3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
A Vibrating Deaf Dog Caller Collar <5$
How do you call a Deaf Dog?
The joke say it doesn't matter he won't come anyway. But seriously, what if the dog (or whatever) is really deaf or the handler is mute? Then what? How can you get your pet's attention and alert them to stop or return to you?
About 3 years ago, my friend came to me with this dilemma when Jake, her very old Siberian Husky was loosing his hearing. She usually kept Jake in a large fenced property but when he decided to chase a rabbit, get loose, jump the fence, head onto the roadway, etc. He would be so focused or distracted that no amount of calling would get his attention.
I solved her dilema then with a Deaf Dog Caller Collar. The great thing about this idea is with a bit of training my friend found the dog would at least stop, change focus momentarily, look around for my friend and usually return, even if at his leisure for a treat.
For this Instructable, I built my second unit so it only took me less than 1 hour to locate everything I needed and less than 3 hours to finish the building.
Step 1Background to the Dog Caller Collar
This instructable is a medium difficulty Instructable, about 1 to 3 hours building time, to convert a Remote Control Toy (a car) into a vibrating dog caller collar. Distance range for this to project is limited by the quality of toy used.
Further information can be fond at this website DeafDogs.org. They sell manufactured vibrating dog collar units. Some of these units go up to a mile away but you may find this out of your budget. This site also suggests making your own unit much cheaper similar to what I did for this instructable. However they didn't write an instructable for it.
This simple remote control could be slightly modified to control many other applications.
If you build this with a light rather than a vibrating motor you can find your night wandering pet much easier, is just one example.
Note: 'Jake' has since passed and so 'Rusty' has volunteered to model the Deaf Dog Caller Collar. He says, "Please send cookies!"
57 comments
1-40 of 57next »
Sep 14, 2010. 3:51 PMjoerice01 says:
Your half way to making a remote control dog LOL
Jan 8, 2010. 1:47 PMharry599 says:
 Cute Doggie, my doggies tounge sticks out like that to!
Oct 16, 2009. 9:39 PMhammer9876 says:
The joke is "How do you call a deaf cat?" "It doesn't matter. He won't come anyway."
Aug 19, 2009. 10:29 AMvishious1 says:
problem with dog collar devices is their size. I have small dogs and would love something like this to distract them when they are off lead. how about the thing that makes a cell phone vibrate?
Jul 16, 2009. 6:49 PMBriguy9 says:
Aww, as a fellow dog lover I'm sorry that your dog has passed. I think my dog might be on the verge of pushing up daisies, actually.
Jul 16, 2009. 6:50 PMBriguy9 says:
*One of my dogs (I have 3)
Feb 13, 2009. 5:39 PMDelaney says:
"The car must be the kind that does not run the motor unless or until you make the transmitter send a signal." This is not true at all... I actually just made a similar device using the above mentioned type. All it requires is a diode. Just some info. Cheers
May 4, 2009. 11:17 AMDelaney says:
Well first you have to find out which way the current flows when the switch is not pressed by using the diode at one of the motor terminals. The diode will be placed the correct way when the motor does not run until you press the remote button. soldier and you're done.
Jan 6, 2009. 12:04 AMomnibot says:
Cool concept. I like it. I've been thinking the same for our cat.
Mar 26, 2008. 10:40 AMjdege says:
And what happens when your dog goes swimming?
You need to take a serious look at how you're waterproofing this thing.
In commercial collars, the electronics is embedded in epoxy, the case is filled with silicone, and the openings are sealed with O-rings. Even then, a lot of users will wrap the entire thing in electricians tape.
Taping a collar
Mar 26, 2008. 3:00 PMninjaimasta says:
yeah but i dont really think anything smaller than a car battery is enough to put your pet in danger at all, even then a "regular" car battery may not even do anything in relation to the size of the dog. The worst that can happen is the electronics can get fried. Just simply epoxy the damn thing shut and be done with it!
Mar 26, 2008. 5:40 PMjdege says:
There have been dogs who have been very seriously burned by shorting electronic collars. There's a lot of energy in those little batteries. Don't believe me? Take a pair of NiCad 9 volts and plug them into each other, and see how long you can hold on to them. Make sure, though, that you do it where they're not going to land on something flammable when you drop them.
Dec 21, 2008. 8:43 AMSmurphette says:
"A will agree about some of the power of a 9Vdc battery though as I've put one in my pocket that also had a few coins. It does give off enough heat to burn skin." I've done that as well. The looks you get when you suddenly go; "Ow! My pocket is burning!" lol
Mar 26, 2008. 8:19 PMjdege says:
There's more than twice as much energy in a AA as in a 9V. Compare the mAh ratings:
9V * 220 mAh = 1.98 Wh
1.5V * 2700 mAh = 4.05 Wh
And the question isn't whether you're going to jump in a bath with it on, but whether your dog is going to roll in a puddle or run through a sprinkler. You can't tell your dog to stay dry, and your dog can't take the thing off, should it start to burn.
Nov 25, 2008. 4:35 PMdniloc2cv says:
That xtra cell phone that can be set to vibrate if we have the xtra cash to keep it activated each month. Good battery life an with Xtra battery just swap out.
Nov 3, 2008. 6:36 AMamicus curiae says:
great idea! big Q...what is the range? i have deerhounds they can cover a lot of ground fast! i can't:-( also i have issues with them being barky at others in the car, they have trashed the interior, aargh! a buzz may remind them of manners;-) some days a zap! would also be handy though.
Oct 26, 2008. 5:03 PMsmokehill says:
An excellent instructable, and should be very helpful. We do dog rescue, usually about 30 dogs, most old or otherwise unadoptable, but we always have a few Dalmatians, and at least half of our older ones are deaf. With our fencing, safety isn't an issue since most are never going anywhere else. However, we picked up a 4-month old deaf Dalmatian puppy last week, really great & quite adoptable, so we're starting on some hand signal training soon. This should make it MUCH easier and give her new owners, eventually, a really great tool. Your instructions are PERFECT. Now I just have to scrounge up an old RC toy somewhere and get to work. Preferably a small toy, since she's still a puppy. Many thanks!
Mar 27, 2008. 2:10 PMbqbowden says:
(removed by author or community request)
Oct 26, 2008. 4:44 PMsmokehill says:
The buzzing shouldn't bother a horse except perhaps initially for a very spooky horse. The electronic dog training collars we use for hunting dogs, or for other types of training, were initially invented for horse training, by a horseman, Rexe Carr, but for horses. His collar training for dogs is basically the "industry standard" now. My wife learned how to use the collar from Rexe Carr, after he had adapted it for dog training, and was still teaching a few classes for pro trainers. For some things -- like getting a dog to stop chasing cars, or other dangerous activities at a distance -- nothing else will really work. However, using it isn't a job for amateurs unless they read extensively first. We've never used it on our horses, but I know that tens of thousands of people have. There is probably a lot of info out there in books or the Web, to give someone an idea of how to introduce this sort of thing to a spooky horse. In theory, though, this should work fine for them, especially since it isn't even a low-level "shock" (buzz might be a better term), but just a vibration .... the point being just to get the animal's attention.
Sep 28, 2008. 11:55 PMno lol today says:
YES! My little Bobby (Short for Bobble Head ... he's special.) is completely deaf. I looked at retail prices & they're expensive! Needed a DIY option! <3
Oct 26, 2008. 3:44 PMno lol today says:
Yeah, I thought about the size factor. Def have to go with a tiny little somethin' or other.
Sep 29, 2008. 12:01 AMno lol today says:
'lil Bob
Oct 26, 2008. 8:55 AMBriguy9 says:
What is a project without it (duct tape)?
It's just not a project at all. (see math formula below)
Whole buncha tools + some tech stuff - duct tape = ?????
lol.
Sep 15, 2008. 9:01 PMpickford78 says:
If your dog has a larger amount of hair and doesnt feel this try using a lead weight with a odd shape instead of the cut gear.
Sep 1, 2008. 11:59 AMcontainer_gardener says:
Inventive, potentially life-saving idea! It could spare some owners of deaf dogs from heartache. Rusty is an adorable model. Of course, I am biased because he resembles my dog.
Mar 28, 2008. 8:54 AMElric says:
Great project... Now all I need is a deaf dog! %-)
Jul 15, 2008. 4:53 PMGamernotnerd says:
Earplugs?
Apr 7, 2008. 12:29 PMpieman123 says:
nice one my dog hates I mean loves it
Apr 4, 2008. 11:49 AMfungus amungus says:
You should consider changing the title of this one. The point is that you made a collar for a deaf dog, not that you used a RC car to do it, right? Something like "Vibrating Deaf Dog Collar"
Mar 26, 2008. 11:56 AMLarrySDonald says:
Excellent idea. I don't even have a deaf dog and I'm tempted to build one. This (or the commercial version) could also work for deaf humans in a kind of "Hey bro, look over here so I can sign something" way, though with vibrating cell phones I guess that's kind of solved already. I suppose that could work for dogs too as a high class version, but even though prepaid phones are cheap service costs over time.
1-40 of 57next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
39
Author:arcticpenguin
