Convert Your Pringles Cans to RTTTL Audio Player
Published
Introduction: Convert Your Pringles Cans to RTTTL Audio Player
About: Maker, PCB designer , electronics instructor from Jordan just one word ! I Adore electronics follow me on FB https://www.facebook.com/Mohannad-Rawashdeh-Raw-774983565988641/
hello everyone , in this tutorial I will show you how to build a RTTTL player ,and I will show you how to do that using Teensy 3.1 .
You can expand the number of the songs you want to add , and will show you how to do that later and give you a resources for more than 10K files.
first , let's talk a look for what we need :
  1. Teensy 3.1 MCU board.
  2. 8 ohm speaker
  3. Nokia 5110 PCD8544 LCD
  4. Button * 2 pcs
  5. potentiometer
  6. jumpers(female-male and male-male)
  7. resistor 2.2K
  8. mini breadboard
  9. DC power jack 2.1mm.
  10. drill.
  11. Something to hold everything inside , I used Pringles can as the only choice I had
Step 1: Second : Let's Take a Look at Teensy
The Teensy is a complete USB-based microcontroller development system, in a very small footprint, and run on a 32 bit ARM M4 MCU , and can run on a frequency up to 96MHz.
the size of the Flash Memory is 256K , 64K of RAM and 34 GPIO , that's make it the best choice for such a project, I will add more audio files and draw more complex GUI later "and you can do as well"
if you didn't use it before , you can take a look to see the specification of the board and fromhereto see how to program it using arduino IDE.
Step 2: Prepare Your Hardware
First , You need to allocate where you want to put the LCD , Speaker , Button and potentiometer , since it will be shown outside , I started with the Speaker Hole , and as you can see i opened 2 holes because i tried to add 2 speakers to the device , but i missed the other Speaker .
Then on the side , I opened a hole to the LCD , just to be smaller compared to the LCD , and as you can see it's ugly , but it works.
then I prepared the Buttons , I soldered them, then I drilled a hole suitable to the button's dimension "install it from inside" , I used the hot silicon to stick it.
the potentiometer will control the LCD back-light , I used a value of 5K ohm potentiometer, and I installed it behind the LCD.
and the final photo will show you how it will look likes , yes not pretty but it works fine for me
Step 3: Test the Speaker ... With RTTTL Library
it's good to test everything before install it , I tested the Speaker using RTTTL library code , you can download it from the attachment below.
For protection , I recommend you to use amplifier , since Teensy can't provide you enough current to power the Speaker.
I used the Amplifier module LM386, and the schematic shows how to connect the speaker to the amplifier module and to pin8 on teensy
you can test your connection by upload this code " you can find it on the attachment"
<p>//Simple Tone Generator arduino<br>//Mohannad Rawashdeh
//http://www.genotronex.com/
//this code under Licence CC by-nc-sa
//http://creativecommons.org/licenses/by-nc-sa/4.0/
// this code works with Teensy 3.1/3.2 boards
//#include  //the external Tone library is used
#include </p><p>const int pinSpeaker = 8;
const int octave = 0;</p><p>const char Barbie[] PROGMEM ="Barbie girl:d=4,o=5,b=125:8g#,8e,8g#,8c#6,a,p,8f#,8d#,8f#,8b,g#,8f#,8e,p,8e,8c#,f#,c#,p,8f#,8e,g#,f#";
const char Indiana[] PROGMEM ="Indiana:d=4,o=5,b=250:e,8p,8f,8g,8p,1c6,8p.,d,8p,8e,1f,p.,g,8p,8a,8b,8p,1f6,p,a,8p,8b,2c6,2d6,2e6,e,8p,8f,8g,8p,1c6,p,d6,8p,8e6,1f.6,g,8p,8g,e.6,8p,d6,8p,8g,e.6,8p,d6,8p,8g,f.6,8p,e6,8p,8d6,2c6";
