Introduction: Convert ITunes Movies to MP4
iTunes movies and TV shows you purchased from iTunes Store are M4V files AND they are protected files. Normal video converter, like Any Video Converter, can not convert them. But the protected M4V files can not play on your Android devices, your TV or your media player on your pc. You have to convert them to normal MP4 files.
So here is the tutorial you may need. The most important tool is NoteBurner M4V Converter Plus [Official site: http://www.noteburner.com/ ]. You may download the Mac version or Windows version according to your need. Although they are not free, they have free trail version you can try. And personally, I think they truly worth it.
The following is the detailed tutorial:
Step 1: Add ITunes Movies [Rental Movies Are Supported As Well]
Click Add which is on the top-left of the interface, and iTunes movies library will be opened by default. You can choose videos from it and click "OK". You can also use "Search" to find which files you want to convert.
Step 2: Choose MP4 As Your Output Format
You can select output format by activating the dropdown list on the right, under the "convert to" section.
By clicking on the "open" button under the "save to" section, you can customize the output path.
Note: If you don't change output path, the output files will be saved in the default folder.
Step 3: Customize Video and Audio Options, Convert!
On the right part of the main interface, you can set the time duration, video size, video nitrate, etc for the output video.
When all the settings are done, you can start to convert the iTunes movies to MP4 by clicking on the "Convert" button.
Once the conversion is completed, you can find the converted MP4 movies and play them with any devices you have.
Tips: If you want to learn more about the program, here are some links
NoteBurner M4V Converter Plus for Windows: http://www.noteburner.com/m4v-converter-plus-for-w...
NoteBurner M4V Converter Plus for Mac: http://www.noteburner.com/mac-m4v-converter-plus.h...
