3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Controllable RGB LED system for your home or office
Step 3Construction time!
Construction time!
By the time you reach this step, you should have completed your design and purchased all your parts. I love receiving boxes of parts to make my great ideas into reality, how about you? Nothing beats putting your hands to work building the design that you crafted in the previous steps.
When I assemble a system, I take my time to double check my construction. I double check components before populating a PCB, I double check connections that are soldered or terminated such as data cables, and I test the system at increments as I go along.
With a large RGB LED system there are many things that can go wrong, so testing as you go along is a good idea. This technique will help you identify problems before they become bigger problems and damage other components. For instance, we tested the
Prop Blade controller before we attached it to the LED Painter driver PCB.
When you start constructing your system, the first thing you should do is assemble your controller and LED driver circuits. If you are using a kit like one of ours, great, then the procurement of parts was easy and assembly shouldn't take too long. If you are building your own controller and LED driver this step may take more time. Don't worry though because the effort is worth it when you get the controller of your system working.
When assembling a kit, you should print out the schematic and bill of materials to make sure you use the right components and place the component in the right spot.
When you finish assembling your controller, take the time to power it on and test it. Download a simple program to the controller to verify that the controller works. In our case, we used the Parallax Prop Plug to download software to the Prop Blade.
Once you finish a driver board, power it on to make sure nothing explodes. Once you've passed that test, add a single RBG LED to a channel and attach the driver to your controller. Use a simple program to verify that the controller can control the driver/RGB LED setup. Again, for the Prop Blade and LED Painter we have example programs on our site: Brilldea.com.
Now that you have the electronics done, let's move on to the LEDs!
9 comments
Sep 29, 2011. 9:29 PMneveroddoreven99 says:
I'm not sure if I'm completely on the same page as far as controllers go. My band plays our live show to midi clock and were looking to purchase DMX controller software that would allow the programming of a live show to a strict timeline (the songs) while each song being triggered by a midi clock. Can I control this via DMX? If you point me in the right direction I can do the homework myself, I was just wondering if there is software that your using to program the lights in your video, or if this project might be compatible with DMX.
Nov 1, 2011. 3:53 PMneveroddoreven99 says:
Thank you for the information! Yeah, sadly this is way out of my league. I know how to work with DMX operationally, but not functionally. If you know anyone who would be willing to tackle this for a somewhat reasonable price, we would be very interested.
Actually, one other question. I came across a message board topic created by T.D Sweiter (who on his website says he works with Billdea, which according to this instructable is you) in which he states that he's made a Propeller DMX receiver. Is that simply enough? If I'm using Elation's Compu Show, is it enough that I program a show, send it out to a Propeller/Arduino receiver and run it to you lighting rig from instructables? I keep reading of libraries and code, but everything I actually find seems to be completely hardware based. Would there be additional coding involved?
Nov 3, 2011. 8:50 PMigutekunst says:
I am currently working on either an Arduino or PIC based DMX "interpreter" or "controller" that will be able to drive a chain of TLC5940s, or the Brilldia LED Painter, which is based on the same integrated circuits. I'll try to post back here when I have something working, but don't get your hopes up.
A few resources to look at is the Entec Open DMX controller
http://www.enttec.com/index.php?main_menu=Products&pn=70303&show=description
The Arduino TLC5940 library
http://www.arduino.cc/playground/Learning/TLC5940
and the tutorial from FreakLabs about receiving DMX with an Arduino
http://freaklabs.org/index.php/Tutorials/Software/Light-Sequencing-and-Decoding-DMX-with-an-Arudino.html
I believe one would be able to use the DMX receiving code and the TLC5940 library to control the Brilldia LED Painter, or a chain of TLC5940s.
Good Luck
Jul 17, 2011. 3:11 PMEAS2013 says:
Hello, I am new to LED's and electronics. I really want to build a project very similar to your bookshelf design. I watched your video and did some research but I am still slightly confused as to everything I need. If you could provide additional information on the subject, I will be ready for purchase of parts from you. Thank you for your time.
Jul 22, 2011. 11:19 AMgraffix says:
I spent quite a bit of time and money dealing with these products and had no success as with other customers.I'd recommend looking else where.
Jun 11, 2009. 7:33 PMVizualXTC says:
I love your bookshelf setup. I work in a club, and something like this would be great. It would put our club one off from the competition. Problem is the initial financial setback of an item like this. Would you possibly know how much this would cost? Thanks for the great instructable.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
37
Author:Brilldea(Brilldea)
Brilldea is a purveyor of prototyping goods. Our products help you to achieve your brilliant ideas.