const char Coca_cola[] PROGMEM ="Coca-cola:d=4,o=5,b=125:8f#6,8f#6,8f#6,8f#6,g6,8f#6,e6,8e6,8a6,f#6,d6,2p";
const char KnightRider[] PROGMEM ="KnightRider:d=4,o=5,b=125:16e,16p,16f,16e,16e,16p,16e,16e,16f,16e,16e,16e,16d#,16e,16e,16e,16e,16p,16f,16e,16e,16p,16f,16e,16f,16e,16e,16e,16d#,16e,16e,16e,16d,16p,16e,16d,16d,16p,16e,16d,16e,16d,16d,16d,16c,16d,16d,16d,16d,16p,16e,16d,16d,16p,16e,16d,16e,16d,16d,16d,16c,16d,16d,16d";
const char PinkPanther[] PROGMEM ="PinkPanther:d=4,o=5,b=160:8d#,8e,2p,8f#,8g,2p,8d#,8e,16p,8f#,8g,16p,8c6,8b,16p,8d#,8e,16p,8b,2a#,2p,16a,16g,16e,16d,2e";
const char final_countdown[] PROGMEM ="The final countdown: :d=4,o=5,b=125:p,8p,16b,16a,b,e,p,8p,16c6,16b,8c6,8b,a,p,8p,16c6,16b,c6,e,p,8p,16a,16g,8a,8g,8f#,8a,g.,16f#,16g,a.,16g,16a,8b,8a,8g,8f#,e,c6,2b.,16b,16c6,16b,16a,1b ";
const char ScoobyDoo[] PROGMEM ="ScoobyDoo:d=4,o=5,b=160:8e6,8e6,8d6,8d6,2c6,8d6,e6,2a,8a,b,g,e6,8d6,c6,8d6,2e6,p,8e6,8e6,8d6,8d6,2c6,8d6,f6,2a,8a,b,g,e6,8d6,2c6";
const char Song1[] PROGMEM ="Song1:d=4,o=5,b=100:2p,8p,16f#6,16f#6,16f#6,16e6,16d6,16c#6,b,8f#6,e6,16e6,16e6,16e6,16d6,16c#6,16b,a,8f#6,d6,16f#6,16f#6,16f#6,16e6,16d6,16c#6,b,8f#6,e6,8d6,8c#6,2d6";
const char Mario[] PROGMEM ="smb:d=4,o=5,b=100:16e6,16e6,32p,8e6,16c6,8e6,8g6,8p,8g,8p,8c6,16p,8g,16p,8e,16p,8a,8b,16a#,8a,16g.,16e6,16g6,8a6,16f6,8g6,8e6,16c6,16d6,8b,16p,8c6,16p,8g,16p,8e,16p,8a,8b,16a#,8a,16g.,16e6,16g6,8a6,16f6,8g6,8e6,16c6,16d6,8b,8p,16g6,16f#6,16f6,16d#6,16p,16e6,16p,16g#,16a,16c6,16p,16a,16c6,16d6,8p,16g6,16f#6,16f6,16d#6,16p,16e6,16p,16c7,16p,16c7,16c7,p,16g6,16f#6,16f6,16d#6,16p,16e6,16p,16g#,16a,16c6,16p,16a,16c6,16d6,8p,16d#6,8p,16d6,8p,16c6";
const char StarWar[] PROGMEM ="MainThem:d=4,o=5,b=100:8a#6,8a#6,16p,8f#7,8f#7,16p,16d#7,16p,16d#7,16p,16c#7,16p,8a#7,16p,8f#7,16p,16d#7,16p,16d#7,16p,16c#7,16p,8a#7,8a#7,8p,16p,16d#7,16p,16d#7,16p,16d#7,16p,8c#7,8c#7";</p><p>Rtttl player;</p><p>void setup(void)
	player.begin(pinSpeaker);
        player.play_P(StarWar, octave);
        delay(2000);
	player.play_P(Barbie, octave);
        delay(1000);
        player.play_P(Indiana, octave);
        delay(1000);
	player.play_P(Coca_cola, octave);
        delay(1000);
	player.play_P(KnightRider, octave);
        delay(1000);
	player.play_P(PinkPanther, octave);
        delay(1000);
	player.play_P(final_countdown, octave);
        delay(1000);
	player.play_P(ScoobyDoo, octave);
        delay(1000);
        player.play_P(Song1, octave);
        delay(1000);
}</p><p>void loop(void)
}</p>
Step 4: Test the LCD ... Without Library !
For the LCD , you can use Adafruit GFX library to control this LCD , but i went with an old code I have without a library , here the connection for this LCD , please be careful to the LCD power supply , use external Source to power the LCD, I connect it here to Vin pin which can give you 5V from USB .
this code to test your connection .
<p>/**************************************************<br> * Nokia LCD Test
 * Kyle Kuepker
 * 18 February 2011
 * This code modified By Mohannad Rawashdeh - Jordan
 for  http://genotronex.com/
 Describe how to connect LCD Nokia 5110 with arduino .
 modified to work with teensy 3.1/3.2
 modified by : Mohannad Rawashdeh
#define LCD_CMD 0
#define PIN_SCE   4
#define PIN_RESET 3
#define PIN_DC    5
#define PIN_SDIN  11
#define PIN_SCLK  13</p><p>#define LCD_C     LOW
#define LCD_D     HIGH</p><p>#define LCD_X     84
#define LCD_Y     48</p><p>static const byte ASCII[][5] ={
 {0x00, 0x00, 0x00, 0x00, 0x00} // 20
,{0x00, 0x00, 0x5f, 0x00, 0x00} // 21 !
