1) don't want to fuss with wax spills from tea lights?
2) don't want to leave an open flame inside?
3) want more light than a tea light can give?
If so, read on! In this instructable, I'll show you how to take a tea light lantern and make a great compact fluorescent lamp!
Remove these ads by
Signing UpStep 1Gather Your Tools/Materials
Tools:
Hand Drill
1/8" (or similar) drill bit
Sheet Metal Step Bit (or a 7/16" drill bit)
Materials:
Tea Light Lantern (I am using a "Roterra" from IKEA)
C7 Compact Fluorescent bulb (I am using an E12 "Sparsam" from IKEA)
Chandelier Bulb Socket
Lamp Hardware Kit
Rotary Thumb Switch
Electrical Cord
Also the live on the power cable should go to the centre of the lampholder, the neutral to the outside, and the switch should be cut into the live wire. On that horrid single inulated cable I think the standard is that the one with ridges on it is neutral (It has been on all the novelty lamps I have bought off eBay and then rewired when they got here to make them safe)
Did you consider entering the lamp from underneath? I am guessing the length of the holder and bulb would put the light source part of it too high in the glass area. Also since the handle is still there some chain would be pretty cool on it.
As for safety, many places of the world do not include ground lines in their indoor electrical cords. I realize that ideally, one would want to ground the frame, but even if the frame were to short to one of the wires, touching it would not hurt you. You would have to touch both the frame and a grounded object at the same time. If both wires were to short to the frame, then it simply would blow a breaker or a fuse at the panel. All of that being said, if someone is unsure about their electrical skills, they should not be working with mains AC.
