[Edit]
In the spirt of Instuctables, I'm adding some of the sugestions for improvement and why I didn't do things that way in the first place. Some I had considered, others i had not.
Q. Why not just put in new batteries?
A. Too expensive. The drill was $5 (with case, extra drill and 2 battery packs) and worked for a while. The wall wart was free at another garage sale. Brand new unit would be about $20 and be ready 'out of the box.' A new set of batteries and a charger for them would not be worth the time or money. If it was a good brand name on the other hand...
A. While trying to find out which cells in the battery were live and which were dead, I lost the parts. Thus, no battery shell to reload : )
Q Use a Zener transorb/5 f. capacitor/ect.
A Aint got one. Too expensive to go out and get some just to play with. I don't feel comfortable enough with electronics to risk the parts.
Q Use a more powerful transformer.
A Aint got one. That and i don't know how much I can pump threw the motor before it burns out. I may end up finding a bigger transformer, or trying it on AC current-but not untill I don't need this one any longer.
You may notice a theme here-this is a cheep fix with what I had on hand. Nothing fancy, not a lot of pre-planning to get in the way of getting something finished. Are there better ways to do this? Absolutely : )
Remove these ads by
Signing UpStep 1Research!
wall transformer for project power supply
http://www.instructables.com/id/EQ3VVA5ZVKEYF7HZ0W/
or
Reuse "Wallwart" transformers
http://www.instructables.com/id/EC1BYG2K40EWPKHAGV/
in a perminant way.
How to solder
http://www.instructables.com/id/E30LR180T4EWP872BS/
or
Soldering to large metal objects
http://www.instructables.com/id/EYUBQBN818EWZMIAYA/
if you are lazy like me and decide to solder onto the large battery clips rather than fiddle with the wires inside the case. or, you can't find your soldering gun but can find your butane torch...
you could even use
Handy box from scratch paper
http://www.instructables.com/id/EZO32EAKLOEXCFECUK/
for screws.
and, yes, i screwed up the batteries before i had a chance to use
Revive Nicad Batteries by Zapping with a Welder
http://www.instructables.com/id/EPV474YLF3EV2Z8V9V/
or
Hot Rodding a Power Drill Battery
http://www.instructables.com/id/EZOAB2A75XEV2ZHAQP/
the reason I say after christmas is because I don't have money currently (well, I do, but I kind of need it for gas and insurance) so I need to get a job and get money. that, and my mom told me I couldn't go in my dad's workshop for the rest of the year because I cannot keep anything clean (cruel and unusual!) so I really can't do anything anyway.
and thus ends the rant of codongolev. have a nice day.
One a 12v craftsman drill where I used the 12V 750 mA adapter for the charger that came with it. This one seems underpowered.
For the second one a black and decker 18V I used the biggest adapter (physically as well as voltage) that I could find a 30V 500mA and this one seems to work great. Not sure about longevity though but it hasn't melted yet. :)
Crude schematic below:
Wall jack---PC power supply---rectifier---drill
http://the-goodlife.blogspot.com
Oh, and the argument was here. Not the first time this has been tried : )
http://www.instructables.com/id/EBLN6A48CVERIE1R92/
By the way...if you want to do this instructable but you want a drill which will function at full power you'll have to get an AC adapter (wall-wart) which can at least match if not surpass the original battery's current capability. The one in this instructable was probably trying to draw more current than the wall-wart was capable of providing. Extended peak usage like that may overheat the transformer in the wall-wart and throw a breaker or make a bunch of nice smoke.
As the author said in step one
more voltage with less current = more RPMs with less power
more current with less voltage = more power with less RPMs
also: more voltage AND more current = more RPMs AND more power And overheated drill.
So depending on which power supply you choose you could end up with a really big dremel moto-tool, a really small winch, a pile of molten, smoking slag, or a functioning drill.
The best bet is to stick with a PS that supplies the original battery's voltage and matches or surpasses its current capabilities.
An Energizer AA battery for example can push up to 2 A continuously (until it is dead).
