3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Convert a hand-held circular saw into a table saw
Step 8Things I made with the saw
The main reason I made the saw was to cut up the old lumber I had in my garage. There's old 2x4 and other stuff from the last 7 years of home improvements. I was able to re-claim some of the lumber but a lot of it is probably only good for throwing away or making charcoal. I also made a shop cart for my tool box and misc tools. It was inspired (but doesn't at all resemble) by an instructable about building a shop table.
Please take a second to rate this instructable. Click on one of the stars in the upper left corner.
10 comments
Oct 13, 2011. 8:08 PMSIRJAMES09 says:
This was a good read, & interesting too...HOWEVER, would it not be better to make the entire table top from 1 whole sheet of plywood??
That way, all the edges are the same, the surface is more likely to be all flat(or at least flat as in 1 solid piece).
Or, you could do like I did yrs ago & cut tongue & grooves into some 2x6's, glue & clamp them all together, then cut to size & sand them smooth.
This is what I did when I made a dining room table. turned out sharp too. :-)
I was thinking, that one thing you could do to keep the saw running when in use, is to by pass the switch on the saw & wire in a switch within arms reach by your waist on the side of the table. it may sound complicated, but it's really not. It's actually quite easy.
Just my 2 cents worth...not telling you what to do...
Dec 20, 2010. 9:51 AMwade7632 says:
this is cool i am making my own how did u keep the saw on thow
Oct 13, 2011. 7:57 PMSIRJAMES09 says:
that link/address is dead....
Jul 1, 2011. 9:19 AMshuja.shaher says:
great !!!!!!
but i am not clear about the mounting of the saw on to the table
i have only a 4" circular saw
May 14, 2011. 11:40 AMDOSn3rd says:
Just an idea about the insert and it's clearance, wouldn't it be possible to just lower the blade aka. increase the cutting depth with the saw alredy attached to the underside of the insert-board?
May 15, 2011. 2:10 PMDOSn3rd says:
Now that I look at it I wasn't making myself clear in my previous comment, sorry :/
What I wanted to say was that if you attach the saw to the underside of the insert and then "lower" the saw while it's on and by that making a "zero-clearance insert" instead of drilling holes. Would that be a feasible idea?
Sep 25, 2010. 6:16 PMpsiked says:
Thorough ible. Been planning on buying a table saw, but kicked around the idea of making my own since I have 3 hand ones. Now I'm inspired.
Feb 26, 2009. 7:08 PM0087adam says:
Im envious of your work bench though -.-
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
20
Author:neffk
hmmm...
