Introduction: Convert a Vintage Light to Component LED
Picture of Convert a Vintage Light to Component LED
I bought a cool-looking vintage photography spotlight at a garage sale that I thought would make a great looking desktop lamp or reading light. The bulb was burned out and the base was a rare twist lock that is no longer available. For the conversion I bought a chip-on-board (COB) LED. LEDs require constant current and precise thermal management. I'll use a driver with a constant current of 300ma and a forward voltage of 21. A quick calculation using Ohms law has my LED working at 6.3 watts. A finned heat sink rated up to 10 watts will handle the heat.
Step 1: Pick You LED First
Picture of Pick You LED First
I chose a high power COB LED with a color temperature of 3,200 Kelvin, or about the warmth of an incandescent bulb. COB chips pack small LED together on a single chip. The maximum drive current for this LED is 500ma, but I chose a driver at 300ma to stay within the wattage rating of the heat sink.
Step 2: Heat Sink for Thermal Management
Picture of Heat Sink for Thermal Management
High-powered LEDs require you to stay below a certain temperature or they will fail. My LED forward voltage is 21 volts with a driver delivering 300ma. Volts times Amps = Watts (21v x .3a) gives me 6.3 Watts. I chose a heatsink rated at 10 Watts to be safe. I'll use thermal paste before attaching the LED to ensure good heat transfer.
Step 3: Mount the Heat Sink and LED
Picture of Mount the Heat Sink and LED
After tearing the guts out of the spotlight, I fashioned a 90-degree bracket that put my LED at the center of the reflector. I coated the heatsink with thermal paste and screwed down the LED. This LED is mounted to a star that allows two soldered connection on the front of the chip. It has two positive and negative connection so you can daisy chain chips. Just remember that if you chain the chips, your driver's voltage must be greater than the combined forward voltage of the chips and be of sufficient wattage.
Step 4: LED Driver and Mounted Chip
Picture of LED Driver and Mounted Chip
I pulled the case off the driver to enable it to fit inside the spotlight. I'll cover it in plastic to keep it from shorting out on metal case. It is a 120 volt AC to 21 volt DC constant current driver I bought on Ebay.
I added a reflector to keep light spill to a minimum. You can add optics to focus the light, but this spotlight has a glass Fresnel lens to handle that task.
Step 5: Testing Before Assembly
Picture of Testing Before Assembly
A quick test shows the LED is working properly. I realize the old reflector is not doing anything, but it's not in the way. High-powered single LEDs throw a fairly narrow beam, while COB chips are quite wide.
At 6.3 Watts, the bulb is equivalent to a 65 Watt incandescent, or about 850 lumens at 3,200 kelvin. I intend the light to be on a desktop, so the light is not overpowering or too blue.
Step 6: The Assembled Case
Picture of The Assembled Case
The LED is dead-center on the fresnel lens. The spotlight has a twist knob to adjust the distance to the fresnel and the beam angle. Yes, I could have converted the light using a small 30 Watt halogen, but I decided to go small and efficient. The case is much too small for a standard bulb. You may see LEDs rated with a CRI. The rating is a measure of the quality of light. Colors look better with higher CRI ratings. This LED's CRI comes in a 85. That's a B+ for light quality. Anything above 90 will render colors that are the most pleasing to the eye. The rated life of this chip is 40,000 hours, or about 40 times longer than a standard incandescent.
Pdwight (author)2016-01-28
Would these be dimable ?
I used these lights back in the early 70's when I worked in Photo during high-school. I would love to make a pair of these for vanity mirror location for my wife...the look is great
ranjeevm (author)Pdwight2016-08-22
Good information - I was browsing eBay with this info and see several LEDs of your description being sold. Questions - 1. The price seems to be around $1.50 so they are not too expensive. How long have these lasted in your projects? 2. Did you derate the current?
rexperry (author)ranjeevm2016-08-23
In this project I used an LED rated to 500ma and installed a driver at 300ma, derating it by quite a bit. After just a few hundred hours the LED started to dim. I replaced the cheap COB with a Cree CXA 1310 array and it has functioned perfectly.
Lee Wilkerson (author)Pdwight2016-02-14
Connect a variable DC supply to it to dim it instead of the AC hookup and AC converter module.