,{0x00, 0x07, 0x00, 0x07, 0x00} // 22 "
,{0x14, 0x7f, 0x14, 0x7f, 0x14} // 23 #
,{0x24, 0x2a, 0x7f, 0x2a, 0x12} // 24 $
,{0x23, 0x13, 0x08, 0x64, 0x62} // 25 %
,{0x36, 0x49, 0x55, 0x22, 0x50} // 26 &
,{0x00, 0x05, 0x03, 0x00, 0x00} // 27 '
,{0x00, 0x1c, 0x22, 0x41, 0x00} // 28 (
,{0x00, 0x41, 0x22, 0x1c, 0x00} // 29 )
,{0x14, 0x08, 0x3e, 0x08, 0x14} // 2a *
,{0x08, 0x08, 0x3e, 0x08, 0x08} // 2b +
,{0x00, 0x50, 0x30, 0x00, 0x00} // 2c ,
,{0x08, 0x08, 0x08, 0x08, 0x08} // 2d -
,{0x00, 0x60, 0x60, 0x00, 0x00} // 2e .
,{0x20, 0x10, 0x08, 0x04, 0x02} // 2f /
,{0x3e, 0x51, 0x49, 0x45, 0x3e} // 30 0
,{0x00, 0x42, 0x7f, 0x40, 0x00} // 31 1
,{0x42, 0x61, 0x51, 0x49, 0x46} // 32 2
,{0x21, 0x41, 0x45, 0x4b, 0x31} // 33 3
,{0x18, 0x14, 0x12, 0x7f, 0x10} // 34 4
,{0x27, 0x45, 0x45, 0x45, 0x39} // 35 5
,{0x3c, 0x4a, 0x49, 0x49, 0x30} // 36 6
,{0x01, 0x71, 0x09, 0x05, 0x03} // 37 7
,{0x36, 0x49, 0x49, 0x49, 0x36} // 38 8
,{0x06, 0x49, 0x49, 0x29, 0x1e} // 39 9
,{0x00, 0x36, 0x36, 0x00, 0x00} // 3a :
,{0x00, 0x56, 0x36, 0x00, 0x00} // 3b ;
,{0x08, 0x14, 0x22, 0x41, 0x00} // 3c <
,{0x14, 0x14, 0x14, 0x14, 0x14} // 3d =
,{0x00, 0x41, 0x22, 0x14, 0x08} // 3e >
,{0x02, 0x01, 0x51, 0x09, 0x06} // 3f ?
,{0x32, 0x49, 0x79, 0x41, 0x3e} // 40 @
,{0x7e, 0x11, 0x11, 0x11, 0x7e} // 41 A
,{0x7f, 0x49, 0x49, 0x49, 0x36} // 42 B
,{0x3e, 0x41, 0x41, 0x41, 0x22} // 43 C
,{0x7f, 0x41, 0x41, 0x22, 0x1c} // 44 D
,{0x7f, 0x49, 0x49, 0x49, 0x41} // 45 E
,{0x7f, 0x09, 0x09, 0x09, 0x01} // 46 F
,{0x3e, 0x41, 0x49, 0x49, 0x7a} // 47 G
,{0x7f, 0x08, 0x08, 0x08, 0x7f} // 48 H
,{0x00, 0x41, 0x7f, 0x41, 0x00} // 49 I
,{0x20, 0x40, 0x41, 0x3f, 0x01} // 4a J
,{0x7f, 0x08, 0x14, 0x22, 0x41} // 4b K
,{0x7f, 0x40, 0x40, 0x40, 0x40} // 4c L
,{0x7f, 0x02, 0x0c, 0x02, 0x7f} // 4d M
,{0x7f, 0x04, 0x08, 0x10, 0x7f} // 4e N
,{0x3e, 0x41, 0x41, 0x41, 0x3e} // 4f O
,{0x7f, 0x09, 0x09, 0x09, 0x06} // 50 P
,{0x3e, 0x41, 0x51, 0x21, 0x5e} // 51 Q
,{0x7f, 0x09, 0x19, 0x29, 0x46} // 52 R
,{0x46, 0x49, 0x49, 0x49, 0x31} // 53 S
,{0x01, 0x01, 0x7f, 0x01, 0x01} // 54 T
,{0x3f, 0x40, 0x40, 0x40, 0x3f} // 55 U
,{0x1f, 0x20, 0x40, 0x20, 0x1f} // 56 V
,{0x3f, 0x40, 0x38, 0x40, 0x3f} // 57 W
,{0x63, 0x14, 0x08, 0x14, 0x63} // 58 X
,{0x07, 0x08, 0x70, 0x08, 0x07} // 59 Y
,{0x61, 0x51, 0x49, 0x45, 0x43} // 5a Z
,{0x00, 0x7f, 0x41, 0x41, 0x00} // 5b [
,{0x02, 0x04, 0x08, 0x10, 0x20} // 5c ¥
,{0x00, 0x41, 0x41, 0x7f, 0x00} // 5d ]
,{0x04, 0x02, 0x01, 0x02, 0x04} // 5e ^
,{0x40, 0x40, 0x40, 0x40, 0x40} // 5f _
,{0x00, 0x01, 0x02, 0x04, 0x00} // 60 `
