Introduction: Convert Your Bluetooth Headset Into Wired Bluetooth Headset
Picture of Convert Your Bluetooth Headset Into Wired Bluetooth Headset
Today i'm going to tell you how to make or convert your own wired bluetooth headset.
Follow my step and your are some step behind to convert it.
Step 1: We Need
Picture of We Need
Our Requirements are as follows:-
1.Scissor
2. Some Tape
3. Screw Driver
4. Mobile
5. Soldering Iron and Soldering Stand
6. Soldering Paste And Solder
7. Lighter
8. Blade
9. Bluetooth Headset
10. Old EarPhone
Step 2: Procedure With Earphone
Picture of Procedure With Earphone
First we take an old earphone and cut it into half.
Now take the part which contain speakers and burn your lighter on the cut end point then solder each wires with the help of soldering components.
Now solder two wire together. here question come which wire to chose.
Ans:- Solder both golden wires together and solder both other colored wire together.
Step 3: Procedure With Bluetooth Headset
Picture of Procedure With Bluetooth Headset
Now open you bluetooth headset carefully. Place all the small components on other side. KEEP IT SAFE.
Check which wires are connected for speaker then unsolder those wires from circuit and paste it on the body of bluetooth headset with the help of some tape.
Now take the earphone golden wire and solder it on -ve sign and solder another wires to +ve sign.
Test it with you phone which is compatible with it or you can test it on your laptop.
Step 4: Assembling
Picture of Assembling
Now Assemble all the parts of bluetooth headset.
And test it again......
Step 5: Demo
Enjoy my friends.....
And don't forget to Share and vote me if you like it..
Thanks foe seeing it..
Step 6: Upgrades
Tech Works (author)2015-02-01
Hope You Like It....
MiłoszG (author)2015-02-14
Great but I got 3 wires from the speaker (red,black and blue)...any help?
Tech Works (author)MiłoszG2015-02-15
Ohhh... But it's not possible because each speaker having 2 wires 1 for +ve and other fot -ve (GROUND), It might be possible if the company join another wire at the joint... You will proceed with that earphone in 2 way.....
1st option is to open your speaker container and check which color is there (Just open one of them But do it carefully) after locating wires color then join both common wire first and after that join another wires together 1st way is just do it manually check each one of then first solder red to +ve and black to -ve if it work in one speaker then remove red one and solder blue if not then change it try the combination like as follow:-(+ve - -ve) red-black, blue-black, red-blue, blue-red, black-red, black-blue
i think black is for ground and red-blue for right-left
2nd option is to open your speaker container and check which color is there (Just open one of them But do it carefully) after locating wires color then join both common wire first and after that join another wires together
i'm sending some pics to understand if your are not able to figure it out then send some pics of your earphone...
Hope this is helpful to you.....
victoman1234 (author)2015-02-02
Good idea! Would be even better to add a 1/8" audio jack to plug your headphones into. Like that, you don't have to cut them in half!!
Tech Works (author)victoman12342015-02-02
i was just started about it.. see my next project....
thanks for your comment...........
Hope you like it
Tech Works (author)Tech Works2015-02-02
For now you may see this link
https://www.instructables.com/id/Upgrade-Your-Bluetooth-Battery/
About This Instructable
9,279views
50favorites
License:
Bio: I have some interest in electronic. you can find me at https://www.facebook.com/theTechWorks
More by Tech Works:How to Make Mobile Phone Wall Charging HolderHow to Make Your Own Homemade Arduino Uno R3How to Make Relay Circuit Board for Arduino
Add instructable to:
