Controlling a Stepper Motor With the Raspberry Pi and Piface
103,034
158
19
Posted
Introduction: Controlling a Stepper Motor With the Raspberry Pi and Piface
Updated April 2015
I have made this because I have found no projects using the PiFace.
Forum topic at www.raspberrypi.org:
http://www.raspberrypi.org/phpBB3/viewtopic.php?f=37&t=54314&p=413902
Here is a simple project that only needs a Raspberry Pi, PiFace, Python, jumper wires, and a stepper motor - that's it!
Step 1: Schematic
Step 2: Connect the PiFace to the Raspberry Pi
Put the PiFace breakout board onto the GPIO connectors pf the Raspberry Pi.
Simple ;-)
Step 3:
First connect a jumper wire from ' 5 v' to red wire on motor.
Step 4:
Second connect a jumper wire from 'output 4' to orange wire on motor.
Step 5:
Third connect a jumper wire from 'output 5' to yellow wire on motor.
Step 6:
Fourth connect a jumper wire from 'output 6' to pink wire on motor.
Step 7:
Fifth connect a jumper wire from 'output 7' to blue wire on motor.
Step 8:
Sixth type this into a python file (or copy-paste):
  #CONTROLLING A STEPPER MOTOR
  #Author: Robert Caldwell
  #Date: 14 August 2013
  from time import sleep
  import piface.pfio as pfio
  pfio.init()
  print"Type: direction(rotations, speed)"
  def anticlockwise(rotations, speed):
      sleep_time=0.1 / float(speed)
      for loop in range(1,int(512*float(rotations))):
          pfio.digital_write(4,1)
          sleep(sleep_time)
          pfio.digital_write(7,0)
          sleep(sleep_time)
          pfio.digital_write(5,1)
          sleep(sleep_time)
          pfio.digital_write(4,0)
          sleep(sleep_time)
          pfio.digital_write(6,1)
          sleep(sleep_time)
          pfio.digital_write(5,0)
          sleep(sleep_time);
          pfio.digital_write(7,1);
          sleep(sleep_time)
          pfio.digital_write(6,0)
          sleep(sleep_time)
  def clockwise(rotations, speed)
          sleep(sleep_time)
          sleep(sleep_time)
          sleep(sleep_time)
          sleep(sleep_time)
          sleep(sleep_time)
          sleep(sleep_time)
          sleep(sleep_time)
          sleep(sleep_time)
Step 9:
Done!
The motor I used was 28BYJ48 5V DC
Your motor should now obey orders you type!
(make your speed 10-600)
If you have any problems, ask me!
  • Science of Cooking
    Science of Cooking
  • Pocket-Sized Contest
  • Trash to Treasure
    Trash to Treasure
16 Comments
hi
i want to controler 2 stepper motor with rasbperry pi 3 (python)
how!!!!
My python shell tells me that there's a mistake in the line #6
ImportError: No module named piface.pfio
See page two here:
http://www.farnell.com/datasheets/1684425.pdf
the motor is bipolar
hey, can I use raspberry to make a CNC controller ?
I love it!!! I translated it for the PiFaceDigitalIO library:
Here is your code redone
import pifacedigitalio as p
p.init(False)
pfd = p.PiFaceDigital()
print("Type: direction(rotations, speed)")
pfd.output_pins[4].turn_on()
sleep(sleep_time)
pfd.output_pins[7].turn_off()
sleep(sleep_time)
pfd.output_pins[5].turn_on()
sleep(sleep_time)
pfd.output_pins[4].turn_off()
sleep(sleep_time)
pfd.output_pins[6].turn_on()
sleep(sleep_time)
pfd.output_pins[5].turn_off()
sleep(sleep_time);
pfd.output_pins[7].turn_on();
sleep(sleep_time)
pfd.output_pins[6].turn_off()
sleep(sleep_time)
def clockwise(rotations, speed):
sleep(sleep_time)
sleep(sleep_time)
sleep(sleep_time)
sleep(sleep_time)
sleep(sleep_time)
sleep(sleep_time)
sleep(sleep_time)
sleep(sleep_time)
Sorry It did not seem to import the indents which are very important
Doug Wyman
Does this leave a pi face output spare for an LED?
Yes it can I will post a guide for controlling an LED soon.
(PS you can use a breadboard to divide up which parts go where)
