Remove these ads by
Signing UpStep 1Price, Secondary Materials, and Primary Materials
Here's the breakdown of what you will need...
Secondary Materials (not a part of final construction)
1. WD-40
2. Toothbrush
3. Towel/Clean Cloth
4. Pipe Wrench
Primary Materials
1. One - 2" Galvanized Tee ($7.84)
2. One - 2"/0.5" Galvanized Hex Bushing ($3.90)
3. One - 0.5" Galvanized Floor Flange ($3.56)
4. One - 5" x 0.5" Galvanized Nipple/Pipe ($1.13)
5. One - Container of 5min Epoxy Adhesive ($2.97)
Another note...the picture below has a (12" x 0.5") pipe. I was using a longer pipe in order to stack a greater amount of weight. I would suggest the 5" pipe if you intend on using the weight converter for deadlifting. Anything longer will exceed the height of your 45lb weights as it rests on the ground/on the bar.
I also see no reason why you could not shoot a bead of weld in place of epoxy if you were so equipped, but I realize many of us don't have a welder handy.
Finally, I have found recently that I can currently get Olympic and standard plates, cast one-piece hex dumbells, and bars and associated equipment, at my local scrapyard-as scrap prices go up, weight sets are apparently being scrapped along with other steel and iron. I can currently get as much as I can carry for around $.18 a pound, but the price is fluctuating.
This is not a criticism. Just pointing out that the cost of this can make it not viable for many situations, not all situations, but many. Anyway, good job, I love to see creative ideas regarding gym equipment..
