3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Converting a generator to run on propane
A step by step instruction on how I converted my generator to run on propane as a back up fuel source. There a numerous reasons one might want to do this. You might need a cleaner burning engine. You might not want to store or carry large amounts of liquid fuel around, besides liquid fuel eventually goes bad, propane will not. Its easier to store large amounts of propane. In an emergency situation such as hurricanes and earthquakes, gasoline might not be available or if it is, it will be in high demand, propane usually is not.
I found several ways of doing it on the web but nothing that seemed permanent or cheap. They have kits to do this but I didn't feel like forking out 100+ bucks to do it. This project cost me about 25 bucks and thats because I wanted new parts. If you had the parts laying around you could get out of it cheaper.
Step 1Warnings
WARNING This could be dangerous if the motor dies and your not around, the propane will continue to run and could possibly build up and you would have a nice explosion. The kits available commercially have a safety shut off or an on demand regulator that will shut the gas off when the engine dies or is not running so they will not flood the area with propane.
I run my generator outside on the driveway and know when it dies so I don't have a problem with the way I did this. Besides, with the wind blowing, I would never have a problem with gas build up. NEVER run the generator indoors with propane or any other type of fuel for that matter. Propane is heavier than air so it will collect on the floor or near the ground when it is allowed to escape out of the tank. Use this instructable at your own risk!!
121 comments
1-40 of 121next »
Jan 27, 2012. 1:14 PMemiller17 says:
Interesting I didn't realize you could convert a generator to a portable gas generator. So cool!
Jan 24, 2011. 4:55 AMsimonkoenig911 says:
i was just wondering about that safety shutoff valve... if you had an engine with an alternator on it, could you use that to power a solenoid valve, so the minute the engine stops turning, the propane supply would turn off, and you could have a manual override button for starting. anyone got any ideas on this?
Dec 12, 2011. 11:35 AMThe 4th Doctor says:
sounds like a great idea to me, on any generator you could just run it off of the wall voltage output too. i cant find any cheap solenoid valves though.
Feb 16, 2011. 6:17 PMtrike road poet says:
To end the backfire/explosion worries, just go to a local welding shop and buy a flame arrestor, a simple device used on cutting torches to prevent flame burning back up a torch hose and into the tank. The one for the Acetylene tank would likely work well, and the guys at the welding shop can aid you with selecting the right fittings to make the arrestor fit into your rig.
May 20, 2010. 4:38 PMmpikas says:
I don't get it, why go to all this effort?  You could just drill and tap a hole someplace in the casting and leave the carb functional, maybe put a shutoff valve in he gas line.
That way you have a setup that can be used for either, shut off the gas and run it on propane, or close the propane valve an run it on gas...
May 21, 2010. 12:23 PMmpikas says:
Yea, i get that you had the junk carb, but my point is that you didn't need to even mess with that.
A MUCH better way of doing this is to find an open spot in the carburetor casting, intake casting, or maybe make a spacer 3/8-1/2" thick using the carb gasket as a pattern (could be out of anything, aluminum would be best, but lots of plastics will work, as will any decent wood (soak it in "aircraft dope" or model airplane stuff from SIG, thin epoxy or a dozen other things to seal it), then drill a hole in the side of it and tap it for an 1/8" NPT thread.  Then take a brass hose nipple with a 1/8" NPT thread, solder, epoxy (JB weld...) or braze a short length of tube into the opening on the threaded end, and then crush the end so it acts to spray the propane into the throttle bore when threaded into the hole in the spacer.  The crushed end will give it some velocity and turbulence so it mixes better and you shouldn't have to worry as much about throttling the airflow in, it should run well over a broader range of mixtures.
Hook up your regulator + needle valve to the hose barb with a length of hose making it convenient and go for it.
Nov 28, 2010. 10:46 PMmenahunie says:
I agree.
My generator I drilled and tapped a hole in the intake manifold; similar to the one you see in the video.Took the carb off first to make sure I got the chips out.
I used a piece of propane hose clamped to the fitting screwed into the intake manifold with a male quick connector ( i stick a rubber cap on it when not hooked up ) to hookup the generator to the propane regulator. I also use a electric cut off valve that uses 12v; ( I use the 12v port on the generator - stops no 12v ) - no 12v it closes and turns off the propane. I use an adjustable regulator at the propane tank.
If I am using the generator camping or work I run it on gas or propane depends where I am. My truck runs on propane so I have around 45 gallons when truck is full. I just screw the fitting onto the fill port of my truck using high pressure propane hose to a regulator and hook up to the generator..
Nov 28, 2010. 10:23 PMmenahunie says:
you could have left the butterfly in to control air flow...
