Here is a method of constructing a variable flush conversion for about $10. Not only does it provide substantial savings on your water bill over a period of a year, it is a very environmentally friendly project.
http://www.dualflushkit.com/uploaded_images/cms_files/dualflush_toilet.jpg
http://images.channeladvisor.com/Sell/SSProfiles/13000155/thumbs/51/tn4_940583.jpg
Remove these ads by
Signing UpStep 1Tool, parts and planning
1) 1/8 drill bit
2) drill
3) hack saw
4) hobby knife
5) locking pliers
6) multi tool/pliers and assorted small tools
7) pen
8) ruler
9) tape measure
optional: scissors if you your multi tool doesn't have them
parts include
1) 2" ABS/PVC plastic pipe
2) acrylic sheet 1/8 or more
3) coat hanger
4) plastic container (see notes)
5) toilet flapper
6) waterproof epoxy
optional: super glue and latex glue
planing: Start by measuring the inside of the tank to see where and what size jar to use and where to place it. If there is a large float that takes too much space then you should move it or replace it. The new system will work by having the plastic jar holding some water in the tank for a small flush and for a big flush the flapper in the jar is opened to allow all water to drain.
notes: For the plastic container I used a P.E.T (Polyethylene Terephthalate) plastic jar, I found out that it resists glue, it still bonds to the plastic and preforms the job, however, it's not very strong, so AVOID anything with ethylene in its name it's better to use containers made of acrylic aluminum, PVC, lexan or ABS, you can I dentine the type of plastic. The easiest way to tell is to see if it snaps when bent, then it is good. If you cant find a jar then make one with a large peace of pvc and a pipe cap.
Let's come up with more smart ideas that save us money and save the planet. I'm an older lady with no kids, but I love our planet and believe we have the responsibility to take care of it!!! I liked the comment about letting your waste water from the washer drain out into the garden. The Brits did this 20 yrs. ago in a village I lived in and called it "gray water". Kirsteen
In addition, I only flush after number 2 (i don't know why some people find this gross to do on a residential bathroom and at the same time find it ok on a public restroom)
A friend of mine calculated the optimal volume of the bottle (i need to do this as well). calculate the volume by adding enough small bottles until the toiled could not flush (limit), then removing the last small bottle, add all volumes and find bigger bottle(s) volume equivalent.
