3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Convert a 300 Watt Torchiere Lamp into a Dual 20 Watt CFL
Step 12Dual bulbs
Dual bulbs
I used wire nuts and short pieces of scrap wire to hook up the dual sockets. Be sure to wire them in parallel and not series. If you don't know, you shouldn't be wiring up lamps.
10 comments
Dec 21, 2011. 11:30 PMSIRJAMES09 says:
I think some people need to give it a rest.
In short, if you do not know what the heck you are doing, DO NOT DO IT!
The guy is putting safety first like a responsible adult SHOULD.
To explain the difference between series & parallel, one has to start from the begining of electrical technology & progress from there.
In English, that means that when you first started going to school at the age of about 5 or 6 yrs old, you went to kindergarden or 1st grade, not Yale college.
I support the author & how he has written this. He is trying to cover your butt so to speak because there are idiots in the world that will try anything even if & when they do not have a clue what they are doing or getting themselves into.
Dec 23, 2011. 9:23 AMSIRJAMES09 says:
Dear Sir:
Years ago, I had bought not one but several books on Electricity...unfortunately, I lost them in a divorce(she tossed them in the trash) I still remember SOME of the stuff I read, but not not all. Anyway, my point is, I have always been afraid of electricity & always stay away from anything I am not sure of. I'll install light switches in walls, outlets, GFCI's, but when it comes to serious wiring(like running wire from room to room, adding a circuit, etc) that's when I'll have no problem calling for help from an electrician.
Making & rewiring a lamp is easy for me as I have done it so many times, but like you say, I ALWAYS double or triple check my work B4 plugging it in.
I TY Sir for sharing this instructable for it has given me the ideas I need to switch my torch lamp over from what it is now to the corkscrew bulbs you show in the instructable.
Take Care Sir & God Bless. :)
Dec 21, 2011. 11:36 PMSIRJAMES09 says:
bben46, I TY for sharing this as I DO understand basic electrical & I understood everything perfectly.
I think you did a great job of explaining everything & the pics reinforced that.
5 stars Sir.. TY.
Mar 14, 2009. 7:39 AMsmcan22 says:
I really like what your doing here but it is an "instructable" - why not explain the difference between wiring them in parallel instead of in series? What makes not knowing that the qualifier for trying this out?
Dec 21, 2011. 11:31 PMSIRJAMES09 says:
AMEN!
Jul 2, 2009. 3:44 PMtehbizz says:
I agree with smcan22. If you put up the instructable, you need to at least give a little back knowledge for people that may not know. I was actually going to try this but your comments regarding parallel vs. series are a turn off. This site is for sharing information and helping people do different projects, not tell us we can't do things.
Dec 21, 2011. 11:33 PMSIRJAMES09 says:
and the author has done just that.
If you do not know the difference between series & parallel, then you should NOT be messing around with electricity. PERIOD.
Aug 24, 2009. 12:47 PMmagicdust says:
Get real, folks. I totally agree with the author, BBen46. Series vs. parallel is basic stuff that shouldn't bog down an instructable writer. If every instructable required every bit of knowledge explained it would seriously impede the flow of the essential information. I had no problem and actually appreciated not having to skip through YET ANOTHER explanation of basic electrical circuits!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:bben46
Semi retired, Electronics tech, working part time as Motor & Controls Field Service Engineer. I have worked in many different fields, including Metrology (yes, it's spelled right), Textiles, Dental Eq...
more »
