3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Convert an ATX Power Supply Into a Regular DC Power Supply!
Step 6Putting It Together
Putting It Together
Now comes the fun bit. Install the binding posts while using a small screwdriver to make sure they're all orientated right when you're tightening them down.
Install the tongue terminals onto the back of the binding posts and tighten them down good and snug with the pliers. This might be tricky if you have a high-wattage PSU as you will have more wires. The most the posts shown in these pictures can take is 4 tongue terminals.
After that's done, close up the power supply.
I had some clearance issues with mine- the 90mm fan just wouldn't fit. I figured since it will not be acting as the exhaust fan for a computer anymore, it wouldn't be needed anyway. So I removed it.
1 comment
Aug 3, 2008. 5:38 AMEstwald says:
The fan, however, DOES keep the heatsinks for the regulators cool when drawing a heavy load.
If you need the internal space remount the fan on the outside of the PSU case.
Clearance issues solved and PSU doesn't burn out under heavy load.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
33
Author:Sitnalta