Nov 23, 2010. 7:28 PMderhul says:
Good idea!!! I never knew you could do this to portable gas generators
Jul 23, 2010. 8:49 AMmarkger14 says:
where did you get your propane? is it from lpg tank?
Feb 8, 2009. 2:22 PMPhantasmagoric says:
Wow, pretty cool. I'm trying to find stuff on converting small engines to run on alternative fuels to do a project for school... Would this be safe/easy enough to do on a lawn mower engine?
Mar 17, 2009. 4:17 AMkubbetta says:
It is very good project.I managed to convert a 2 stroke generator,but the problem is how to lubricate the piston, as before it worked on mixed petrol and oil.Any ideas
Jun 19, 2010. 12:37 PMkaado505 says:
well you could put the propane in the air intake and where the gas used to flow you could put the oil and turn the throttle low so it only lets a little oil in then control the speed by a regulator for the propane
Apr 11, 2010. 4:10 AMcompaq1501 says:
 i know its been a while since anyone commented on this instructable, but i wanted to convert a weed whacker/eater to run on propane from one of the small camping stove sized propane tanks. What i was wondering is, is it possible for the motor to back fire and ignite the propane? This is for an experiment so it wont actually be cutting weeds, at least not yet, and i dont want to blow up one of the tanks. Did anybody use some kind of bubbler or flash back arrester or anything?
Thanks in advance to whoever can help
Apr 16, 2010. 6:42 PMcompaq1501 says:
 My weed wacker is among the rare population of 4 strokes. there is no need to mix the oil. I tried to start the weed wacker motor by placing a propane torch into the carb opening (not the air filter) and pulled it and it wouldn't start or even fire. I then warmed it up with gas and got the same result..
thanks in advance for your help
Apr 17, 2010. 5:03 AMcompaq1501 says:
I dont think it was too much, becasue i was doing it outside and after i had pulled it once, it should have dissipated a little. I think that maybe the motor is a lower compression and just a cheap little motor. I think it was designed to run just good enough for whacking weeds.
Anyway thanks for your help...
I think i'll try a bigger motor maybe...
Oct 2, 2009. 7:56 AMhendrosutono says:
If you get rid of all the carb component and all the hole, why don't you just replace it with the same diameter plain tubular pipe, weld a plate shape like the intake on one side as an anchor and bold it up. Then put the venturi in the midle. That way any time you want to go back to the gasoline, you just put the carb on.... ;-)
Oct 30, 2009. 5:37 AMhendrosutono says:
would you like to give comment on my instructables? it's also about converting generator...
Oct 2, 2009. 9:51 PMqparker says:
you could, but the carb I had was shot and I wanted to do something unique to it, besides just toss it
Oct 19, 2009. 6:53 AMdsandds2003 says:
This looks similar to an idea that was posted on the Internet before. But it was removed for safety reasons. Something to do with using a regulator because for some reason their was a danger of explosion without a regulator.
I have been looking for a similar idea for quite awhile. Glad I found it here as I want to explore the prospects of this idea a little further. Thanks for posting it.
Keep up the great work!!!
Sep 28, 2009. 7:05 PMqparker says:
I tried a hotter plug and it helped a little but the problem is still there I also tried a colder plug and it wouldn't run at all once the engine is running I tried changing the fuel/ air mixture but that didn't help Any other suggestions would be appreciated
Oct 18, 2009. 5:56 PMqparker says:
I finally figured it out:
 I got the engine running and covered all known holes on the carb, spraying a little bit of starting fluid on various spots of it and found that the gasket between the carb and the intake manifold was leaking air, so I used some silicone and that fixed all my problems!
 I can now mow my entire acre of lawn on just one of those bottles used on a camp stove:)
Thanks for all the help,   This Instructable is GREAT!!
Oct 5, 2009. 8:02 PMqparker says:
I checked the compression when I put the hotter plug in and it was about 115-120 psi I think that would be plenty... I'll check the fly wheel and see if it is loose Thanks again for all the help
Oct 3, 2009. 8:35 AMrhoula says:
How long does the generator run on a full propane tank? Thank you
Sep 24, 2009. 1:12 AMKronoNaut says:
Can you use some type of solenoid to cut off the flow of propane if the engine dies?
Sep 23, 2009. 10:20 PMqparker says:
I'll check the spark, I changed the plug before the conversion, but i'll check it again, just to be safe, maybe put a hotter one in Thanks for the input.
Sep 20, 2009. 10:53 PMqparker says:
Great help, currently have my lawn mower running on propane... the longer it runs the worse it runs, could the propane be freezing in the lines thus constricting the flow? please help, if needed i can send pics of my setup
1-40 of 121next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
19
Author:Rainh2o
