3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Convertible Geometric Blanket
Almost every kid I've ever known as gotten more excited about the box a gift came in than the gift inside, but this blanket is sure to be an exception. Composed of foam and felt, this blanket's grid of triangles not only offers a way to learn about geometry, but also to let your imagination run wild!
Unlike standard blankets that just let you snuggle up and keep warm (which it also does), this one can also be used to teach kids the Pythagorean theorem (a2+b2=c2) or the angle sum of triangles (the three angles of a triangle added together always equal 180o). You could also use it for simpler concepts like addition or simple counting, or to make an awesome fort!
Learning Objectives
Learning Objective 1: By constructing this blanket, students will be able to master simple math (counting, addition, division, etc.)
Example 1: Counting the triangles and squares in one row and determining how many compose the entire blanket
Example 2: Dividing the length of each side of the blanket by 6" to determine how many squares should be in each column and row
Learning Objective 2: By constructing this blanket, students will be able to enhance their understanding of simple geometry
Example: The division of a square into rectangular rows and columns, and those rows and columns into squares, and those squares into triangles. Numerous shapes can be plotted out on the completed blanket, and 3D shapes can be constructed using the blanket to explore surface area and volume
Learning Objective 3: By constructing this blanket, students will be able to explore the angle sum of triangles
Example: The blanket offers a clear, visual representation of how the angles of triangles add to 180o. Further, a protractor can be used to measure the angles for increased understanding
Learning Objective 4: By constructing this blanket, students will be able to apply the Pythagorean theorem in a hands-on way
Example: Using a ruler, the sides of any of the triangles can be measured and the Pythagorean theorem applied to them
Note: Inspired by the super-cool stuff at studio_Gorm
Step 1You'll Need. . .
You\
  • 1 piece of 1/2" thickness foam - 24" x 24" 1
  • 2 pieces of felt or other durable fabric - each 26" x 26"
  • Sewing machine (you could do this by hand, but a sewing machine is strongly suggested)
  • Ruler
  • Thread (either to match your fabric or contrast, depending on the look you'd like)
  • Straight pins
  • Scissors
  • Tailor's chalk or other marker that can be removed easily (optional but suggested)
1You can use larger or smaller dimensions, but make sure that you're working in multiples of 6" for the foam, and that the felt is slightly larger
12 comments
Jan 6, 2012. 10:40 AMrosebud557 says:
Very Cool!! You gave me the idea to do a customized saddle blanket...Thanks!!
Jan 5, 2012. 4:57 PMMauigerbil says:
Wow! This is the coolest invention EVER! Thanks Shesparticular!
Dec 29, 2011. 11:58 PMwilgubeast says:
That is spectacular. Great work.
Dec 27, 2011. 11:03 AMdombeef says:
Or better yet, make equilateral triangles with velcro on the edges, so you could build 3d objects like a sphere, and at the end of the day make a triangular blanket!
Dec 26, 2011. 3:11 PMmikeasaurus says:
Comfy and nerdy, what an awesome combination!
Dec 26, 2011. 1:26 PMSeamusDubh says:
Question, how is this convertible?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
283
Author:shesparticular(Sometimes I tweet about stuff)
Learn more about me here: http://www.instructables.com/id/Featured-Author-shesparticular/ or follow me on Twitter (@shesparticular) (if you're into that sort of thing).
