In this Instructable, I will show you how to convert a computer power supply into a regular DC power supply with 12, 5 and 3.3 volt outputs. For about $10!
Why use a computer (ATX) power supply? Well, they're available everywhere, and they can output tremendous amounts of power in a small form factor. They have overload protection built right in, and even a 500W model can be reasonably priced with high efficiency. The voltage rails are incredibly stable. Giving nice, clean DC current even at high loads.
Plus, it's likely that many of you simply have an extra one lying around doing nothing. Might as well get the most value for your investment.
Remove these ads by
Signing UpStep 1Getting Started
Here are the tools/parts needed:
Drill
Needle-nose pliers
Soldering iron
3 x "Banana Jack" Insulated Binding Post sets
1 x bag of "#6" Ring Tongue Terminals (16-14 gauge)
Rubber feet
Small bit of heat shrink.
Screwdriver
Wire strippers
Ok, let's get to voiding some warranties!
I have an AT power supply, it was creating 11.43v from the yellow 12v wire. I wired a 12v globe to one of the black wires and one of the red (5v) wires. I put the multimeter on the 12v and ground wire while the globe was on. it read -12.21 I was wondering why it said negative? and also my lipo charger can handle 12v-17v, would it be ok if I put another globe on the 5v rail? or is one enough already?
cheers
Can Anybody Please
help me to Idfentified the pin out of my ATX COMPAQ
model PS 5201 4T2.
I like to make power supply also. from that Model.
The position of the green or Power ON is not in Position 14.
Please help me to solve this.
and do I need sense wire also. to be able to run it.
I have 20 pins out.
GOD BLESS.
Thanks
Thanks for this great info. I just converted my first ATX 600w PSU model ULT-VX600 yesterday. It is working good thus far, and is so much quieter then the marine battery charger that I was previously running. I use it to power a Hyperion LiPo battery charger for my RC hobbie. My charger is capable of accepting 12-28 volts on the DC input side. I did some test charging pulling 25 amps from the PSU and am noticing the output voltage of the PSU drop to close to 11 volts and as a result my charger stops charging one leg. I have 10g wire soldered to the power bus on the inside to provide power to my charger. It shouldn't be a voltage drop issue.
Is there a way to tweak it to make it put out over 12 volts?
I was also considering wiring two ATX's in series to get 24 volts, but the problem would be that they share case ground with - DC. If I put the + from one the ATX to the - of the other it would short out since they are using a common AC source for power. The -12v line is only rated at less then one amp, so that is worthless to me.
Any suggestions?
My problem is that I can't run a zvs driver (pulls around 5A at 24V), a plasma speaker either.
It just simply turns off.
What could be the problem? :S
In short, check what specific ratings are on the stickers on the PSU and search the internet for the data sheet if you can find it. If you cant, i would say thats your problem and you can really only fix it by getting a new PSU that has a 25V 5A rating on it
Actually I want to make a test bench and I want to do series of experiments relating to my project, for which I cannot wait to charge the Lipo again and again
Any guidance in this will be much appreciated
Regards
1mm^2 10A
1.5mm^2 16A
2,5mm^2 25A
4mm^2 32A
6mm^2 40A
My PSU is rated:
-12V 0,8A
-5V 0,5A
+3.3V 26A
+5V 35A
+12V 15A
I'm not thinking of using the negative voltages. The wires are AWG16 = 1.310mm^2. Because I don't think I will go to the max, 2 wires will give me enough room to pull 25A per channel(NOT simultaneously!).
So using two wires will give you 200% current without melting your wires and it will save you some room and time grouping ALL the wires.
http://www.hobbyking.com/hobbyking/store/__17753__Turnigy_Mega_200Wx2_Battery_charger_discharger_400w_.html
i will be charging at 10 amps x 2
i have a 600w psu, will it handle wot i need?
thanx, wuld apriciate it if some one culd email me direct, i dont get mutch time to get on line at the mo
rickyc83@gmail.com
When I look for supplies to convert, I'll actually scrap supplies that don't have the -5V live, for parts.. those with everything, get converted.
Right now, Just picked-up a pair of discarded 235W 'Power Man' supplies, , just begging to be converted Provided they start-up. :-)
By the way.. as for amperage... it's a heck of a lot higher than just 3,3Amps.
Look at the specs for a generic 350w psu:
Rosewill RV350 350W ATX 1.3 Power Supply
+3.3V@28A
+5V@35A
+12V@15A
-5V@0.5A
-12V@0.8A
+5VSB@2.5A
There's quite a lot of juice available :D
By the way... the +3.3v and +5v share the same amperage source, while the +12v is separate. So, if using +3.3v, and +5v.. be aware of how much is actually needed.. might be better to just draw from the +5v, and add resistors or regulators for the +3.3v feed. :)
Cheers.........
