Controlling a Servo With Ultrasonic Sensor Signal Using Arduino ( Automated Gate System )
8,702
79
Published
Introduction: Controlling a Servo With Ultrasonic Sensor Signal Using Arduino ( Automated Gate System )
In this project we will simulate an automated parking gate
by using an ultrasonic sensor to open and close the gate if a specific distance is achieved, and we will use ( EPILOG LASER ) the laser CNC to build our structure
Step 1: Hardware
  • Ultrasonic sensor
  • Arduino uno Microcontroller
  • Servo motor
  • Jumper caple
Step 2: How Does It Work
The ultrasonic sensor will detect the distance infront of the gate if a car came closer than 20 cm to the gate the ultrasonic sensor will send a command to the arduino microcontroller to open the gate , then the ardino will send a command to the servo to open the gate 90 Degree to open the gate
Step 3: Connection: Ultrasonic Sensor
  • Vcc to 5V in the arduino
  • trig to port 2 in the arduino
  • echo to port 4 in the arduino
  • Gnd to Gnd in the arduino
Step 4: Connection : Servo Motor
  • Black wire to Gnd in the arduino
  • Red wire to vcc in the arduino
  • Yellow wire to port 9 in the arduino
Step 5: Structure
The structure for this project had been designed by a laser cutter and connected to each other by super glue, you can see the picture below.
Step 6: Conclusion
At the end this is how the project will look like , it looks kinda funny , but I built to merely visualize the idea.
whenever something gets withing the range of the ultrasonic sensor , it will measure its distance from sensor , and if it was less that a certain amount, the servo will turn , opening the gate.
it's just an idea for a simple application of using sensor and actuators to make something useful easily with Arduino
Step 7: The Code
As usual , just copy the code to Arduino IDE and upload it :
#include
Servo myservo; // create servo object to control a servo
const int trigPin = 2;
const int echoPin = 4;
void setup() {
// initialize serial communication:
Serial.begin(9600);
myservo.attach(9); // attaches the servo on pin 9 to the servo object
void loop() {
// and the distance result in centimeters:
long duration, cm;
pinMode(trigPin, OUTPUT);
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(20);
pinMode(echoPin, INPUT);
duration = pulseIn(echoPin, HIGH);
// convert the time into a distance
cm = microsecondsToCentimeters(duration);
// the condition for the distance
if ( cm > 7 && cm < 14)
myservo.write(140); // sets the servo position according to the scaled value
delay(4000);
else if ( cm < 8)
myservo.write(40); // sets the servo position according to the scaled value
delay(100);
else
delay(100);
Serial.print(cm);
Serial.print("cm");
Serial.println();
delay(100);
long microsecondsToCentimeters(long microseconds) {
// The speed of sound is 340 m/s or 29 microseconds per centimeter.
// The ping travels out and back, so to find the distance of the
// object we take half of the distance travelled.
return microseconds / 29 / 2;
    • Microcontroller Contest
    • Make it Move Contest
    • Casting Contest
      Casting Contest
    2 Questions
    Why is it showing error in return
    What will be the filetype in #include
