3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Controller-Embedded Remote Lag Switch
In this Instructable I'll show you how to make a remote lag switch that's embedded in your controller, allowing you to trigger it without lifting a finger.
The "remote" part of this Instructable stems from the fact that the trigger is away from the actual switch, so that you needn't sit within reach of the ethernet cable it controls.
The "controller-embedded" part uses the battery shell from a wireless Xbox 360 controller, so take note that you'll want to have a Play & Charge kit to use the controller. The rechargable battery in the kit replaces the battery shell that comes with the controllers, so most will have no use for it, and the cable will supply power to the controller whilst using the lag switch.
You can also adapt this Instructable for use without a controller, simply by placing the trigger in another enclosure of some kind. I've thought of placing it in a box by my foot, so I can just "stomp" on it when I want some lag.
Step 1Parts and Tools
Parts and Tools
This Instructable is a fairly easy one, requiring only a few common tools and some cheap parts from your local Radio Shack or equivalent.
Tools:
Wire cutters & strippers
Soldering iron
Solder
Screwdriver(s)
Drill
X-acto knife/Stanley knife
Multimeter
Hot-glue gun
Hot Glue
Parts:
Ethernet cable (the length is up to you, I used a short one as the distance between my router and Xbox is tiny.)
Enclosure/project box (again, size is up to you, but smaller is better in this case.)
Heatshrink tubing
Veroboard
Spare Xbox 360 controller battery shell (it won't ever hold batteries again, make sure you aren't using it.)
Generic hook-up wire
Shielded wire (we'll be using the shield as another wire, feel free to substitute a different type of wire.)
Two watch-battery holders (CR-2032, CR-2025 or CR-2016 recommended.)
Two watch-batteries to suit the holders
A normally-open push button (I used a button that had both N.O. and N.C. but it's not necessary.)
A SPDT (single-pole, double-throw) 6 volt relay
All up, this should cost you under $15.
19 comments
Oct 18, 2011. 10:44 AMRDProgrammer says:
This instructable should be taken down and the posted banned. How is this not a site policy violation?
Dec 30, 2011. 11:17 PMII Laylovv II says:
This should be taken down and sh*t the f*ck up LarryDProgrammer... You sound like revenge of the nerd.
Nov 22, 2011. 11:37 AMpootie22 says:
I don't see why people are making such a big deal about this.
Search keyword "cheat" on instructables and you'll find
Cheat on any Wii
How to cheat on chess
How to cheat on a test with a T shirt (yay cheat ur way to a degree!)
How to cheat a polygraph test (god forbid our national security is in jeopardy)
How to cheat at poker (i'm sure more people play this for money than COD)
Dec 14, 2011. 5:39 PMcornoncob56 says:
Will someone please tell me what the batteries and the circuit board are for? and is there a way around the circuit board?
Nov 19, 2010. 4:25 PMnathangill says:
Good job on the instructable - very informative.
But I sincerely hope that if you use this on Xbox live, they ban you for tampering.
Can you explain why you'd want to use one of these, besides not being able to play and win a good, clean game?
It's worth noting that this kind of cheating device can be spotted quite easily by players that know what to look for, and after a few reports you can be banned from Xbox live for using one.
And I swear that I'll report anyone I spot using one. If I'm playing in a party, I have my team mates report them, too.
Dec 4, 2011. 1:10 PMWilliam930 says:
I appreciate that you wouldn't use it online, but for me the problem is that most of the people that make it will. Its like posting an instructable on email hacking but then telling people to only use it on consenting friends. Its probably not going to happen. Ive run into plenty of lobbies where this kind of thing is being used.
Oct 16, 2011. 8:36 PMWilliam930 says:
How would you use it off-line?
Oct 18, 2011. 1:25 PMsrhadaham says:
lan party, at least i assume that's what he means by offline
Oct 16, 2011. 8:50 PMv0rt3_x86 says:
The sole purpose of this is to cheat and ruin online gaming.
Applying a wafer-thin "do not use online," disclosure on here is lame.
Thanks for further ruining CoD.
Oct 18, 2011. 2:13 PMgoliathfox says:
I agree with V0rt3_x86 comment. I see no fun out of using this LAN or Online. This is just another way to cheat online. Instructions like this, ruin the quality of online gaming.
You should really create a more constructive instructable with the skills you have. Helping 12 year old kids cheat online is just a waste of your time and everyone else who reads this.
Oct 22, 2011. 6:51 PMv0rt3_x86 says:
That's like saying "I don't promote robbery, but please rate this Instructable on the quality of instruction instead of judging me on how clearly inappropriate it is."
Oct 20, 2011. 12:48 AMgreightbit says:
I think that even if your intentions are good, this mod will allow people to cheat... easily. I agree that it should be taken down.
Oct 18, 2011. 12:25 PMNick.D says:
So what exactly does this do? Just make you lag out and skip around the map?
Oct 18, 2011. 11:01 AMmilesduggan says:
Its people like you that ruin good clean competition. Makes me not even want to play anymore.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Archive555
