Convert a MR16 Fitting to GU10 Fitting!
Published
Introduction: Convert a MR16 Fitting to GU10 Fitting!
About: My name is Francesca, I work for HomeWatt (www.homewatt.co.uk). We specialise in anything lighting related! With over 5 years of innovation behind us, we like to help everyone in any way that we can.
Before you start you will need:
  1. Switch of the power at the fuse box.
  2. GU10 lamp box.
  3. Electrician's screwdriver or small flat head screwdriver.
Remove the fitting and transformer from the ceiling by pulling firmly.
Step 1:
Disconnect the mains feed going INTO the transformer from the lighting circuit.
Step 2:
Leave the cable going FROM the transformer to the fitting.
Step 3:
Uncover the connector block on the fitting (ours is screwed some are clipped) to expose the connector block inside.
Step 4:
Unscrew the cable connecting the transformer to the fitting.
Discard the transformer.
Step 5:
Disconnect the MR16 lamp holder from the connector block and discard.
Step 6:
Connect the GU10 lamp holder to the connector block, feeding through the inside of the fitting with the lamp holder inside.
Step 7:
Connect the mains cable directly to the fitting and re- cover the connector block.
Step 8:
Install GU10 LED bulb – from www.homewatt.co.uk of course.
Step 9:
Re-install fitting into ceiling and switch electricity back on.
Step 10:
Let there be light!
    • Water Contest
      Water Contest
    • Creative Misuse Contest
    • Oil Contest
      Oil Contest
