Convert 3-AAA Flashlite to Lithium
Introduction: Convert 3-AAA Flashlite to Lithium
I like having a small flashlight with me when working. Especially one with a nice pocket clip, but don't like those with 3 AAA cells. After noticing a 14500 lithium cell is very close in length to those 3 AAA cell holders, It got me to think if can I make work with it. A 14500 cell is close in voltage to 3 AAA cells.
Step 1: Compare Sizes
If you remove the battery holder from the flashlight (this one is a Lowes Utilitech), you will see the sizes are almost the same. Just the diameter of the AAA holder is larger.
Step 2: Make a PVC Sleeve
To compensate for the larger diameter of the AAA holder, cut a piece of schedule 40, 1/2 inch PVC pipe. The length is just a little over 2 inches. Try 2-1/16 inches. The 14500 cell will slip inside the PVC pipe. You may need to adjust the length to minimize rattle.
Step 3: Add a Piece of Shrink
To help enlarge the sleeve diameter, shrink down a piece of heat shrink tubing over the PVC tube. You could just add a layer of tape instead. This will prevent the tube from rattling inside and center the battery better.
Step 4: Place Inside Flashlight and Test
Slip the adapter and battery inside your flashlight. Remember to face the Positive End toward the front of the flashlight. The flashlight should work now. When using lithium cells, try not to over discharge the cell so as not to damage it. Charge the cell before it reaches 2.5/2.7 volts. Using cells with built-in protection is recommended.
  • Paper Contest 2018
    Paper Contest 2018
  • Pocket-Sized Contest
  • Science of Cooking
    Science of Cooking
The lithium cell shown is a common lithium ion 14500 Ultrafire that charges at 4.2 volts. The 18650 you mentioned will not fit the flashlight and can't be used. Only use a 14500 size cell. When in use, the cell voltage will be about 4 volts.
Why replace the AAA with a battery that has less voltage and less storage capacity?? I use rechargeable Sanyo E's which have a voltage around 3.75 and a reserve of 2400 ma. Your conversion is 3.7 to 4 volt with 900 to 1400 ma reserve.. Did I miss something???
Actually AAAs are are pretty horrible when you consider they have about 1/3 the capacity of AAs and cost EXACTLY the same. All but the tiniest flashlights made with AAAs are a crime against all that is good. Any attempt to removed a AAA powered device from service should be lauded.
Actually, yes, you did. The absolute LARGEST capacity AAA NiMH cell I have seen available is 1350mAh, and that is unlikely to be a credible rating. Most are something in the 1000mAh range, and in particular the Eneloops. In my experience, the charge life of the lithium cells eclipses even alkaline AAA batteries, and the higher potential and current provide a bit brighter performance, without burning out the LEDs. 14500 lithium cells are also available in the 2000-2200mAh range.
I think you also missed something. He is replacing (3) batteries with (1). My Sanyo have a 800 ma rating so you times that times (3) batteries and you get an easy 2400ma. Alkaline have even higher rating so I get back to my original question. Why replace with a lower power and lower reserve battery??
You can't just add the mAh rating of 3 AAA cells together. Since the current is in series, the mAh rating would be no better than one cell. The best you can get from a single NiMh cell would be 600 to 800 mAh for a AAA cell. With a good quality 16500 lithium, you can get 600 to 900 mAh and have 4 volts to start with. So in terms of power, there is an advantage. The Ultrafire cell shown is probably one of the worst 16500's around with at best, 300 mAh of capacity. I only got it to try this little experiment out. With only dealing with one battery, its easier to change out the battery instead of messing with 3 cells in a holder.
14500 or 16500 ???
Oops, 14500 cells. My mistake. One thing I wish is that Instrucables would allow the author to make edits on their own posts.
Ah Ha-- The right answer! Thank You Sir.. Now it all makes sense to me...Forgot that series doesn't compound the ma!
While the 18650 won't fit most of these cheap lights, I really like using the 18500 size. They have a larger charge capacity, somewhere between the 14500 and 18650, but fit nicely inside. They are commonly available in four-packs for about $10, for use in solar pathway lights.
