up. Normally close (87a) white; Normally open (87) blue; Contact Armature (30) black; Coil ground (86) yellow; Coil positive (85) red ((not used in your configuration)). Really appreciate your effort putting this together. thanks!
    Hello insteon_diy. I'm sorry to hear that you're having difficulty with the wiring. I have to admit, this was the most complicated part of the endeavor. I don't have a direct answer for you but I do have a few suggestions:
    • There is an error in the digram: the white wire on my wire harness is normally open, not normally closed
    • Try each component individually: make sure the motor is powered by the 12V PSU on its own and make sure the relay is powered by the 12V PSU on its own
    • I would try connecting the motor directly to one of the 12V PSUs to see if it turns normally without the complication of the relays
    • If it doesnt, try reversing the connection to the motor and the power supply
    • The Rollertroll motors have an internal rotation counter and if you are at the end of the rotation, reversing power should get the motor to at least show some signs of life.
    • If you still cant get any life out of the motor, try pressing and holding the set button hidden in the non-rotating side of the motor friction ring. If after a few seconds, the motor sounds three beeps, it will go into a programming mode where you can set the limits of the rotation. You'll want to do this to set the limits once your shades are up, but in the meantime it at least lets you know power is working.
    • As for the relays, it is possible that the wiring harnesses are not color coded the same even if your purchased the same relay set
    • Try connecting your 12V PSU to the relays two power leads such that you can hear it click. For my relays, this was blue and yellow (I'm afraid I don't have the relays present to check the numbered markings).
    I really do hope this helps
    So before I read this comment I wired up my set up based on the wire colors in the diagram and it did not work. In examining the pictures it looks like the coloring is completely different from my relays to yours. Could you label your colors for me? Like on my relays: Black = 30, Red = 85, White = 87a, Yellow = 86, Blue = 87.
    Mike, this is how I got my insteon/rollertrol wiring to work (based off of Humbug's work). I'm not an electrical pro and hope my house doesn't' burn down.... I have three of these setup as of this weekend.
    Diagram whit 1 power supply
    Thanks so much! I did a quick mock up and your circuit worked perfectly!!! However that said, I do now question the purpose of these relays. The way they are wired whatever voltage is supplied across 85 & 86 will go through 87 & 30. Since the two relay circuits are working independently (only sharing a ground) if you were to somehow supply voltage across the 85 & 86 pins of both relays they would both be turned on with no way to get to ground. I am thinking maybe something like the image attached. Have one voltage source switching off the path for the other. This way if both were to be turned on at the same time then both circuits would break. Any thoughts?
    Awesome Instructable baughhumbug! So I am thinking to save money I am going to have all 3 windows be controlled as one. Using only 1 Insteon controller and wiring the motors in parallel. If my memory serves me correctly from Circuits 101, I can use your diagram, wire the motors in parallel and use power supplies with an output of 12v 6A and I should be good. Any thoughts?
    Thank you. And, technically, yes, you should be fine. The Rollertroll website even suggests a similar setup when you want multiple motors to be controlled from a single device. The only thing that I've noticed with the motors when you have multiple windows side by side - the motors don't always seem to run at the exact same speed. It could be differences in weight but I have two shades side-by-side that are identical and the left one always rolls up about 4 seconds faster. Happy automating!
    I think I just spotted a potential issue with my plan... the listed Max load of the Isteon controller is 2.5A motor or 8A resistive. With three motors running simultaneously I would be drawing 6A to motors. These are the windows I am trying to shade: http://i.imgur.com/Vjpnopv.jpg I am now thinking of just getting 1 12lb motor and using a single tube with 3 shades on it. Do you think a single 12lb motor could handle that?