,{0x20, 0x54, 0x54, 0x54, 0x78} // 61 a
,{0x7f, 0x48, 0x44, 0x44, 0x38} // 62 b
,{0x38, 0x44, 0x44, 0x44, 0x20} // 63 c
,{0x38, 0x44, 0x44, 0x48, 0x7f} // 64 d
,{0x38, 0x54, 0x54, 0x54, 0x18} // 65 e
,{0x08, 0x7e, 0x09, 0x01, 0x02} // 66 f
,{0x0c, 0x52, 0x52, 0x52, 0x3e} // 67 g
,{0x7f, 0x08, 0x04, 0x04, 0x78} // 68 h
,{0x00, 0x44, 0x7d, 0x40, 0x00} // 69 i
,{0x20, 0x40, 0x44, 0x3d, 0x00} // 6a j
,{0x7f, 0x10, 0x28, 0x44, 0x00} // 6b k
,{0x00, 0x41, 0x7f, 0x40, 0x00} // 6c l
,{0x7c, 0x04, 0x18, 0x04, 0x78} // 6d m
,{0x7c, 0x08, 0x04, 0x04, 0x78} // 6e n
,{0x38, 0x44, 0x44, 0x44, 0x38} // 6f o
,{0x7c, 0x14, 0x14, 0x14, 0x08} // 70 p
,{0x08, 0x14, 0x14, 0x18, 0x7c} // 71 q
,{0x7c, 0x08, 0x04, 0x04, 0x08} // 72 r
,{0x48, 0x54, 0x54, 0x54, 0x20} // 73 s
,{0x04, 0x3f, 0x44, 0x40, 0x20} // 74 t
,{0x3c, 0x40, 0x40, 0x20, 0x7c} // 75 u
,{0x1c, 0x20, 0x40, 0x20, 0x1c} // 76 v
,{0x3c, 0x40, 0x30, 0x40, 0x3c} // 77 w
,{0x44, 0x28, 0x10, 0x28, 0x44} // 78 x
,{0x0c, 0x50, 0x50, 0x50, 0x3c} // 79 y
,{0x44, 0x64, 0x54, 0x4c, 0x44} // 7a z
,{0x00, 0x08, 0x36, 0x41, 0x00} // 7b {
,{0x00, 0x00, 0x7f, 0x00, 0x00} // 7c |
,{0x00, 0x41, 0x36, 0x08, 0x00} // 7d }
,{0x10, 0x08, 0x08, 0x10, 0x08} // 7e ←
,{0x78, 0x46, 0x41, 0x46, 0x78} // 7f →
};</p><p>char arduino [] = {
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xC0, 0xE0, 0xF0, 0xF8, 0x78, 0x3C, 0x1C,
0x1C, 0x1C, 0x1C, 0x1C, 0x1C, 0x1C, 0x3C, 0x38, 0x78, 0xF0, 0xF0, 0xE0, 0xC0, 0x00, 0x00, 0x80,
0xC0, 0xE0, 0xF0, 0x78, 0x38, 0x3C, 0x1C, 0x1C, 0x1C, 0x1C, 0x1C, 0x1C, 0x1C, 0x3C, 0x38, 0x78,
0xF0, 0xE0, 0xC0, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFF, 0xFF, 0xFF, 0x81,
0x00, 0x00, 0x00, 0x00, 0x18, 0x18, 0x18, 0x18, 0x18, 0x18, 0x00, 0x00, 0x00, 0x00, 0x81, 0xE7,
0xFF, 0xFF, 0xFF, 0xFF, 0xE7, 0xC1, 0x00, 0x00, 0x00, 0x00, 0x18, 0x18, 0x18, 0x7E, 0x18, 0x18,
0x00, 0x00, 0x00, 0x00, 0x81, 0xFF, 0xFF, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x03, 0x07, 0x0F, 0x1F, 0x1E, 0x3C, 0x3C, 0x38, 0x38, 0x38, 0x38, 0x38, 0x38, 0x3C, 0x1E,
0x1E, 0x0F, 0x07, 0x03, 0x01, 0x00, 0x00, 0x01, 0x03, 0x07, 0x0F, 0x1E, 0x1E, 0x3C, 0x3C, 0x38,
0x38, 0x38, 0x38, 0x38, 0x38, 0x3C, 0x1E, 0x1F, 0x0F, 0x07, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xF8, 0x4C, 0x44, 0x4C, 0xF8, 0x00, 0xFC, 0x24, 0x74, 0x98,
0x00, 0x00, 0xFC, 0x84, 0x84, 0x78, 0x00, 0x00, 0xFC, 0x80, 0x80, 0xFC, 0x00, 0x00, 0x84, 0x84,
0xFC, 0x84, 0x84, 0x00, 0xFC, 0x1C, 0x30, 0x60, 0xFC, 0x00, 0x00, 0xFC, 0x84, 0x84, 0xFC, 0x00,
};</p><p>char LOGO [] = {
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0xC0, 0xC0, 0xE0, 0xE0, 0xFC,
0xFE, 0xFE, 0xFF, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x88, 0x88, 0x8C, 0xFF, 0xFF, 0xFE, 0xFE, 0xFC,
0xE0, 0xE0, 0xC0, 0x80, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xC0, 0xF0, 0xF8, 0x7E, 0xFF, 0xFF, 0xE7,
0xC3, 0x01, 0x00, 0x01, 0x03, 0x03, 0x07, 0x07, 0x80, 0x80, 0xC0, 0xC0, 0xC0, 0x80, 0x81, 0x07,
0x07, 0x03, 0x03, 0x01, 0x00, 0x01, 0xC3, 0xE7, 0xFF, 0xFF, 0x7E, 0xF8, 0xF0, 0xC0, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0xFC, 0xFF, 0x7F, 0x07, 0x00,
0x00, 0x01, 0x07, 0x1F, 0x7F, 0xFF, 0xFE, 0xF8, 0xE0, 0xC0, 0x00, 0x1E, 0x7F, 0x7F, 0xFF, 0xFF,
0xFF, 0x7F, 0x7F, 0x1E, 0x80, 0xC0, 0xF0, 0xF8, 0xFE, 0xFF, 0x7F, 0x1F, 0x07, 0x01, 0x00, 0x00,
0x07, 0x7F, 0xFF, 0xFC, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1F, 0xFF,
0xFF, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x07, 0x3F, 0xFF, 0xFF, 0xFF, 0xFE,
0xFE, 0xFC, 0xFC, 0xFC, 0xFC, 0xFC, 0xFE, 0xFF, 0xFF, 0xFF, 0xFF, 0x3F, 0x07, 0x01, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0xC0, 0xFF, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x03, 0x1F, 0x7F, 0xFC, 0xF0, 0xC0, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x01, 0x7F, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x3F, 0x01, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xC0, 0xF0, 0xFC, 0x7F, 0x1F, 0x03, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x03, 0x07, 0x0F, 0x1E, 0x3C,
0x78, 0x78, 0x70, 0x60, 0x60, 0x40, 0x4F, 0x4F, 0x5F, 0x1F, 0x1F, 0x1F, 0x1F, 0x1F, 0x5F, 0x4F,
0x4F, 0x40, 0x60, 0x60, 0x70, 0x78, 0x78, 0x3C, 0x1E, 0x0F, 0x07, 0x03, 0x01, 0x00, 0x00, 0x00,
};</p><p>void gotoXY(int x, int y)
  LcdWrite( 0, 0x80 | x);  // Column.
  LcdWrite( 0, 0x40 | y);  // Row.  ?</p><p>}
void LcdBmp(char my_array[])
  for (int index = 0; index < 504; index++)
    LcdWrite(LCD_D, my_array[index]);
}</p><p>void LcdCharacter(char character)
  LcdWrite(LCD_D, 0x00);
  for (int index = 0; index < 5; index++)
    LcdWrite(LCD_D, ASCII [character - 0x20][index]);
void LcdString(char *characters)
  while (*characters)
    LcdCharacter(*characters++);
}</p><p>void LcdClear(void)
  for (int index = 0; index < LCD_X * LCD_Y / 8; index++)
}</p><p>void LcdInitialise(void)
  pinMode(PIN_SCE, OUTPUT);
  pinMode(PIN_RESET, OUTPUT);
  pinMode(PIN_DC, OUTPUT);
  pinMode(PIN_SDIN, OUTPUT);
  pinMode(PIN_SCLK, OUTPUT);
  digitalWrite(PIN_RESET, LOW);
  digitalWrite(PIN_RESET, HIGH);
  LcdWrite(LCD_C, 0x20);
  LcdWrite(LCD_C, 0x0C);
  LcdWrite( LCD_CMD, 0x21 ); // LCD Extended Commands.
