Step 5There is a little cylinder in all of us...
iImage Information
Find the center of the cylinder from the bottom and place a finishing nail there. (If you used the chain method from the last step then just reuse the nail hole that was used to scribe the circle) This will help to line it up with the center of the can. This is a good time to whip out the machine gun...oops...did i leave that little tool out of the materials list? I guess a drill will do...drill all those drain / vent holes in the trash can. Find the center of the bottom of the can, drill a hole there and a few more radially outward from the center. These will secure the inner cylinder (the sifter / screen). Now put the sifter cylinder in the trash can; insert the pin (a.k.a. finishing nail) that is at the bottom of the cylinder into the hole that is in the bottom of the trash can. Find a minion...I mean helper... to hold the inner cylinder while you shoot screws through the bottom of the trashcan into the wood of the inner cylinder. You might even be able to stand the cylinder and trash can up on a block of wood or something so that you can do this without help.
