Step 8: Assemble the rest of the door.
After the two pieces are bolted together, fit the door on the stove and when you have the best fit, mark the position for the two hinges. When you mount the door, put a light and mirror inside to check the alignment as you progress. Photo K is a closeup of the hinges. You can use hinges of steel, aluminum, or brass. The alignment of the door was troublesome and took time to get right.
You will want to be able to replace the hinges and fiberglass gasket, so have the nuts on the outside for easier removal.
Remove these ads by
Signing Up
Not Nice
Visit Our Store »
Go Pro Today »
