Introduction: Converting Courtesy Light (door) to LED
Picture of Converting Courtesy Light (door) to LED
I replaced the incandescent bulb with a LED. The light is now brighter and cleaner
specs on LED
12V, 10mm, 40 degree, 5 chip LED, 100ma@280Kmcd
Step 1: Remove Housing
Picture of Remove Housing
Remove the housing from the door, acquire 10mm LED with resistor (for 12V)(purchased on EBay), rubber grommet and silicone if needed. remember where the hot wire (positive) is located
Step 2: Remove Bulb
Picture of Remove Bulb
Remove bulb holder and insert rubber grommet.
Step 3: Test Fit
Picture of Test Fit
Test fit LED into grommet, cut wires to proper length.
Step 4: Solder
Picture of Solder
Remove grommet and leads from housing, solder wires to the metal leads, remembering which side is positive. If solder does not take drill a small hole loop wire thru it and then solder.
Step 5: Install Leads
Picture of Install Leads
Replace leads and grommet might have to trim connection cover for proper fit.
Step 6: Check Function
Picture of Check Function
Connect to a 12V source and check proper function.
Step 7: Reinstall
Picture of Reinstall
Reinstall in vehicle.
ReCreate (author)2009-04-11
Now where did you get a 12 volt led?! LEDs are 3.3 votls not 12 volts
comanche (author)ReCreate2009-04-11
I did a search on EBay, 10mm 12v,. They were sent with the resistor already attached.
ReCreate (author)comanche2009-04-12
what a ripoff. Its not a 12v led its an ordinary led with a resistor attached,nothing special about that. how much did it cost?
comanche (author)ReCreate2009-04-12
14.99 for 10pc, 12v, 10mm, 40 degree, 5 chip LED.
Erik Lindemann (author)2009-01-26
I'm always happy to see another person out there converting to the almighty LED. Looks cool and helps the environment.
About This Instructable
5,851views
11favorites
License:
More by comanche:Converting Courtesy Light (door) to LED
Add instructable to:
