Step 3Convert to MP3 & Tag
First, choose "add files" and select one file, or just drag a whole folder into the task list
Second, choose output location and name for the first file and click next
Third, choose encoding options. I'm using 128kbps constant bitrate at 44100Hz Joint Stereo... that should play on almost anything.
Fourth (optional), set your ID3 tags. You can do it here a file at a time, or if your doing full albums you can label them later with ID3-TagIT. If you're going to tag them later, You can tell the encoder to use the same settings for every file; otherwise, you'll have to confirm your settings and tag each file.
Fifth, click start, kick back, and wait.
comments
Add Comment
gschoppe (author)
says:
Add Comment
