3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Convert old CD packaging into a flower pot
Step 2Make holes in the top pot
Make several holes (at least 6) in the bottom of the top pot. This will be the pot that holds your plant. I used a Dremel with a 1/8" drill bit. The holes allow the excess water to drain out of the bottom so you don't get root rot.
1 comment
Jan 2, 2008. 5:26 PMBox_Full_Of_Sharp_Objects says:
i would make the holes, stick a clean cloth in the hole fill, and the bottom drum with water. the cloth soakes up the water so you don't need to worry about forgeting to water the plant.
Jul 23, 2009. 12:35 PMpborstel says:
I was thinking the same as I read the instructable. I grow African Violets in 2 piece pots that use a piece of cloth to wick the water up to the plant. You can use just about any kind of thick string or fabric for wicking. You can water from top, excess water going into bottom trap, wick pulls it right back up. If bottom trap is empty, time to water!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:gate
