Introduction: Convert Your Wall Into Magnetic Dashboard
If You like to paint or if You hava kids who like to paint, then You can make blackboard on the wall. Not only blackboard, but magnetic one. It's simple and easy. If You can paint, You can probably paint the walls and this is all You need for this project ;-)
Step 1: Preparations
Picture of Preparations
If You have drywall in Your room or very fine plaster, You can skip this step. However if You have rough, bumpy wall with cracks, You have to make it smoother. I recommend to use gypsum putty because it is easy to apply it.
First put the putty on the wall, two layers at least, then after it will dry, use sandpaper to make it perfectly smooth. Now You are ready for making the magnetic blackboard.
Step 2: Blackboard
Picture of Blackboard
You need two type of paints to make the magnetic board:
- magnetic undercoat paint
- blackboard paint
Both paints You can buy in the stores. They are however pretty expensive (in comparison to standard paint) so it could be hard to buy them. Moreover You have to put at least 3 layers of them (especially magnetic paint) to have a good results.
Paints should be layed on the wall using painting roll. Do not use the brush-it won't give smooth surface.
Step 3: Painting on the Wall
Picture of Painting on the Wall
After last layer of paint is dried, You are ready to use Your board as blackboard. You can not only paint on it with chalk, but also You can clean it with sponge and water. Nothing bad will happened.
That's all. Isn't this an easy task, as I said in the bigginning ?
mrsmerwin (author)2017-07-27
We made one of these years ago for the kids play room. You make me want one of my own--that I don't have to let my teenagers use.
About This Instructable
413views
13favorites
License:
Bio: I love to make DIY projects with my son
More by woodenProjects:Natural Curtain Rods Made From Branches. How to Make and How to Hang.Cool Garden Lamp From Reclaimed Cracked Wood LogAntique Restoration Is Mostly Easy (brass Tepot to Mirror)
Add instructable to:
