3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Converting a computer ATX power supply to a really useful lab power supply
Computer power supplies cost around US$15,but lab power supplies can run you $100 or more! By converting the cheap (free) ATX power supplies that can be found in any discarded computer, you can get a phenomenal lab power supply with huge current outputs, short circuit protection, and very tight voltage regulation.
In this instructable I will show you how to quickly convert one of those many computer power supplies into something that you can use to power your electronics projects, for electroplating, for electroetching, for heating wires for foam cutting, etc.
The voltages that can be output by this unit are 24v (+12, -12), 17v (+5, -12), 12v (+12, 0), 10v (+5, -5), 7v (+12, +5), 5v (+5, 0) which should be sufficient for most electrical testing. Many ATX power supplies with a 24-pin connector for motherboards will not supply the -5V lead. Look for ATX power supplies with a 20-pin connector, a 20+4-pin connector, or an AT power supply if you need -5V.
PLEASE, YOU ARE WORKING WITH AC VOLTAGE!!! IF YOU ARE NOT SURE OF WHAT YOU ARE DOING - DO NOT ATTEMPT THIS.
These instructions were originally posted by me on http://www.wikihow.com/Convert-a-Computer-ATX-Power-Supply-to-a-Lab-Power-Supply
Step 1Harvesting the ATX power supply
1) Unplug the power cord from the back of the computer. "Harvest" a power supply from a computer by opening up the case of the computer, locating the gray box that is the power supply unit, tracing the wires from the power supply to the boards and devices and disconnecting all the cables by unplugging them.
2) Remove the screws (typically 4) that attach the power supply to the computer case and remove the power supply.
3) Discharge the power supply by either letting it sit unconnected for a few days, or by attaching a 10 ohm resistor between a black and red wire (from the power cables on the output side). Using a resistor will only take a few seconds to fully discharge the power supply.
4) Gather the parts you need: binding posts (terminals), a LED with a current-limiting resistor, a switch (optional), a power resistor (10 ohm, 10W or greater wattage, see Tips), and heat shrink tubing.
142 comments
1-40 of 142next »
Feb 21, 2012. 9:02 AMRaf72 says:
Hi all, i am new here so nice to meet everyone. i already did this conversion and now i am going to do a second one but i noticed some doing the 1st and i checked that on the new one... i see that all v got a fuses protection and that is ok but i am wondering this, the ground goes on the psu case by the screws that set the pcb in the case so if for some "reasons" we accidentally short the v+ with the case..inste a good thing..., maybe we shouold isolate the case, am i wrong? infact the test on the new psu conversion, that i tested with the pcb out of the case uses only the gnd wire. so what about isolating the pcb by the case?...also if i see that the case id grounded with the wall AC so i dont know if it will resolve. any ideas or i am pretending too much by a simple and cheap conversione?.thanx a lot
anyway this project it's very nice and got the chance to reuse many psw that i got at home...cause of my job and passion
Jan 26, 2012. 4:17 PMKinnishian says:
If you're having an issue with the current being limited on the 12v rail, make sure you have tried the resistor upgrade on the 5v line. That is, put appropriate resistors on some 5v wires to draw 300-3000ma.
Otherwise, your question is not quite clear...
[This is a little old, maybe you have long given up].
Feb 16, 2012. 1:52 PMPyrofan says:
Ok so i have the resistor on the 5v wire but I only get 11.71 - 11.89 volts. It it settles at 11.88v. How do i get more the 12v? Like 12.6 or 12.8v. Thanks for the help!
Feb 16, 2012. 10:54 PMKinnishian says:
Just to make sure, what kind of resistor do you have on the 5v line? If you have too high of a resistor, you might not have enough of a load to stabilize the 12v line. Many sources say 100-300ma is enough (like, I think this instructable), but other sources I've found say 500-2000ma is optimally necessary.
In my case, with a 10ohm resistor (pulling 0.5amp) + a small lightbulb (pulling 0.3amp) I'm getting 12.35V. That might be the upper limit of this power supply, but I will check sometime with a bigger load (like 1ohm) to double check. But my 12.3V stays stable under load.
