3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Converting a computer ATX power supply to a really useful lab power supply
Step 5Connecting the wires
10) Connect one of the red wires to the power resistor.
11) All the remaining red wires to the red binding posts.
12) Connect one of the black wires to the other end of the power resistor.
13) One black wire to a resistor (330 ohm) attached to the anode of the LED(see the next image)
14) One black wire to the DC-On switch
15) All the remaining black wires to the black binding post.
16) Connect the white to the -5V binding post, yellow to the +12V binding post, the blue to the -12V binding post, the gray to the cathode of the LED.
  • Note that most power supplies have either a mauve or brown wire to represent "power good"/"power ok". Check the ATX plug (the plug with many connections) to see if there is a small mauve or bown wire plugged into the same hole as an orange wire (+3.3V) or a red wire (+5V). If the small wire is connected to the orange in the ATX plug then do the same, hook these two together. If it is connected to the red, then hook it to the red wire. This wire must be connected to either an orange wire (+3.3V) or a red wire (+5V) for the power supply to function. When in doubt, try the lower voltage first (+3.3V).
8 comments
Feb 12, 2012. 9:08 PMpro5200 says:
I have a PSU from my old computer pentium II, I have connected the red and black wires to the power resistor, and green wire to black wire I connected to the switch, my PSU have 5 brown cable & just 1 brown cable connected it to orange cable, but the psu still would not start, can you help me?
Sep 1, 2011. 7:15 PMExiumind says:
I'm trying to use a computer psu to power up a rgb led strip(12v, 3amp)..
The 12v rail is giving 12.4v (no load), the outputs of these psu's arn't regulated right?
If i use a high current voltage regulator i'l get a fairly large voltage drop, and that wont give me the full 12v i need.. the only v reg i have right now is a sharp pq12rd11, since it has low Vd, the output i get is around 11,9v.
What do you think, should i use this one and some transistors to handle more current?
Need some tips guys =)
Sep 4, 2011. 7:22 PMExiumind says:
the point is that i want to use the computer psu that puts out 12,4v or so, and with this regulator the problem is that even having a low Vd it only supplies 1 amp max..
anyway, ill powerup the stirp using just the regular 12v output
Jan 26, 2012. 4:06 PMKinnishian says:
If you're having an issue with the current being limited on the 12v rail, make sure you have tried the resistor upgrade on the 5v line. That is, put appropriate resistors on some 5v wires to draw 300-3000ma.
Otherwise, your question is not quite clear...
[This is a little old, maybe you have long given up].
Oct 25, 2010. 7:10 AMhoussemus says:
hi, i am quite beginner,!
what's the rule of the power resistor!
Sep 21, 2009. 9:20 AMbrod says:
Hi Should that be in step 13 that the grey wire has the 330 ohm resistor and not the black one, also the black wire should go to the cathode and the grey one to the anode.
Oct 4, 2009. 7:31 AMsijmenjan says:
I think this doesn't matter
Sep 13, 2009. 7:34 AMLaminarin says:
You might also use a fan as a load in place of the 10 Ohm resistor (if you can find a 5v 500 mA fan). Then you still have the same current (5v / 10 Ohms = 0.5 A = 500 mA) load but you also get some cooling instead of more heat.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
10
Author:abizar
