Step 3Put everything together
Right now you should have the Palm dock, the Create Robot Serial Cable, and your null modem. It's a good idea to bundle up the wires with twist-ties (or string/elastics/etc.) so we don't have a big mess of wire. The Serial Cable should be plugged into the create and the Null Modem. The other end of the Null modem should be plugged into the Palm dock (if you need to use a 9-pin gender-changer to make things fit then do so).
When your finished you should have something that resembles the picture below. With just this you can communicate with your robot using your Palm Pilot; you might want to test everything now in case something isn't working. If everything works congrats, you can move on to the next step.
Add Comment