From what I've read,
You might also have a problem if your voltage sense wire isn't done properly. In my case there was an brown wire that went into an orange cable in the biggest connector of the original cables (the 24pin output). I had to make sure that brown wire was again shorted to the orange cables. Whether the brown cable exists an is shorted to the 5v or 3.3v (or in some cases even 12v) line depends on a number of things, so I just had to go through the trash to find the 24pin connection that I cut off and see what the case is.
When you say "it settles at 11.88v" I'm wondering what you mean by settles. Do you mean no-load voltage is 11.88v? The more likely problem tends to be that no-load voltage is "12.xx" V, but under load the line drops to 11v or something like that. That is primarily what the resistor is supposed to help with.
Feb 17, 2012. 4:28 AMPyrofan says:
ok so i have a 10ohm 10watt resistor on the 5 v line. with nothing on the supply the voltage is 11.88v
Feb 17, 2012. 8:51 AMKinnishian says:
It's possible that for your supply you won't get much more than 11.88v. What are you using the supply for?
I would also try and see if you can add another 10ohm resistor in parallel, or a small incandescent lightbulb, just to see if increasing the load helps. That will double the amount you pull from the 5v line (from 500ma to 1amp).
So 1) i would try adding another resistor (in parallel, not series)
2) Is there anyway you can work around your 12.6 or 12.4v requirement?
Feb 12, 2012. 9:08 PMpro5200 says:
I have a PSU from my old computer pentium II, I have connected the red and black wires to the power resistor, and green wire to black wire I connected to the switch, my PSU have 5 brown cable & just 1 brown cable connected it to orange cable, but the psu still would not start, can you help me?
Sep 1, 2011. 7:15 PMExiumind says:
I'm trying to use a computer psu to power up a rgb led strip(12v, 3amp)..
The 12v rail is giving 12.4v (no load), the outputs of these psu's arn't regulated right?
If i use a high current voltage regulator i'l get a fairly large voltage drop, and that wont give me the full 12v i need.. the only v reg i have right now is a sharp pq12rd11, since it has low Vd, the output i get is around 11,9v.
What do you think, should i use this one and some transistors to handle more current?
Need some tips guys =)
Sep 4, 2011. 7:22 PMExiumind says:
the point is that i want to use the computer psu that puts out 12,4v or so, and with this regulator the problem is that even having a low Vd it only supplies 1 amp max..
anyway, ill powerup the stirp using just the regular 12v output
Jan 26, 2012. 4:06 PMKinnishian says:
Nov 25, 2011. 1:02 PMGantman4eva says:
how would you go about adding a USB connection. Rocketman221 added one in his power supply, but wasnt quite sure how he wired the unit up. Any help would be appreciated. He threw this pic up but wasnt sure what wires you would use for port 2 and 3. Thanks!!
Dec 15, 2011. 5:00 PMchunk_change says:
As far as i know you would just ignore the rx/tx on the USB. You only need to wire 5v+ and GND.
Nov 9, 2011. 1:23 PMbrusho150 says:
HI!
Brilliant instructable I am new in electronic engineering and wanted a lab power supply will you please tell me that how Can we add a potetiometer(voltage regulator),rheostat, voltmeter and ammeter to calculate and vary voltage and current?
Thanks
Nov 10, 2011. 5:41 PMbrusho150 says:
Thanx alot bro I will try to construct it now.
Sep 17, 2011. 6:36 PMrhobbies says:
Hey Guys, I'm hoping you can help me out. I've got the mod done per the instructions above and triple checked my connections.
I get the desired voltages in the designated ports according to my multi-meter. I can do a small load with an LED light and small computer fan and the power supply operates as it should.
But anything larger (rc motor, motor dyno) the power supply immediately shuts off. I cannot find a reason for this at all. Any ideas?
Oct 7, 2011. 9:59 AMbeehard44 says:
PSUs shut down if they are overloaded
Aug 21, 2011. 6:23 PMbswt says:
would a 20w 2ohm resistor work
Mar 2, 2011. 9:22 PMtracer11lb says:
hi i try making this and in my atx 20 pin power supply i have a gray, green, brown, and purple wires... i did exactly what the guide said but for some reason when i turn it on the fan would spin for like a split second and would shut down. i tried everything and is still not working... the only power i saw was connecting the purple wire to the led and that works when i flip the switch at the back of the power supply not the switch i made with the green and black wire... also i tried taking out the switch and connecting the green and black together so i know the connection is right.. but i get notting...it seems like it is shutting down but i dont know why... i have a load on the 5v line.. tried the car light buld (did not work).. i tried the 10amp >10watt resistor (did not work).. please help cuz i have alot of project that i need for my car and dont want to keep bringing my car battery inside the house.. thank you
Aug 22, 2011. 9:21 PMbswt says:
try to put the green wire with the red wire that mite help
Aug 22, 2011. 3:27 PMbswt says:
put 2 10ohm 10watt resistor in parallel
Jun 28, 2011. 8:56 AMbaseballplayer34 says:
I need some help. I am trying to make one of these and the yellow wire is +12v and my meter reads +9.98V. And the blue wire -12v reads -7v. And the fan is barely spinning. Any help would be appreciated. Thanks in advance.
Jun 29, 2011. 7:22 PMbaseballplayer34 says:
Ok so I need a 10 ohm 10 watt resistor one lead to a red wire and the other lead to a ground wire then run the wire to the binding post? Thanks alot for your help I am kind of new to electronics.
Jun 30, 2011. 8:35 PMbaseballplayer34 says:
Thanks for the help I put in the 10 ohm resistor and we I turn on the power suppy the resistor get kind of warm. Is that normal? But I am now getting +12v and the -12v.
May 1, 2011. 8:21 PMjpoopdog says:
hey
i am trying to convert a pc power box into a power supply as mentioned, however, inside it looks nothing lke yours, it just has a bunch of really fat capacitors.
does this mean its not an "atx" power supply
and, what computers may i find such a powersupply in?
as in, how old must they be , as these capacitor power supplys that i keep finding, never give currents any higher than 5v, and i tried every single pin combination possible with my multimeter.
Mar 31, 2011. 10:55 AMphevtron says:
ahmm if i connect only one of the red wires in the +5 clip instead of all of them the current will decrease right? if yes what will the current be?
thanks
Nov 18, 2010. 7:25 AMMinimadnes says:
will a 10ohm 23w resitor work?
Nov 18, 2010. 10:55 AMMinimadnes says:
yeah my neighbour works at an electronics shop but they didnt got anij 10/11 watts so he got me this one
Oct 31, 2010. 10:12 PMcincaluk says:
I've done whatever is written in this instructables, but i can't get any output from the power supply..the fan is not on, so does the LED..
my PSU doesn't have any brown sense wire, but from reprap wiki (http://reprap.org/wiki/PCPowerSupply) they said that the pin 11 of the ATX connector is the sense wire (mine is orange in color - same as the 3.3v)..I've solderered that wire with all the remaining 3.3v, but, still nothing..
connected the sense wire with +5v (red wire) & still nothing...
for info, I used up 2 working PSU for this conversion & none of it works....
checked with multimeter (using the "buzz" function), it seems, there is a connection between ground & other's output, but, the sound is very slow. I assume it's due to the capacitor connected in the circuit..
can someone highlight to me what am i doing wrong?
thx
Oct 25, 2010. 7:10 AMhoussemus says:
hi, i am quite beginner,!
what's the rule of the power resistor!
Sep 28, 2010. 10:50 PMTroyMacDonald says:
So I've wired up everything exactly as this and other posts said, but I'm not getting any voltage out of my terminals and while the Standby LED comes on, the Power On LED never does. Using my multimeter across the additional Power toggle switch, I get just over 5VDC in the ON position but thats it. The fan comes on briefly - about 1 sec - then turns off. Any suggestions on what to check?
Sep 29, 2010. 5:44 PMTroyMacDonald says:
You were right about the short circuit thing going on, but it wasn't really modified wiring, it was the all the extra wires I clipped down....when I put the lid back on they apparently were shorting to the housing. A little electrical tape on the inside of the metal housing fixed it up and the thing works like a charm!
Sep 11, 2010. 3:45 PMandy70707 says:
Nice, I built one of these a long time ago as a high current 12v PSU, and I didn't need a 10w resistor. or any of the complicated wiring you describe. All I did was cut off all the connectors except the ground, 12v, and green cable, then solder the green cable to ground, and you have a high current 12V PSU. I used it to power my 100w peltier cell fridge, it works nicely!
1-40 of 142next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
10
Author:abizar
