3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Convertable all terrain board for summer and winter
Got inspriation for an all terrain board that worked on ice from this Howtoons
http://www.instructables.com/ex/i/BD8D2D787C831028A786001143E7E506/
Step 1Draft blade configuration
17 comments
Dec 15, 2007. 5:59 PMhamgravy says:
plzzzzz reply:: does this work for snow as well?? If not,the could you please tell me how I cam make it work? Thx! -hamgravy
Oct 16, 2009. 8:59 AMAqueous_Snake says:
Just take off the blades and go down hill... common sense really
Sep 12, 2008. 6:24 PMRye2121 says:
where did u get the tires?
Mar 28, 2006. 11:43 AMAleksi says:
Good looking board! Last year I hacked together an iceskateboard out of a cheap skateboard and some old skates. It was built for a party on a skating rink. Take a look at the construction and you can probably guess that the board fell apart later that same night. It was a lot of fun though.
Jul 18, 2008. 4:48 PMClayton H. says:
A way that you could probly fix it is by making the trucks higher with some risers and mke it just like the picture and then just flip the blades over to skate.
Feb 3, 2008. 6:53 PMcooldog says:
what width steel did you use
Dec 15, 2007. 6:04 PMhamgravy says:
Mar 18, 2006. 11:51 AMbillz260 says:
What about some runners for snow?
Dec 28, 2006. 1:48 AMorangekid13 says:
take your foot out of your mouth then go google "snowboard" or "snowskate"
Apr 8, 2006. 8:01 AMclint eastwood says:
i like aleksi's idea better
Mar 28, 2006. 3:13 PMkearney says:
don't you have to worry about looking like marty mcfly in i think it was the second back to the future movie? he had his board and could push off of the water. I would suggest putting together or buyiing a cheap pair of crampons for a bit of friction on the ice.
Mar 30, 2006. 4:55 AMAleksi says:
Yes, I had a pair of those. They completely ruined the deck but without them it was exactly like in that movie :)
Mar 20, 2006. 8:44 AMflywoodkb says:
Have you tried it out? Does it work well? How thick is the blade steel and what kind of steel did you use? Are they ground to... how do I ask this question... are they ground to a 90 degree V so that the vertical axis of the V is parallel to, and cenetered between, the sides of the blade (ice boat style)?
Is there a mechanism for aligning the two blades on each truck to each other? I used to have an ice conversion kit for a 3-wheeled kite-powered buggy and its main weakness was that the blades couldn't be easily aligned. It was only *really* fast if you rode it in a "wheelie" with one one the rear skates "flying". It was also much quieter and left less visible tracks. One of the ice boaters I met said that he aligned his skates with a cheap rifle scope mounted on a straight edge. He set the straight edge against one skate and sighted someting like the edge of a house's door across the lake through the scope. He would then move the scope to the other skate and shim the skate til the scope pointed at the other edge of the door.
Re: Runners: My kit had a fiberglass runner for each of the three skates. The runners were about 6 inches wide and 2 or 2.5 feet long. It still didn't like snow drifts, and was worthless in deep snow. The kit maker said the runners also reduced the hazzard of getting whacked by a skate (better to get whacked by a runner than a sharp skate).
Looks super cool. Nice project.
Mar 20, 2006. 9:15 AMflywoodkb says:
Whoops, silly me, I missed the pics that show that the blades would be easy to align by adjusting the nuts :)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
37
Author:radiorental
Appreciate what you've got, every day will bring something new.
