Controlling Motor Using LDR
Published
Introduction: Controlling Motor Using LDR
About: I'm a mechatronics engineer. I'm into mechanics, electronics, CAD, any engineering discpline pretty much :D My hobbies is to cook, read and practice sports
The idea is making Line Follower Robot by using LDR
LDR defines light resistivity and differentiate between white and black (TM1).
Voltage drop between LDR and R1 is used to trigger base of transistor (2N222) to allow motor movement on jumpers (J1, J2)
,When LDR< R3 motor will switch on ( white space)
When LDR> R3 motor will be off ( black lines)
JP4 for power (+12V)
JP3for Ground
Using two circuits with two motors will be enough for making Line follower Robot
Step 1: Board Layout
On eagle software after drawing the schematics, open board layout, add routes to the components and board border
Step 2: PNG Files
Extract PNG file for bottom layer, pads, dimensions and vias ... mirror the image
Extract another PNG file for only pads, dimensions and vias .... mirror image then switch white and black colors
Now the files are ready to be manufacutred on Modela Machine then Soldered
    • Woodworking Contest
      Woodworking Contest
    • Oil Contest
      Oil Contest
    • Planter Challenge
      Planter Challenge
    2 Comments
    AWESOME PROJECT
    Hi, RashaH
    I am a student of class 11 and I am trying to make a similar circuit but I dont have modela machine or one like that so can you please help me out in building such a circuit on breadboard. It will be a great favour if you can help me out...........
    regards
    Hello,
    sure it can be easily done with breadboard. just make the exact connections on breadboard using jumpers and it should work
