Convert a Baby Swing from Batteries to AC (wall) Power
  • last photo ←
Are you tired of changing the batteries in your infant/baby swing?
This instructable covers how to convert your baby swing to wall power, so you can just plug it in and not have to change the batteries.
It's designed so that you can choose wall power or batteries, depending on your needs.
This Instructable requires soldering--There are other instructables covering that if you need help learning.
Step 1Tools & Parts Necessary
Tools
Screwdriver(s)--Used to open up the motor/switch/battery housing
Wire Stripper/Cutter--Used to cut and strip the old and new wiring
Soldering Iron--Used to solder the new switch and wires to the existing wiring
Heat gun or Cigarette Lighter--Used to melt the heatshrink tubing
Parts
5 VDC Power Supply--I used an old cellphone charger. It needs to have a similar voltage output to the batteries in your swing. Count the batteries in your swing. Each one puts out 1.2VDC (Whether AA, C, D, ect). Obviously 9V batteries are a different animal. Mine used 4 "D" batteries, so I needed at least a 4.8VDC power supply.
Double Pole Double Throw (DPDT) Switch--A small one from Raido Shack, etc. is fine.
Solder--Used to secure the new wiring
Heatshrink Tubing--Used to protect the solder joints
Epoxy or Super Glue--Used to secure the switch to the housing
70 comments
1-40 of 70next »
Nov 25, 2011. 10:04 AMsbednarek says:
HI! Thanks for the great post! My only question about these kind of conversions, is do you need to be concerned with amperage? Understandably, you want to try to match the voltage of the combined 4 batteries to the AC supply, but what about amperage? As I understand it, a D cell battery has 1200mA hours, or 12 amps for an hour. I don't know if this means that batteries are 12amps? that seems high, and also cell phone adapters are usually less than an amp. Do I need to worry about this? Thanks!!
Nov 23, 2011. 9:07 PMbfeij says:
I think the instructions were clear (anything that isn't to the reader, I would suggest you Google what you don't understand or ask someone for help).
What I would add is this when you have the DPDT (Double Pole Double Pull) switch and you have identified which side your going to put your positive and Negative cables on in a row, use the wires that was originally coming from your battery pack to the control as the wires going to the motor. On the one end you would have wires going to your battery pack, the other end wires going to your 5V (or whatever voltage you require) power supply and the center poles (originally your battery wires) going straight to your control panel.
This way you have full control whether you use batteries or AC power.
Nov 3, 2011. 5:15 AMrsakamaki says:
Great instructable. I have a question. I have a spare 5v 1.2A charger I want to use to power a baby mobile. The mobile uses 3 C cells. Could I simply splice the 5v in, or will that make it blow up/ die? If so, how do I step it down to 4.5v?
Jul 13, 2011. 2:50 PMlagüera says:
I love this instructable!
I have this exact swing and the same exasperation with the repeated purchase of "D" batteries!
I do not know how to solder, however, so I probably won't try this at home. :-/
I have never seen a baby swing with an AC adapter and all the hand-me-down swings we got are battery operated. I looked for swings with AC adapters in local (Pittsburgh) stores and found none. My sisters actually didn't believe that they existed, and they almost had me convinced. We figured there had to be a law against them, because who would want a battery powered swing if plug-in swings were available?
Are you listening, Fisher-Price?! (Probably not. Sigh.)
Oct 30, 2011. 8:10 PMsanthony5 says:
My old swing was AC power or battery, but you could never find an AC adapter officially sold for it. I just went to radio shack and got one of those adapters you could change the voltage and the plug on..
It's a shame that they don't make both options.... It's probably a "safety" issue with having a corded product... they have to go through UL certification I think.. or something probably like that..
Sep 3, 2011. 5:07 PMdapperbac says:
try the mamaroo baby swing. its actually a better swing all together. it is pricey but its a great swing.
Oct 22, 2011. 2:03 PMvedder79 says:
Hello, great instructions, my question is do I need this DPDT switch? My battery pack broke so I would just use wall power all of the time, can I just connect the cell charger right to the motor wires? Thank you..Mike
Oct 21, 2011. 11:53 AMzlange says:
I had a 5V .5a adapter and it seemed too weak. So I swapped out for a 5V .7a adapter and it seems a bit better. I think that I might spring for a 5V 1.0a adapter, i bet that'll be about right. thanks for posting this DIY!
Sep 3, 2011. 9:18 PMCrackclimber25 says:
I have a baby chair that vibrates and it takes one d cell battery which means that it only takes 1.2 vdc. I have an old charger that puts out 5 vdc, should i get a charger that puts out 1.2-1.5 or can I use the one I have?
Aug 11, 2011. 10:17 PMjkhan6 says:
Great Instructions; loved it. But can this method be applied to a Wall Clock or any gadget that requires batteries only.
I have this beautiful large Wall Clock with music and lighting which turns on every hour and has a sensor that automatically shuts the music and lighting off at night or in darkness and back on in any lighting. The clock requires 4 C-size batteries and have changed them several times within just six months whilst taking clock off the wall and adjusting the time each time. Would appreciate the response. Thanks.
Aug 14, 2011. 12:52 AMjkhan6 says:
Thanks WrenchingPilot,
To further clarify and upon noticing, the clock has two sections adjacent to each other in a compartment each requiring two C-size batteries; a total of four. I believe that one section is for the clock and the other for music/lighting - in conjunction. I can see two wires (black/red) passing through each section. I just hope it doesn't require two separate adapters.
I have a cell phone LG AC Adapter that has an input of 100-240 VAC, 50-60Hz, 0.2A and an output of 5V, 1A. Can this be used?
Jul 30, 2011. 5:52 PMparones says:
Just finished this fix up and I coudln't be happier! Followed the instructions dead on. Used a cel charger with 5DC / 1000mA output (that's one amp if you weren't sure), and one of those DPDT switches with the option to screw on the wires- the one with a red 'on/off/on' plate- I still soldered it though.
Cost about $5 in parts- batteries are $10 a pop and last for 1-2 weeks, so I figured I saved easily $100!
I was lucky enough to have pretty much the same model shown here, but mine has an extra function. So you know, that has no effect on how this fix works.
Jun 23, 2011. 1:17 PMahorton1 says:
I'm using an adaptor that has one solid black wire and one wire that has a white dash line. Which wire would be positive and which one would be the negative?
The adapter is an AC adaptor:
P/N: PSA12D7P5P7-A
Model: MKD-4175700
In Put: 120VAC 60 Hz
Output: 7.5VDC 700mA
ITE power supply.
I just want to make sure I don't blow myself up when attaching the wires to the swing or at the very least touching them to the positive and negative areas of the battery faces to test it.
Apr 3, 2011. 1:12 AMcroma1 says:
What do i do if I have a device that uses a 9Volt battery? I have a toy that i want to leave running all day on a timer, but the battery dies in like 2 days if i just leave it running and turn it off at night. I noticed you said that a 9v is a "different monster,"
Can I Still do this?
What parts do I need?
Mar 28, 2011. 3:40 PMinternethotspot says:
I used 5v 2amp power supply. For switch I purchased one with thread and nut on back to fasten rather then use epoxy. As for wires, I would recommend using longer wires, as it is rather difficult to solder while holding the housing. A couple more inches would have made it easier.
One thing didn't seem to work out for me - it doesn't appear to be rocking. Manually, it freely moves and continues rocking, but for some reason it's not working via the controls.
Lights and music work fine.
Good luck!
Mar 17, 2011. 5:12 AMjpierce81 says:
I got 2 of the 3 working.
the one that I am having trouble with worked with batteries before I took it apart.
I have the polarity right. when you turn the swing on the motor turns on for 1-2 seconds then quits. when you turn the swing off the motor turns on for 1-2 seconds.
I swapped the motor with another swing and the motor is good. something is messed up in one of the 2 circuit boards. one board only have the power switch and the speed setting. the 2nd board has all the caps, and resistors, ect..
It would be nice to get this last swing working again.
Mar 15, 2011. 5:19 PMjpierce-3 says:
I have triplets and I am tired of buying batteries. I have 3 swings and each swing takes 4 c batteries. I bought 4 of these http://www.radioshack.com/product/index.jsp?productId=2049709
I cut the end off and attached the wires to the back of the battery pack. now the swing dosent work. is 1800mA to much?
Feb 9, 2011. 12:16 PMshane67lchs says:
Thanks I'm gonna try this out, well my brother in law is cause hes a electrition, so i figure its eaiser for him, but looks great
Oct 25, 2010. 9:31 PMselina_robyn says:
did you have any problems with the music skipping?
Nov 7, 2010. 9:46 PMrexexdesign says:
Great tutorial! I have had some experience with soldering, but had never installed a switch, was a great experience. I had a couple of issues where the battery side worked, but not the DC one, I had to try a few different combinations (used the coax panel mount power jack so I can unplug easily.
I have a question though, I went to Home Depot to buy some wire to extend the ends, but couldn't find any wire as thin as the one present in the swing, so the only thing close to that was Bell Wire, is that safe? It works great, just want to make sure it's not going to cause issues...
Thanks
Aug 24, 2010. 5:45 AMdustindu4 says:
Thanks for the inspiration for the project. The Radio Shack parts I used were: switch = 275-0614, coax panel mount power jack (size N) = 274-1583, and DC power plug (size N) = 274-1573. I tried using a cell phone charger like you described and it doesn't have enough amps to run the swing. On my Fisher Price swing the cell phone adapter had enough power to run just the swing with no baby in it. Put a baby in it and it didn't have enough juice, nor would it allow the music to turn on. I found a 5V 2.1amp output AC/DC adapter lying around and used this. The 2.1 amp provides enough power to run the swing. Regardless of what the naysayers on here say, 2.1A is not dangerous, the swing only draws the power that it needs. 4 D sized batteries supply 2.5 amps of 6v power. My swing works perfectly.
May 4, 2009. 3:03 PMSwishercutter says:
This got reposted on Lifehacker.com...you should read all the comments from people who have no electrical knowledge commenting about the fire/shock danger.
http://lifehacker.com/5239690/convert-a-gadget-from-money+sucking-batteries-to-ac-power
Good Instructable, I thought of doing the same thing with my son's swing but he grew out of it before I got around to it.
Aug 24, 2010. 7:32 AMdustindu4 says:
I'm pretty sure that a USB port puts out 5VDC @ 1 amp
May 25, 2009. 7:58 PMjason thomas carter says:
Very Nice. I did this but without the switch as I don't plan to use tons of D cells. Works well thanks for the inspiration.
Apr 5, 2010. 11:27 AMlazuara says:
Hello, so for your swing, did you just connect to the 2 wires leaving the battery pack and to a ac to dc convertor?
1-40 of 70next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:WrenchingPilot