  LcdWrite( LCD_CMD, 0xAF ); // Set LCD Vop (Contrast). //B1
  LcdWrite( LCD_CMD, 0x04 ); // Set Temp coefficent. //0x04
  LcdWrite( LCD_CMD, 0x14 ); // LCD bias mode 1:48. //0x13
  LcdWrite( LCD_CMD, 0x0C ); // LCD in normal mode. 0x0d for inverse
}</p><p>void LcdWrite(byte dc, byte data)
  digitalWrite(PIN_DC, dc);
  digitalWrite(PIN_SCE, LOW);
  shiftOut(PIN_SDIN, PIN_SCLK, MSBFIRST, data);
  digitalWrite(PIN_SCE, HIGH);
}</p><p>void setup(void)
  LcdInitialise();
  LcdClear();
  LcdInitialise();
  //LcdInitialise();
  LcdClear();
  LcdBmp(arduino);
  delay(2000);
  LcdClear();
  LcdBmp(LOGO);
  delay(2000);
  LcdClear();
  LcdString("Teensy 3.1");
  delay(2000);
  LcdString("  ");
  delay(2000);
  LcdClear();
  LcdString("Mohannad Rawashdeh");
  delay(1000);
  LcdClear();
}</p>
Step 5: Connect the Buttons and LEDs
for the buttons , I connect one to pin 19 and the other to pin 20 , for the LED , be careful to select a suitable resistor to not damage the teensy board , i selected 2.2K ohm .
No need for pull-up resistor with the buttons , I activated them on the software.
well the final shape is not that perfect , but it works , so you need to connect everything correctly because any mistake might be fatal !
Step 6: Upload the Final Code !
after you check everything , we will upload the code to the teensy and see the results.
for the power input , if you want to use the DC jack as i did , connect the positive pin Vin on teensy.
You can see the results from the video .
<p>/**************************************************<br> * mb-raw.blogspot.com
 * written by: Mohannad Rawashdeh/july 2017
 #include
#define LCD_CMD 0
#define PIN_SCE   4
#define PIN_RESET 3
#define PIN_DC    5
#define PIN_SDIN  11
#define PIN_SCLK  13
#define Button1pin 19
#define Button2pin 20
#define LED1pin 17
#define LED2pin 16</p><p>#define LCD_C     LOW
#define LCD_Y     48</p><p>// Audio variables here
//song
const char ItsTheWa[] PROGMEM ="ItsTheWa:d=16,o=6,b=125:c#,p,c#,p,c#,p,c#,p,c#,p,8c#,8c,4c,g#5,p,g#5,p,g#5,p,g#5,p,8g#5,a#5,p,2a#5,8c#,8c#,8d#,8c#,c,p,1c,c,4c#,4c#,c#,p,c#,p,c#,p,8c#,c,p,2c,c,p,c,p,c,p,8c,a#5,p,2a#.5,8a#5,8c,4c#,8c,4g#5,4a#5,4a#5,1g#5,g#5";
const char StudioSport[] PROGMEM ="Theme:d=4,o=6,b=125:8c.,16c,16c5,16p,8c,16c5,16p,16c,16g5,16c,16e,16c,16g5,16c5,16p,8p,16c5,16p,8p,16c5,16p,8p,16c5,16g5,16a5,16c,8c.,16c,16f5,16p,8c,16f5,16p,16c,16g5,16c,16e,16c,16g5,16c5,16p,8p,16c5,16p,8p,16c5,16p,8p,16c5,16p,8p,8g_.5,16f_5,16g_5,8c,16d_,16p,8f,g_,16p,8g.5,16f5,16g5,8b5,16d,16p,8f,2g,8g.5,16a_5,8p,2c,8p,c";
const char SpiceGirlWannabe[] PROGMEM ="WannaBe:d=16,o=5,b=125:g,g,g,g,8g,8a,8g,8e,8p,c,d,c,8d,8d,8c,4e,4p,8g,8g,8g,8a,8g,8e,8p,4c6,8c6,8b,8g,8a,b,a,4g";
const char MyCultur[] PROGMEM ="MyCultur:d=8,o=7,b=90:g6,g6,4c,4f,g.,4e,1p,4c6,1c6,1c6,c6,d6,e6,g6,g6,4c,4f,g.,e.,1f,e,1d,c.,1c,1p,1b6,1p,1a#6,1p,1f6,g6,g6,4c,4f,g.,4e,1p,c.6,1c6,1p,1c6,c6,d6,e6,g6,g6,4c,4f,g.,e.,1f,e,1d,c";
const char CDionAlive[] PROGMEM ="I'mAlive:d=4,o=6,b=100:8d_5,8f5,g.5,8d_5,1d_5,p,8d_5,8f5,g.5,8d_5,8d_5,16p,8d_5,8a_5,a_.5,8d_5,d_.5,8f5,g.5,f.5,8g5,8d_5,2d_.5,8d_5,8f5,g.5,8d_5,1d_5,p,8d_5,8f5,g.5,8d_5,8d_5,16f5,1g5,16p,8d_5,8a_5,a_.5,8d_5,d_.5,8f5,g.5,f.5,8g5,8d_5,2d_.5";</p><p>Rtttl player;</p><p>int rttl_Counter=1;
const int MaxSong=14;
boolean Button1select=true;
boolean Button2scroll=true;</p><p>IntervalTimer ButtonISR1;
IntervalTimer ButtonISR2;</p><p>static const byte ASCII[][5] ={
};</p><p>char audio [] = {
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFE,
0xFE, 0xFC, 0xFC, 0xFC, 0xF8, 0xF8, 0xF8, 0xF0, 0xF0, 0xE0, 0xE0, 0x80, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80,
0x60, 0x30, 0x08, 0x08, 0x08, 0x04, 0x84, 0x44, 0x08, 0x08, 0x08, 0x10, 0x60, 0x80, 0x00, 0x00,
0x00, 0x00, 0x00, 0xFF, 0xFF, 0xFF, 0x00, 0x00, 0x01, 0x01, 0x01, 0x03, 0x03, 0x03, 0x07, 0x07,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x60,
0x10, 0x08, 0x08, 0x08, 0x44, 0x84, 0x04, 0x04, 0x08, 0x08, 0x10, 0x60, 0x80, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x07, 0x18, 0x20, 0x40, 0x40, 0x80, 0x83, 0x84, 0x88, 0x80, 0x40, 0x40, 0x20,
0x18, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0xF0, 0xF8, 0xF8, 0xFC, 0xFC, 0xFC, 0xFC, 0xFF, 0xFF, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x07, 0x18, 0x20, 0x40, 0x40, 0x80, 0x88, 0x84, 0x83, 0x80, 0x40, 0x40, 0x30, 0x18,
0x07, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x01, 0x03, 0x03, 0x03, 0x03, 0x03, 0x01, 0x00, 0x00, 0x00,
};</p><p>char Play [] = {
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xC0, 0xC0, 0xE0, 0xF0, 0x70, 0x78, 0x38, 0x1C, 0x1C,
0x1C, 0x1C, 0x1C, 0x1C, 0x1C, 0x1C, 0x1C, 0x38, 0x78, 0x70, 0xF0, 0xE0, 0xC0, 0xC0, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xF0, 0xFE, 0xFF, 0x1F, 0x03, 0x01, 0x00, 0x00,
0x00, 0x00, 0x00, 0xFC, 0xFC, 0xF8, 0xF0, 0xF0, 0xC0, 0xC0, 0x80, 0x00, 0x00, 0x00, 0x00, 0x01,
0x03, 0x1F, 0xFF, 0xFC, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1F, 0xFF, 0xFF, 0xE0,
0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7F, 0x7F, 0x7F, 0x3F, 0x1F, 0x0F, 0x0F, 0x07, 0x03,
0x00, 0x00, 0x00, 0x00, 0x80, 0xE0, 0xFF, 0xFF, 0x1F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x01, 0x07, 0x0F, 0x1F, 0x1C, 0x3C, 0x38, 0x70, 0x70, 0x70, 0x70, 0x70, 0x70, 0x70,
0x70, 0x70, 0x70, 0x70, 0x38, 0x3C, 0x1C, 0x1F, 0x07, 0x07, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00,
};</p><p>char Pause [] = {
0x00, 0x00, 0x00, 0x00, 0xC0, 0xE0, 0xF0, 0x78, 0x38, 0x1C, 0x1C, 0x0E, 0x0E, 0x06, 0x06, 0x07,
0x07, 0x07, 0x06, 0x06, 0x0E, 0x0C, 0x1C, 0x1C, 0x38, 0x70, 0xF0, 0xE0, 0x80, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0xC0, 0xFC, 0xFF, 0x0F, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0xFC, 0xFC, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFC, 0xFC, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
0x1F, 0xFF, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x0F, 0x7F, 0xF8, 0xE0, 0x80, 0x00,
0x00, 0x00, 0x00, 0x00, 0x1F, 0x1F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1F, 0x1F, 0x00, 0x00, 0x00,
0x00, 0x00, 0x80, 0xF0, 0xFC, 0x7F, 0x0F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x03, 0x07, 0x07, 0x0E, 0x1C, 0x1C, 0x18, 0x38, 0x38, 0x30, 0x30, 0x30, 0x30, 0x30, 0x38,
0x38, 0x1C, 0x1C, 0x1C, 0x0E, 0x07, 0x07, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  while (*characters)
}</p><p>void HelloMessage()
 LcdClear();
  gotoXY(0,0);
  LcdString("RTTL Player ");
  gotoXY(0,10);
  LcdString("using Teensy ");
  gotoXY(0,20);
  LcdString("Use Buttons ");
  gotoXY(0,30);
  LcdString("To select ");
  gotoXY(0,40);
  LcdString("the Tone ");
void setup(void)
  LcdInitialise();
  LcdClear();
  pinMode(LED1pin, OUTPUT);
  pinMode(LED2pin, OUTPUT);
  pinMode(Button1pin, INPUT_PULLUP);
  pinMode(Button2pin, INPUT_PULLUP);
  ButtonISR1.begin(button1LED, 10);  // blinkLED to run every 100 mseconds
  ButtonISR2.begin(button2LED, 10);  // blinkLED to run every 100 mseconds</p><p>  HelloMessage();
  delay(1000);
  rttl_Counter=1;</p><p>}</p><p>void loop(void)
  gotoXY(0,0);
  LcdBmp(audio);
  updateSongScreen(rttl_Counter);
  delay(500);
  while(Button1select==true)
  delay(50);
  if(Button2scroll==false)
    rttl_Counter++;
    //update the song
    if(rttl_Counter>MaxSong){rttl_Counter=1;}
    delay(100);
  delay(200);
  LcdClear();
  gotoXY(0,0);
  //LcdBmp(Play);
  LcdBmp(Pause);
  updateSong(rttl_Counter);
    delay(10);
  noTone(pinSpeaker);
  delay(500);
  LcdClear();
}</p><p>void button1LED(void)
Button1select=digitalRead(Button1pin);
digitalWrite(LED1pin,Button1select);
}</p><p>void button2LED(void)
 Button2scroll=digitalRead(Button2pin);
 digitalWrite(LED2pin,Button2scroll);
}</p><p>void updateSongScreen(int counter)
    LcdClear();
    gotoXY(0,0);
    LcdBmp(audio);
    if(counter==1)
    LcdString("Barbie 001");
    if(counter==2)
    LcdString("Indiana 002");
    if(counter==3)
    LcdString("Cocacola 003");
    if(counter==4)
    LcdString("K.Rider 004");
   if(counter==5)
    LcdString("pink.p 005");
   if(counter==6)
    LcdString("Final.C 006");
   if(counter==7)
    LcdString("ScoobyDoo007");
   if(counter==8)
    LcdString("ItsTheWa008");
   if(counter==9)
    LcdString("Mario 009");
   if(counter==10)
    LcdString("StarWar 010");
   if(counter==11)
    LcdString("St.Sport 011");
   if(counter==12)
    LcdString("Wannabe 012");
    if(counter==13)
    LcdString("MyCultur 013");
    if(counter==14)
    LcdString("CDionAlive 014");
}</p><p>void updateSong(int counter)
    if(counter==1)
    if(counter==2)
    if(counter==3)
    if(counter==4)
   if(counter==5)
   if(counter==6)
   if(counter==7)
   if(counter==8)
    player.play_P(ItsTheWa, octave);
   if(counter==9)
    player.play_P(Mario, octave);
   if(counter==10)
   if(counter==11)
    player.play_P(StudioSport, octave);
   if(counter==12)
    player.play_P(SpiceGirlWannabe, octave);
    if(counter==13)
    player.play_P(MyCultur, octave);
    if(counter==14)
    player.play_P(CDionAlive, octave);
}</p>
Step 7: One Million Dollar Question : How to Add New RTTTL Files ?
OK this is a good question , and I will show you now how to do that.
first: you need to find a resources for RTTTL files , on the attachment I put a folder with more than 10k track , you can check them out, and here some links to online resources:
1- Online Link 1
2- Online Link 2
Each file consist of the RTTTL array , it looks like:
Funeral(:d=4,o=5,b=100:c.,c,8c,c.,d#,8d,d,8c,c,8c,2c.
second: create an array on the code , for example I will call it Fun
const char Fun[ ] PROGMEM ="Funeral(:d=4,o=5,b=100:c.,c,8c,c.,d#,8d,d,8c,c,8c,2c.";
third : you need to change the value of MaxSong variable "on line 46" depend on the number of melodies you have .
Fourth: go to void updateSongScreen(int counter) function (Line 407) and add a new if condition, like this
if(counter==15)
{ LcdString("Fun 015"); }
this will update the name of the song each time you scroll "change" the track.
Fifth: add the name of the song and play the melody , go to void updateSong(int counter) (line 470) and add your melody like this:
if(counter==15)
{ LcdString("Indiana 015"); player.play_P(Fun, octave); }
hope with this simple instruction you will be able to add any melody you want
Thank you
    • Woodworking Contest
      Woodworking Contest
    • Make it Move Contest
    • Planter Challenge
      Planter Challenge
