loading
Step 2: Building the circuit - power connections
USB powers the arduino, the batteries power the solenoid. A jumper grounds the two together.
<p>I need its ardino code , can u help me?</p>
<p>After recreating the circuit numerous times, I've found that I cannot get the transistor to engage, and that the circuit as I have done it runs current through the solenoid with or without voltage from the digital pin. Is there any explanation for this? I've wired two 9v batteries in series, and am using a 24v solenoid (like one used for a sprinkler). Both my transistor and diode are NTE, but should be interchangeable with the suggested models, as per the catalog. I greatly appreciate any input.</p>
<p>Hello!</p><p><br>What can I do when, after all of the connections are according to the tutorial, the solenoid works with voltage variation (if I change the current for example) and simply it ignores the signal sent by Arduino?</p>
<p>I have the exact same problem. Have you worked out how to fix it? </p>
I just rebuilt the circuit but basing on the photo and not on the scheme.
<p>What's the difference between the photo and the scheme? Just wondering as I am experiencing the same problem.</p>
just wondering if it would be possible to add another solenoid into the circuit and have it run at a different speed than the first solenoid??
<p>yep just duplicate the circuit for any additional outputs and modify the code for the extra output pins</p>
<p>thanks and do you know how i could control the solenoid at differnt speeds?</p>
what is the use of diode in the above circuit???
<p>it prevents &quot;kickback&quot; current from damaging the arduino</p>
how to control the on/off of the solenoid? include into the coding the condition it should be on and off?
<p>where can I buy this solenoid? I am European</p>
<p>I'm doing a project in school and need to operate three solenoids independent of each other. Is there a way to manipulat this setup to do that? Can anyone please help me with that?</p>
<p>Yes u can do that.above shown procedures is for one solenoid,similarily you have to use same circuit for controlling 2 or more solenoid indiviually.use three transistor and make the three circuit indiviual.just u have to use same power supply for all the three thats all</p>
<p>you could use relay for each solenoid. and control those relay with arduino.</p>
<p>Please, I need your help, I am Using the TIP 122 and is hot when the circuits is On, same with the Solenoid, this is normal? or I need to do something?<br><br>Thanks for your answers</p>
This circuit is used to substitute a relay board???
Can look at the codes? Ryply asap.
<p>Nice project..! Do you have any code of solenoid lock or Unlock? please....!</p>
<p>I want to use the pneumatic cylinder at slightly higher switching speeds. Can I use the IN4148 diode? The solenoid valve that I am using works at 24V DC. </p>
Did you minded, if i see your schematic?
Hello - we are currently using your instructions as a reference tool for a project and are confused at the discrepancy of the Arduino board vs the Arduino One board.
<p>i need coding for this above video</p>
<p>Hello, the solenoid i'm trying to control has 3 pins. where should i connect these pins? thanks!</p>
<p>I'd be interested to know as well. I've you figured out how to wire it?</p>
<p>*Have you? (late night typing)</p>
<p>I know this question is a month old, but it might be usefull for other people.</p><p>In valves like these, you have 2 parallel and 1 perpendicular pins. The parallel ones need to be connected to your output driver. It doesnt matter which pin gets the positive/negative or live/neutral. The perpendicular pin is for grounding.</p>
Thanks for the reply :)
I believe that is a solenoid valve for water.
<p>Thank you, this is very helpful to us newbies. </p>
<p>How do you modify the code in order to run twice a day?</p><p>Every 12hrs for exaple for watering plants needs to stay open for 2 mins and repeat?</p><p>What is the difference if i use a relay instead a transistor?</p><p>Thank for sharing</p>
<p>I've used this circuit many times now to control solenoids but also to control motors via pwm. Good Stuff - Thanks for Sharing!</p>
<p>Can this be accomplished without usb power?</p>
<p>when the solenoid is active, it tends to heat a lot, what do you do with yours?</p><p>thanks!</p><p>marC:)</p>
Could an arduino control nine solenoids (though only one would be in use at any time)? I was thinking how much work it would be to make an automated whack-a-mole out of http://www.thinkgeek.com/product/1270/
<p>See this link, maybe can helpyou.</p><p>sonidiario.tumblr.com/post/35689237364</p>
<p>how many solenoid valves can i trigger using ardunio......i am using it to make programmable fountain.</p><p>plzz rply soon</p>
<p>Maybe this link can help you.</p><p>sonidiario.tumblr.com/post/35689237364</p>
<p>I have done all the steps, but with a TIP126 transistor and a IN4007 diode... when I connect the batteries to the breadboard, the solenoid opens, but nothing related with the Arduino seems to work... what can I do? Is it because of the different diode or transistor?</p>
<p>Hi Kvnn,<br>I have the same problem, have you found a solution?</p><p>Thanks<br>Mike</p>
<p>I had the same problem because I had connected the diode to the GND rails rather than the SOLENOID V+ rail. </p>
<p>This was very helpful! Thanks!!</p>
<p>Nice tutorial, thanks for sharing it.</p>
<p>hello..i aldy connect all the components correctly..but when i turn on my power supply..my arduino suddenly give error..i am using 24V solenoid..and using labview interface with arduino..is it happened because the power supply is unstable?when i measure the power supply it gives 32V instead of 24V..</p>
<p>TIP122 will also work ??</p><p>thanks!<br>marC:)</p>
About This Instructable
327,903views
277favorites
License:
More by jts3k:Controlling solenoids with arduino Superterrific Tub Bass
Add instructable to:
