Step 7Construction: Start hooking things up
Get a segment of jumper wire, tin the end, get a (not excessive) ball of solder on the nes pad 15, do not push the wire through the hole, just solder it flat on the pad
Now loop it around so it meets up with pad #12, Pin # 17 of the atmega is already in this hole, and the pad is not connected to anything else in the controller, so B button is good to go, A was not as graceful
For button A solder a wire flat onto pad #1, loop this around to the top of the board and solder to pin # 23 of the atmega
Also solder blob pins 20 and 21 together (dont overheat) this is aref and analog power supply, aref is soldered to the pcb's +5v bus
Add Comment
