This is my first Instructable for what I think is a brilliant idea, I'm only 14 and i can build it
WARNING: This will void warranty's and can shock you if you don't have your wits about you
NOTE: This Tutorial is littered with bad grammar and spelling mistakes. English Teachers may want to look away now
Your going to need:
Tape
Screw Driver
Computer PSU (I recommend 250W+)
PSU Cable
Wire Snaps
Soldering Iron
A 10ohm, 10W or greater power resistor (Some new power supply's don't work properly without some load so this can provide that)
Optional:
Switch
2 LEDs of any colour (Red and Green is the best)
If your using the leds you need a 1 or 2 330 OEM Resistor(s)
Heat Shrink Tubing
External Enclosure (Some people cram it all inside the Power supply case or you can put it in a external enclosure.)
These Depend on which method you use: (More on that later):
Terminal Blocks
Drill
LM317 or LM338K Voltage regulator
100nF Capacitors (ceramic or tantalum)
1uF Capacitors Electrolytic
1N4001 or 1N4002 Power Diode
120 Ohm resistor
5k Ohm variable resistor
Binding Posts
Crocodile Clips
Remove these ads by
Signing UpStep 1: Harvesting & Preping The Power Supply
BEFORE WE CONTINUE MAKE SURE YOUR POWER SUPPLY IS UNPLUGGED.
Capacitors can bite and if not give a painful shock kill you. Please discharge the power supply by letting it sit unconnected for a few days or connecting a 10ohm resistor between the red and black wires.
If you hear buzzing when you turn on the power supply it means there is a short or another serious problem. If you hear buzzing (that not coming from the soldering iron) when soldiering it mean your power supply is on. There is still power flowing through the PSU if it plugged in but not switched on
OK lets get straight into it remove the computer case and take out the screws (usually 4) at the back of the computer to release the power supply. Now take out the 4 screws on top of the case and take the wires out of the hole then group wires of the same colour together and snip off the ends.
Just To tell you , you've just void your warranty
Visit Our Store »
Go Pro Today »
Thank u
What do I do with them?
Any help would be great.
Thanks,
E
I've made a few supplies, +/-12V, +5V, +3.3V (No -5V.) out of the 200W supplies from a bunch of old Optiplex desktops.. usually use a 30-Ohm, 5W resistor across the +5. Been able to run gadget projects, Amateur Radio equipment, (with little to NO noise, surprisingly.) external hard drives, even charge Gel-Cell batteries from them.
It also depends on the condition of the supply... Brand New? Pulled from a working computer? or pulled from a failed computer? If the last, suspect even the supply may be bad, and NOT a good candidate for conversion. (See remark below I made to Coolinst, about the one that went up in smoke.)
There are some circuits for ( http://img.photobucket.com/albums/v472/n1np/local/manual_fan_controller.jpg for example) for manual control, but thermal control would require making a circuit that uses a thermal varister in place of the potentiometer... most of the time, I'd simply leave the noisy fan be, as it's doing its job, and unless noise is a problem (needing quiet for recording, etc.) it's not worth baking the supply, but slowing the fan.
Most supplies have a built-in speed control now, and the last few supplies I've converted, I replaced the straight-wired fan with a thermal circuit & fan (if it fits) from another supply I've scrapped.
I am putting one of these together and have come across something that I might be getting wrong....
In mocking up the LM317 circuit in breadboard, I have got the thing metering -11v to +11v??? I am using one of the black ground wires on the black side of the volt meter, but cant figure out why I am not just getting positive voltages??? Could the diode be faulty? Or is this in fact correct?
Any help appreciated...
The way you are measuring, it is correct.
reg set for max: meas +22var(actual +23)-->R1-->R2--> -12-->psu gnd= +11v
reg set for min: meas +22var(actual +1)-->R1-->R2--> -12-->psu gnd= -11v
0V has to become new gnd or (0V adj)
Brilliant instructable I am new in electronic engineering and wanted a lab power supply will you please tell me that how Can we connect a potetiometer(voltage regulator),rheostat, voltmeter and ammeter in atx power supply to calculate and vary voltage and current?
Thanks
http://www.antennex.com/preview/archive3/powers.htm