Pdwight (author)Lee Wilkerson2016-02-14
That would be fine for a lab workshop enviroment, but daily household use would be a different story
Okay, then use X-10 or something similar.
rexperry (author)Pdwight2016-01-28
Because this was my first conversion, I kept it simple. Just buy a dimmable driver and matching dimmer available at places such as LEDsupply.com.
zappenfusen (author)rexperry2016-02-01
Nice adaptation. Dimmable?
zapp
ranjeevm (author)2016-08-22
LED technology is evolving by the day... if you ever have anything serious to do with them buy only the ready made bulbs from the most recognizable brands. I have LEDs mostly "Made in China - sold on eBay" kind of stuff (fitted by the previous owner) at my place that are about 1 year old. Purchased branded LEDs at Costco @$1.50 per bulb. There is no comparison in brightness, energy savings and overall life!! In my previous house I tried experimenting with DIY LED projects but thanks to the lack of quality control (on eBay and other popular websites) none lasted more than a few weeks. My projects have spanned COB and non-COB LEDs... COB LEDs are the ones used in this project... these are especially bad and none lasted for more than 3 days. I tried under rating them by reducing the quiescent current to half that is rated but that wasn't encouraging either. Having warned you of the futility of this exercise, I hope that if you still do this project, you are luckier than I was!!
rexperry (author)ranjeevm2016-08-22
I hear you and I have experienced that lack of quality control. I've done a couple of other modifications using both the Cree Xlamp and Luxeon high power LEDs on 20mm stars. I'll never go back to the cheap COBs.
Lee Wilkerson (author)2016-02-14
Great job and 'able. I have been doing some experimentation with some high-power LEDs also.
MarkL34 (author)2016-01-28
I think they still make these:
http://www.bhphotovideo.com/c/product/42236-REG/Photogenic_908882_CL150FS_200W_Minispot.html
rexperry (author)MarkL342016-01-28
Wow. I bought mine for$10 at a photo garage sale.
MarkL34 (author)rexperry2016-01-28
Looks like they're going for 150 or so on E-bay. I would've made a lamp out of it too.
friggin WOW.....$300 bucks
I should have just sold it on Ebay! I had no idea.
starphire (author)2016-01-28
I can't tell from the photos whether the lamp housing allows airflow past the fins of your heatsink, but hopefully you realize that approximate "10 Watt" rating assumes unimpeded airflow in an ambient environment close to room temperature (which it would not be if the housing traps the heat generated). If the original bulb cavity is more or less closed off completely, the equation changes significantly. But an array of vent holes or slots could greatly improve convective airflow if that is the case.
Still, it's a really cool-looking retrofit, and your efforts to use proper heatsinking are certainly much better-considered than some of the rather shortsighted LED lamp Instructables I've seen here lately.
rexperry (author)starphire2016-01-28
As Filmist correctly commented, the body has large slits at every rib for extensive ventilation. And thank you Filmist for the bulb source.
Filmist (author)starphire2016-01-28
I've owned this original lamp before, and the housing was designed to cool a 250-W tungsten halogen lamp. There's plenty of air flow through the lamp.
:-J
schabanow (author)2016-01-28
An urgent lack of cooler is detected. 50 mm would be perfect.
Filmist (author)2016-01-28
Your original premise that "The bulb was burned out and the base was a rare twist lock that is no longer available" is wrong.
This lamp can take a variety of standard bayonet lamps: The ANSI codes for them are ESS (250W), FEV (200W), ESP (150W) and ESR (100W).
Were I to do this, I'd place the LED & heat sink where the reflector is for a greater flood-to-spot capability. And this particular lamp design would dissipate the heat from the heat sink very well.
Good job.
corporatelab (author)2016-01-24
A beautiful and creative combining of old and new. I, too, like the coolness of quality equipment that folks too-often think is old-fashioned and should just be unceremoniously pitched. Add the changes you make and you have something to be proud of that is better than the original.
In general, if we cannot include old and enduring processes with the new, we will find ourselves to be both non-essential and outmoded “before the end of the day”.
I liked especially your explaining of your mental processes, reasons, and background related knowledge as you went through the complicated decisions for designing your creation. (There has to be a simpler way to say that. ; ) A very effective and caring way to teach serious students, that is not used enough. This way yields not memorizers with the gloss of smart, but true students who master their subject. (And, of course, no master should ever stop being a student.) Thank you.
rexperry (author)corporatelab2016-01-24
Thank you corporatelab. I believe that we must create objects that are durable, repairable, upgradable and beautiful. Without those qualities, the things we make--and in effect our time, treasure, and legacy--end up in the landfill.
DIY Hacks and How Tos (author)2016-01-24
Great mod. The LEDs are really efficient but you get to keep the cool vintage look of the old spotlight.
About This Instructable
27,353views
231favorites
License:
More by rexperry:Convert a Vintage Light to Component LED
Add instructable to:
