Converting an Inkjet Printer to Print PCBs
 by pourcirm
Contest WinnerFeatured
SEE STEP 12 FOR NEW RESULTS AND AN ETCHING/PROJECT UPDATE!
Recently one of my focuses has been to find a way to make the PCB (Printed Circuit Board) creation process easier. I like being able to design something based on what I want in a circuit and just making it myself on the random weekend. While the toner transfer method has been my go to in the past it’s just not nearly as consistent as I would like it to be. The specific pressure of the iron and timing both make it a hit or miss approach. I’m not a fan of hit or miss I like to know something is going to work every time I try to do it. This sentiment got me exploring new ideas for PCB creation which is the topic of this project.
About a year and a half ago I found this webpage on modifying an Epson inkjet printer into a printer capable of printing on thicker materials such as copper clad board used by hobbyists such as myself to create custom circuit boards. As you'll notice that webpage is centered around an Epson C84 printer, but Epson printers are all somewhat similar so I decided to try this method on the C86 I had lying around the house.
Since I've been working on my own website (www.ryanpourcillie.com) I've documented everything about the project and thought it would be good to put it multiple places so hopefully numerous people can see it and try something new for themselves. I really tried to go into detail on everything I did in this process and the problems I had to troubleshoot because from looking around online there have been a few people who have done these modifications before, but no one really seems to have given a very good in-depth step by step build guide. Hopefully this Instructable can serve as just that.
So all that being said let's start with the tools and materials you'll need for this project:
Materials:
- Obviously you'll need some form of an Epson inkjet printer probably of the C80 family as those are the ones I have seen modifications to in the past.
- A sheet of aluminum or steel or some metal sheet (about 9 inches by 14.5 inches roughly)
- Approximately 4 feet of 1/4 inch bent (90 degree corner piece) aluminum rail
- Some type of brackets and screws to secure them with (I used 3, you'll see an image of them later on)
- Some 4 - 40 screws (I used 1/2 inch long ones)
- Nuts for said screws (I used about 16)
- A small piece of scrap plywood and some other random scraps of 2x4 or something of the sort
- Epoxy and/or hot glue
- The drivers for whichever printer and operating system you decide to use
- An ink kit from Inksupply.com (more details on this later)
Tools:
- A Dremel tool with grinding wheels to cut through metal
- Various screwdrivers
- Pliers or a socket wrench that fits the nuts or screws you'll be using
- A drill of some sort to attach the brackets
- A hot glue gun
- A heat gun
Once you've gathered all of those things you're ready to begin.
Step 1: Panel Removal and Breakdown
Step one is a pretty easy one and is somewhat self explanatory. The first thing I did was remove the paper feeder sticking out of the back of the printer and toss that aside. Once that's gone you can just use the tabs in various areas of the printer to pop off the front tray, the side panels, and ultimately the main printer casing. I chose to keep the main casing so that I have something to cover the printer with later for storage purposes.
Once you get all that done you'll end up with the internals of the printer ready for modification.
ahmed92 says: Apr 26, 2013. 7:29 AM
thank you very much.
but have one question,can i use canon printer.
dennist1 says: Mar 20, 2013. 9:15 PM
Great write up, well written and covering all the bases. Excellent job.
I have been considering a very similar mod, but not had the time to attempt it yet. What I am considering is replacing the print head with a laser diode; which could then expose a presensitized board. This of course would require some new control boards/software - possibly Arduino based, but should be able to generate very high quality boards. First thoughts were of course just cutting the copper with the laser, but my guess on that would be a very powerful laser given the heat transfer properties of copper. Anyone ever tried either; or anyone want to take the idea that does have some time to work on it - feel free!
aliyousu says: Mar 14, 2013. 10:36 AM
Hello,
i had a question. I am working at a startup and we are making comic publications. We need to print rolls of size 4inch by 150 ft long! and this is on bible (thin paper). The question i had was, we cant afford these fancy large format printers which are able to do this. Neither can we outsource as the cost is too high per unit. We need to print these cheaply and with inexpensive equipment. Any ideas if it is possible to convert a normal printer into something which can print 150 feet long documents.
The print quality is only 300 DPI and black and white.
Would really appreciate some help.
ryanbou says: May 11, 2012. 11:18 AM
Awesome work. Question- could a laser printer be modified in this same way to directly print toner onto a board?
switch62 in reply to ryanbouMay 27, 2012. 2:50 PM
I would say probably not.
The paper path in most laser printers is a sideways U.  That means the paper has to bend around the drum and rollers, a normal PCB won't.
Even if you could get a laser printer with a straight path the PCB is too thick and you would need to modify the actual drum/toner assembly and the fuser assembly.  Not easy at all.
Lastly the transfer of toner to paper relies on a static charge given to the paper to attract the toner.  I don't think the conductive copper will hold the charge well enough, if at all.
pourcirm (author) in reply to ryanbouMay 13, 2012. 10:00 AM
I have been curious about the same thing actually. The short answer is I'm not sure.
The longer answer is it would depend on the construction of the printer and how easily you could "lift" it. Factor into that the different printhead system and whatever other mechanisms a laser printer might have and it could complicate the build. I don't really have access to a "junk" laser printer so I haven't been able to test this idea out. I'd need to take it apart and look at the specific printer to decide how to go about modifying it.
If you do decide to try it and are successful or find some helpful things out make sure to let me know as I would like to try that in the future.
switch62 says: May 27, 2012. 8:46 AM
Well done, very thorough instructable.  Especially your experiments and results on etching.
I've been converting an Epson T21 but for various reasons haven't finished it yet (over 3 years !)
The T21 has the whole printing mechanisim and electronics on a vertical steel plate that is held by 2 screws to the base.  I just need spacers under the screws to raise it, no cutting, no brackets.  I was lucky on that part.
 I really should finish it and put up an instructable.
fedey2k1 says: May 22, 2012. 10:21 PM
Hi, Did you modify the programming if not then how did you tell the printer to only print with the cartridge you filled with the yellow ink, or did you fill all of them???
pourcirm (author) in reply to fedey2k1May 22, 2012. 10:38 PM
You could fill all of the cartridges if you'd like to and then you wouldn't have to worry about what color printed, but I didn't go that far. I only filled the black ink cartridge.
I've just been designing things in all black and then printing them using a black and white option in the printer settings and that has been working fine.
Additionally the program I use the most with this printer is EAGLE and it has an option on the print screen to only print in black which thus far has worked fine for me.
No-Shi-De says: Apr 26, 2012. 8:30 AM
I just thought somebody has to say this... your a smart person...
rohanmk says: Apr 24, 2012. 4:05 AM
Dear Sir,Your video is not available here.
qualia says: Apr 15, 2012. 3:36 AM
i was recently thinking about hacking a printer like this for a slightly different purpose, and i checked instructables to see if it was already done by someone else, this was the closest. my idea was to mount a lightscribe DVD burner laser on the printer head of a cheapish $50 printer (bought the DVD drive, not the printer yet) and link it up so that as well as depositing ink it could reduce graphite oxide film into graphene, on a glass or, (optimistically)- a cellulose acetate substrate for the purpose of making an active matrix pixel array for creating OLED displays (including the field effect transistors+capacitors for each pixel in the same process, using the semiconducting and conducting properties of the graphite oxide and graphene, respectively), the electroluminescent doped polymers could possibly be dissolved in acetone or perhaps a weaker solvent that wouldnt attack a printer cartridge too much, then printed over the transparent graphene electrodes, one for each subpixel in alternating formation according to the RGB dopants and corresponding subpixel.
the idea i had was having the printer rollers actually moving the entire printer along rack and pinion type rails on each side of the build surface, and i wasnt sure if the steppers would be powerful enough, got some heartier steppers around though, but different current ratings to most printer steppers so i'd have to make a breakout board to drive them if i had to use them for it. (which would be fairly straight-forward, i got a cnc lathe/mill and a UV LED PCB developing glass table)
anyway, what my question really is, would you know of how to mess with the printer driver program and/or circuitry to use it as a plotter as well, so it could laser reduce graphene oxide in continuous lines while changing from one axis to another instead of rastering? rastering would be fine for the deposition of the EL polymer but i think the graphene would have a more continuous molecular formation if it was reduced as a continuous trace.
apologies for lack of caps and the grammar, i are retard.
i would very much appreciate a reply if you have any information i might find useful to achieve this objective.
booga007 says: Jan 19, 2012. 5:07 PM
Very well done. Something that I might try in the future.
Is is just me, or does the final etched product seem rough around the edges for the copper pads and traces, doesn't look very clean in the pictures?
If this is the case, would a better quality printer be the way to a better etch, or is it simply the "DIY"ness of it all that produces the 'rough' results?
pourcirm (author) in reply to booga007Jan 19, 2012. 5:24 PM
The first boards I did while still testing the printer and trying to iron out the kinks do have rough edges on them yes.
As I got everything fixed and calibrated right though the boards got better. I have pictures of the better board I made in there a few places, but now that I know exactly how long to preheat the boards for and how to set the ink better and have a better etching tank the boards are coming out smooth.
I haven't had a chance to post anything new recently because it's been pretty cold outside and I haven't been able to etch boards yet. The new etching tank is nice, but the bubbling ferric chloride isn't something I like to use inside very much. I'm working on designing a few of my own boards currently and when I get a chance to etch them I plan on posting updated photos.
ARJOON says: Jan 1, 2012. 8:26 PM
i still don't believe my eyes. this instructables is incredilble. big thanks. will make one because i have the same printer
skrubol says: Dec 1, 2011. 11:17 AM
Is there something about the MIS ink that makes it more suitable for this task than other pigment inks?
fmubarik says: Nov 27, 2011. 9:46 AM
Can anyone tell me what is the minimum possible line thickness can be achieved
pourcirm (author) in reply to fmubarikNov 27, 2011. 10:23 AM
Currently with the Ethernet Arduino board that I've printed and etched the thinnest trace printed would be about the size of the 74HC08 surface mount chips leads. That is to say that they are approximately .3 to .4 mm wide roughly. I don't have an exact way to measure something this small at the moment, but from the datasheet for the 74HC08 I can estimate them at about that thickness.
As for the thinnest etched spaces on the board I have a few areas that are even thinner and I would estimate at about .1 to .2 mm wide roughly. I'd venture to say probably more around the .15mm area.
I know there are a lot of others out there using this setup too and maybe some of them are getting different results, but that's what I can tell you from my experience so far. I'm working on my own board design for another project currently so once I can that board all designed and ready to print I may be able to give you more measurements straight from Eagle.
aavs says: Nov 19, 2011. 2:02 PM
hi really like the idea, but having trouble with the ink, I thought it would be possible to use laser printer instead of ink jet....
beatyruth in reply to aavsNov 26, 2011. 5:38 PM
I haven't tried it myself, but I have a friend that uses his laser printer to print out the PCB drawing on parchment paper, then transfers it to the board by ironing it on. I've heard of others using regular paper the same way
pourcirm (author) in reply to beatyruthNov 26, 2011. 6:07 PM
That's the typical method of making homemade PCBs. My upgrade to this system was to make more intricate and more consistent boards. There are a lot of options out there though if you search Instructables for other methods.
pourcirm (author) in reply to aavsNov 19, 2011. 3:36 PM
I'm not 100% sure how to approach the idea of using a laser printer truthfully. There's a lot to consider that complicates the process. While you may be able to do it I don't think it will prove to be nearly as simple as this modification was. The laser printer has a more complicated system with the fact that it uses toner and then as the name suggests has a laser which melts or sets the toner powder into an actual ink. If you do try to modify a laser printer let me know as I think it would be quite interesting, but I don't know how much help I can give you without directly having access to the printer and seeing the inner workings that need modification.
switch62 in reply to pourcirmMay 27, 2012. 4:08 PM
The laser only writes the image onto the drum. The photo conductive drum is charged with a positive charge. The laser writes onto the drum, where the laser hits, the drum becomes conductive and discharges the positive charge. Positively charged toner particles then stick to the uncharged parts of the drum. The paper is negativley charged and the toner transfers from the drum to the paper. The paper and toner go through heated rollers (like a laminator) and the plastic toner melts and fuses to the paper.
Two main problems in conversion are,
The paper path is never straight, impossible to make it so without very major modifications.
The copper on the PCB will not hold a static charge as it is conductive.
Though if anyone does do it I would be very interested in seeing it. :)
pourcirm (author) says: Nov 18, 2011. 10:47 AM
Just wanted to post a comment and thank everyone who voted for me and viewed my Instructable. I'm a finalist in the Epilog Challenge and I really appreciate it. Here's hoping I can win and bring you more cool projects with that Zing laser cutter.
wizejester says: Nov 15, 2011. 10:31 AM
Thank you so much. I have been dreaming of something like this for a while but have been to busy (way too lazy) to go through the trial and error myself. I look forward to building one of these soon. You definitely have my vote for most awesome in show!
pourcirm (author) in reply to wizejesterNov 15, 2011. 11:56 AM
The build really isn't all that hard once you've got a plan of attack for everything and it's definitely worth the time you put in because my new boards are coming out very nicely now that I have the heating and etching problems sorted out. Hope the build goes well for you and thanks for the vote it's much appreciated.
profpat says: Oct 25, 2011. 9:23 PM
interesting!!! great work!
pourcirm (author) in reply to profpatOct 27, 2011. 12:47 PM
Thanks. It was a fun project to work on and the goal of better PCBs made it even more so.
Polymorph in reply to pourcirmOct 31, 2011. 9:26 PM
Hi, I'm moderator of Homebrew_PCBs and Inkjet_PCB_Construction on Yahoogroups, which is where a lot of the information on Massmind.com comes from.
I would suggest that you put MISPRO yellow in all four cartridges. It can be very difficult to get an inkjet printer to print from only one ink shade. More printheads printing may mean more dots filled in, too.
As for the curing, from all reports the temperature and hold time are very important. Volkan, the gentleman who first discovered this process of printing and heat curing pigmented ink, would heat it to the point where the copper just turns purple and hold it there. Others have experimented and found that holding it at 230C/446F for about 3 minutes does the trick, but that it is a very narrow window of temperature.
I just ordered a "Mini SMD Preheater" 21-10135 from MCM that is a hot air rework station, set the board on top of it and it heats between 100C and 350C, temperature controlled. My intention is to use it for pigment ink cure and SMD reflow soldering. I got it on sale earlier today for $40. A toaster oven with a better thermostat should work, too.
To the gentleman asking about using an HP inkjet printer, as you mentioned the MISPRO pigmented inks probably won't work since just about every desktop HP inkjet printer is a bubblejet and uses dye colors. However, there is the hybrid toner method - print using any ink, as long as it doesn't run, and dust laser toner across the ink. The ink stays tacky for quite a long time on a nonporous surface. Then heat until the toner turns shiny.
pourcirm (author) in reply to PolymorphOct 31, 2011. 10:31 PM
Thanks for the advice and info. I've been contemplating filling multiple cartridges, but I have yet due to the fact that I don't have any other empty ones to use at the moment. I figured that would get some better coverage.
You are correct that temperature window is very narrow. I bought that heat gun and it was effective, but so touchy to not overheat the board and to try and keep everything uniformly heated. You'll have to update me on that SMD Preheater. I've been thinking of moving to mostly or all SMD parts too, but just haven't quite committed yet. I like the idea of a dual function tool, hopefully that product works out for you.
Glad to hear more input and advice though for sure. I know you guys have quite a thread going and have more ideas and insight than I could probably imagine right now.
batmat says: Oct 27, 2011. 12:33 PM
Very well. Congratulations.
t.rohner says: Oct 20, 2011. 7:24 AM
Interesting instructable.
But the quality is not yet there...
Maybe you should try mild solvent inks.
I work with large format printers, that also use Epson Printheads.
Most of them use modified heads. The printhead itself withstands pretty harsch organic solvents, it's the plastic part on top, that needs to be of a different material. (compared to a standard waterbased printhead)
There are certain mild solvent inks, that work with unmodified Epson heads.
Used in "Freejet" nontextile printers for example.
And there are also inks with a completely different chemistry like these:
http://www.sepiax.com/anwendungen-en
What would work pretty sure, are the Roland UV-inks used for example in the LEF-12. But the price tag of those machines might be a bit prohibitive.
But i could make some experiments with different inks.
I have access to machines with many different inks. Many of them flatbed machines. Maybe i make some test boards.
ElectroFrank in reply to t.rohnerOct 24, 2011. 10:19 PM
So does this mean that an inkjet printer could directly print etchant onto a copper board ?
Then just a short wait and a quick rinse . . ? Now that would save some acid !
Hold on . . . wouldn't this cause massive unemployment in the acid industry ?
t.rohner in reply to ElectroFrankOct 24, 2011. 11:23 PM
No, definitely not.
This would etch away the printheads.
I'm just supposing a better ink for masking.
ElectroFrank in reply to t.rohnerOct 25, 2011. 2:22 AM
Now I see.   But hold the thought.  We progress by thinking outside the box.   Is there, or could there be a way ?  All plastic printheads ?   All metal parts plastic coated ?   A chemical ink that would react with something else to form an acid only where required ?
pourcirm (author) in reply to t.rohnerOct 20, 2011. 8:54 AM
Thanks for the comment. Your work sound interesting in relation to this project. I'm sure it would be helpful to not only me, but anyone thinking of such a project to have some more input or more ink possibilities. Please keep me updated if you decide to run some boards and come up with strong results.
ElectroFrank says: Oct 24, 2011. 9:56 PM
A thought passes through my mind . . .  May I plant an idea seed for people to grow ?
As there is already metallic silver paint used for circuit board repair, can a way be found to directly print metal (by some means, in some form) straight onto blank circuit board ?
Possibly by adapting some kind of inkjet printer (or plotter), using fine enough metal particles ?
Perhaps an ink consisting of metal particles in a flux, then set by briefly heating to melting point with a blast of hot air ?
If anyone can find a way, it should be extremely environmentally friendly, and would make all other prototyping systems obsolete overnight.
And this could be the website where it is first seen . . .
(And OK, if it's already been invented, well I always say, great minds think alike . . .   ;-)
pourcirm (author) says: Oct 24, 2011. 9:07 AM
Hey everyone I've posted the update I commented about yesterday. The new board came out 10 times better and has no pinholes in it. Check it out and let me know what you think.
klee27x says: Oct 23, 2011. 3:26 PM
I wish you best of luck to perfect this method and make a lot of money. In the meantime, I have made hundreds of pcb's with toner transfer, and I suffered through a lot of headache before I discovered the easy way.
Off the shelf laminator, dextrin paper, and heat gun.
Just two runs through the laminator while shooting the board with a heat gun does the trick admirably. I've tried all the papers and TBH, photo paper, magazine paper, and even the other professional papers wilt in comparison to dextrin paper (e.g. Pulsar). I went through a 100 pack of the "blue" stuff before trying the slightly more expensive dextrin paper, and I'm kicking myself for not trying it sooner.
twodotone says: Oct 17, 2011. 12:57 PM
sorry guys, it's not my intention to rain on your party, but with all the effort it takes to convert a printer to print on pcb, the issues you may encounter, the resist calibration and so on...
isn't it easier to just make yourself a UV exposure box and buy boards coated with resist?
I built one years ago then I switched to a commercial (cheap) model.
I'm the happiest champ.
I'm now etching double-sided smd-only boards and the edges are perfect.
I don't etch in FeCl anymore, now I use a 2 to 1 solution of HCl (10M) and H2O2 (3%).
it has a lot of advantages, among which no stains... but it may burn stuff... ehm...
anyway... never thought I'd be as happy with my etching, and using a (again, cheap) etching tank with air pump and heater, I etch a board in about 2 minutes.
that makes the edges very sharp.
I have more trouble drilling 0.6mm holes and center them correctly than to produce the board :)
anyway keep up the experimentation, I would love to see cheap commercial solutions.
to me laser printing acetate, UV exposure, development, etching is a fulfilling experience every time and I'll keep doing it ;)
billd6 in reply to twodotoneOct 20, 2011. 9:56 AM
twodotone - not sure if you are using positive or negative resist but where are you getting your film positives or negatives from?
twodotone in reply to billd6Oct 20, 2011. 11:04 AM
I buy pre-sensitized boards.
http://www.bungard.de/index.php?option=com_content&view=article&id=25&Itemid=76&lang=english
I tried some very expensive ones but I had really lousy results.
I expose with a UV exposure box like this one, just an older model
http://nl.farnell.com/cif/bc10/uv-exposure-unit-cip-1840/dp/1332734
then I etch in Copper Chloride in Aqueous Hydrochloric Acid Solution
http://www.instructables.com/id/Stop-using-Ferric-Chloride-etchant!--A-better-etc/
I use a cheap bubble etching tank with heater at 24ºC and if I preheat for a couple of minutes, my board is perfect after 2-3 minutes.
most of my thin traces are 0.4064 mm (0.016") and there's no visible damage to the trace edges even with the magnifier I use to solder caps in 0805 package.
I've been using this technique for the past 2 years and there's no way I'm steering away from it. :)
billd6 in reply to twodotoneOct 20, 2011. 11:25 AM
Are you placing a film negative or film positive on top of the pre-sentized board when you put it into the UV exposure system? Depending on the type of photo resist, what developer are you using to wash away the unexposed / exposed areas of the copper clad laminate prior to etching?
twodotone in reply to billd6Oct 20, 2011. 12:22 PM
hope I'm getting your question right.
I'm placing a laser printed acetate between the UV light and the copper board.
the black area is the actual trace, everything transparent will not be printed on the copper.
the developer I'm using appears like a salt.
can't remember what it is though, I always used the same.
billd6 in reply to twodotoneOct 20, 2011. 9:32 PM
Yes - you understand my question perfectly. It's been my experience that the black areas printed on acetate thru a laser printer have never been opaque enough to block the UV. As a consequence, I always get pin holes and other voids in the copper traces.
twodotone in reply to billd6Oct 22, 2011. 10:44 PM
almost forgot:
always use freshly made Sodium Persulfate.
it can still be good for a couple of days, but you'll notice the traces getting less sharp after the second day.
you may think it's the etching solution but it ain't.
it's the damn developer :)
twodotone in reply to billd6Oct 22, 2011. 10:41 PM
hey billd6
here's the last one I made.
those solder spots you see are hand-made vias.
they don't look too pretty but they do their job.
sometimes I clean them with copper braid but it can also mess up your via (been there).
the only slight defect I have on this is marked in yellow.
inspecting the acetate I couldn't see any issue, so it must have been a hole in the protective sticker.
it's happened already in the past, those guys don't exactly handle these with the care they need.
I have lots of tips on making pcb at home, but right now I only use the right equipment:
- purchased UV etching lamp (although I made my own a few years ago).
- Sodium Persulfate
- HCl+H2O2 as per the instructable I linked above
- heated bubble etching tank (I spend a lot of time calibrating the temperature every time and keep it around 32-38 (just to reduce the possibility of massive quantities of fumes)
most of the times I don't flux the board, especially when using solder paste.
I noticed that there's too much flux around when doing this.
I also apply my solder paste by hand without a screen, using magnifiers and a very, very steady hand.
hope these tips will be useful to you.
have a good day
ubi
twodotone in reply to billd6Oct 20, 2011. 10:50 PM
I'll take a picture of my latest pcb using a magnifier and will show you the result.
I'm very happy with the acetate result.
of course you have to make sure your solution is strong enough to etch quickly, or it will start eating out everything.
one trick that I used in the past when I used Ferric Chloride was to print 2 acetates per side and align them.
I also always put the printed side on the board so the black areas are effectively touching the copper surface and the possibility of UV infiltrating from the sides.
I know, it's OCD at full speed and unnecessary.
yesterday I etched (for a test) 0.01mm traces and they were more than decent.
pourcirm (author) in reply to twodotoneOct 17, 2011. 1:33 PM
It's not raining on anyone's parade. It's interesting to hear about all the different PCB making tools and procedures. When I started out with the project I obviously thought it was going to be smooth sailing as everyone hopes with their projects I'm sure, but the few little challenges have made it something I want to stick with and finish up completely. I figure once I put fourth that effort and get it all set it'll be a really easy method of print and etch.
For me it came down to a matter of wanting to try something new and when I was looking at the UV exposure stuff I didn't want to build an exposure box and deal with the sensitized boards and the developing solution when I had a printer I could modify sitting right on my workbench. It's just another case where everybody has a different preference and that's what building your own electronics is all about really.
pourcirm (author) says: Oct 22, 2011. 1:10 PM
Just a quick note to everyone. I've just completed a new board and used some of the suggestions and improvements I've come across. I don't have time right this moment to write an additional step and post pictures, but I wanted to let everyone know that the results are drastically improved. There are no more pinholes and the board is on a whole different level than the previous one. I still have to clean the ink off and take some photos, but keep an eye out because I'll be adding those results soon.
MandingaRes says: Oct 20, 2011. 2:05 PM
En general no hago críticas a ningún proyecto porque me parece que es de muy mal gusto. Al contrario me gusta ponderar las nuevas ideas y ésta en especial me parece fantástica ya que "abre la cabeza" respecto a todo lo que se puede modificar (reciclar) y darle otra una segunda posibilidad de uso a muchos elementos que normalmente irían a parar a la basura.
1)Este proyecto en particular no tiene desperdicio ya que enseña muchas cosas interesantes pero creo que el producto final (PCB) no es del todo bueno, sobre todo en la terminación y a la hora de sumergirlo en cualquiera de los líquidos elegidos, pueda quedar con faltantes de cobre en lugares críticos de soldadura de componentes.Para mi todavía no hay nada mejor que un circuito impreso por una laser (conseguí una vieja Laserjet M400 por muy pocos $ y su rendimiento es maravilloso!!)
2)Cuando uno piensa que el percloruro férrico es nocivo para el medio ambiente e intenta otros medios, hay que pensar que tan peligrosas son las alternativas.El ácido clorhídrico, el muriático así como el sulfúrico o el nítrico (generalmente utilizados para hacer el "aguafuerte" que utilizan los joyeros y artesanos para distinto tipo de metales) son mucho más peligrosos que el mismísimo percloruro, por lo que muy a mi pesar lo sigo utilizando y aconsejo por todo concepto.(Todavía no se inventó líquido alguno que podamos utilizar y luego poder tirar por la cañería sin tener remordimientos...)
3)Por último: entré en tu sitio web y pude ver por las fotos que tu caja de herramientas está "asquerosamente" ordenada!! Nunca pude tener ese orden en la mía,aunque puedo encontrar cualquier cosa que necesite(siempre y cuando cuente con el tiempo suficiente)
Muchas Gracias por compartir tu proyecto con el resto de nosotros!
(Por favor, traducir pues mi inglés es muy malo)
chasiscorto in reply to MandingaResOct 22, 2011. 3:20 AM
Translation for "MandingaRes" (which stands for "DevilRes"):
***translation begins***
Generally I don't use to criticize any project because I consider it to be rude. Om the other hand I like to consider new ideas and this particular one looks fantastic to me because it "opens your mind" about every thing you can modify (recycle) and give a second chance to thing that usually would end up in the thrash.
1)This particular project is wasteless (**stands for "very usefull" or "excellent"), because teaches you interesting things but the final product (PCB) is not all that good, specially the finishing and when submerged in any of the suggested liquids, it can result on missing copper on critic places for soldering. There is nothing better yet than a laser printed circuit (I found a old Laserjet M400 for a few $ and its performace is wonderfull!!)
2)When you think about the ferric chloride is noxious for the enviroment and try other ways, you have to think about how dangerous the alternatives are. The chlorhidric acid, the "muriatic" (**this stands for an aqueous solution of sulfuric acid), the sulfuric or the nitric (generally used to make the "strongwater" used by jewelers and artisans for different metals) are way more dangerous that the ferric chloride, that's why although beeing sorry I keep using it and adviceing the use of it (it haves not been invented any liquid that we can use and throw away thorugh the sewer with no remorse...)
3)For last: I've been on your website and I have seen by pictures that your tooling box is "disgustingly" (**this stands for amazingly, it's an irony ;) ) organized!!! I've never been able to keep mine in that kind of organization, although I can always find what I'm looking for (if I have time enough)
Thank you very much for sharing your project with us all!
(please, translate because my english is too bad)
***End of translation***
michaeloqu says: Oct 18, 2011. 10:22 PM
I can understand why H2O2 would do that. It's a very agressive oxidizer. But it's posslble to make a CuCl2 solution without using any H2O2 at all. With a solution of Cuperic Clhoride + HCl it should have a much less agressive overall oxidation rate; the primary oxidation is performed by the CuCl2 itself, not the HCl. The reaction is CuCl2 + Cu (metalic copper on the board) --> 2(CuCl).
The acid doesn't do much, except supply a source af Chlorine when the chemistri\y is refreshed by bubbeling Oxygen (Room Air works). This solution can be used forever, it just gradually grows in volume over time. Any tthoughts on using the inkjet printed board with this chemistry?
michaeloqu in reply to michaeloquOct 20, 2011. 4:07 PM
Do you know the particular temprature required to set the ink?  If not, can you finf it experimentally?  I've worked with some goops that need hear to set them, but you have to be VERY careful with a heatgun, because the blast from on will make it form bubbles on the inside, and then set, trapping the bubbles.
Perhaps curing the board/ink in an over set to the appropriate temprature for the the correct length of time would solve the pinhole problem.
We used a heat tunnel, which is basically an over with holes in each end and a conveyer belt.
MaXoR in reply to michaeloquOct 20, 2011. 10:53 PM
Isn't that called a pizza oven? I swear every pizza place around my home city uses one that is the same as you described.
Either way, figure that might help others understand what you meant.
michaeloqu in reply to MaXoROct 21, 2011. 1:15 PM
Yep, except that some pizzza ovens are huge stone slabs that can be rotated like a lazy susan.  Tends to be used in the larger establlishments  or those that sell "Gourmet" or ':Authentic Old World"  pizzas.  I think the smaller establishments may have a smaller  ovet that has several stone shelves, but doesn't rotate.  (At least out here on the west coast,)
Good comparison though.
Quiznos Subs ovens are similar too.
pourcirm (author) in reply to michaeloquOct 19, 2011. 9:33 AM
Using some different etching solutions in tests is definitely on my list of things to consider. I've put together a heated and aerated etching tank over the past few days and still have a good quantity of ferric chloride on hand so that's my first plan, but if that doesn't give me the results I'm looking for this new solution will definitely be on my list of things to look into further.
e5frog says: Oct 20, 2011. 12:02 PM
The idea was good, the final result not really that good unfortunately.
What's the best looking card you have made so far?
Are there other inks that could be used?
What if a wax ribbon printer (or other transfer type printers) was used... resolution high enough?
pourcirm (author) in reply to e5frogOct 20, 2011. 12:20 PM
I'm still working to improve the quality so I'm not sure what the best looking PCB will or can be, but currently my best result is the one featured in a few iamges that has the pinholes in it.
There have been a lot of ink suggestions I've seen and I'm trying to look into the availability of some of them for later if I can't get the results I'm hoping for with this ink.
e5frog in reply to pourcirmOct 20, 2011. 1:33 PM
It's a nice idea being able to put just the needed ink out on the copper instead of buying (more) expensive boards, make masks, use uv-light and chemicals to dissolve most of what was put on there. I would try a second print after it had dried, just to try and get rid of the holes in the copper. Really quick prototyping!
Perhaps you could have an electronic heater below the moving plate, so you'll warm it just enough while printing and just where you are currently printing? Easier to adjust as well instead of the heat gun.
It's perhaps possible to make a micro-etch before printing, which means you etch it very little so you'll get an even and matte surface to print on.
You could glue a support for one corner on the metal plate, so you always find a correct "zero point". Could be as simple as epoxy a piece of pcb with an internal 90 degree angle (L-shape). Then you don't have to use so much scotch tape.
If you find some other colored inks you could also print solder mask (green or other color) and silk screen print (white).
Great work, I hope we'll see more of this.
michaeloqu in reply to e5frogOct 20, 2011. 3:27 PM
One problem with print a seco0nd coat is the possibility of overspray, making fat traces. This could be overcome by slightly an image that is slightly "thinner." The printing industry has been dealing with this problem for centuries. Photoshop has tools that will slight "shrink" theedges of your image, in anticipation of the fact that, when printed on a press, the ink will spread a little, In this case, it would ley you add a second coat without the risk or overspray. Just something to think about as people tweak their printers.
eelectronica says: Oct 20, 2011. 2:16 PM
since i first saw the DTG (direct to garment) EPSON hack on HaD 1-2 years ago i wanted to have a DTG/PCB printer so i took one of my C86 apart today and raised the whole print mechanism 16mm (i figured that should be enough to also allow tshirts, etc. to go through. )
i still have to build a 16mm caddy for pcbs and one for tshirts/other stuff.
if someone is interested here some pictures. i basically used the same methods as being described here. the only thing i had to add was a wooden spacer for the 3 pressure wheels to prevent them from falling out if there's no spacer inbetween. since i gonna use a caddy i thought i will leave the middle pressure wheel in place sicne the caddy will have an even surface.
thsi instructable finally got me started with that project - thanks!
regarding inks: what about using 2 component inks? first put one layer of chemical on the copper board, then print the second component on there. the non-printed area won't react so before etching you could remove it. these inks do exist but i couldn't get my hands on them yet (restricted use i guess) any ideas? (there's a 2K epoxy system based on epson printers, specialprint.eu i think)
does anyone know where to get new printheads btw?
just the printhead whcih is fastend with the two screws
pourcirm (author) in reply to eelectronicaOct 20, 2011. 2:27 PM
Hack a Day is actually where I first saw the idea as well and I spent around a year just looking at this printer thinking I should modify it. Glad you've done a modification as well. I like the wooden spacer idea you used to keep the pressure rollers in place. I may have to look into that as mine fall off occasionally when there's no material in the printer. I was thinking about gluing them in place, but the wood may be a better idea.
I've heard a lot of suggestions about various types of inks in numerous comments both here and on Hack a Day. I think this is a project where you could go about doing it in so many ways that I'm having trouble keeping up with them all. I've got a full page of ideas to try right now for better PCBs and I hope one of them works out as I expect something will.
eelectronica in reply to pourcirmOct 20, 2011. 2:57 PM
i bought some inks and will report back in a few weeks with some results. preetching the copper to make it matte (like suggested here earlier) could be a good idea indeed. in a different context i was using this method to write on copper.
one thing i forgot to mention:
people when copying this make sure the print head docking station is in place and centered properly => if it doesn't work (or the pump doesnt work) the printheads will be clogged in no tiime.
that's actually the only flaw in that DTG HaD hack we refer to => there was no pump connectted.
on the other hand you could remove the pump and always flush clean the printhead or propably apply some duct tape after usage.
oh and i used M4 hexagon bolts to be able to fasten them really really strong. thinking of adding a few drops epoxy glue on top now.
perfo says: Oct 20, 2011. 6:47 AM
Good work there. It is something I’ve played with myself but really thinking it would be good if possible to actually mount the Dremel with a fine routing blade on to the carriage instead of the ink cartridges and actually mill the PCB. Gets rid of the chemical step.
e5frog in reply to perfoOct 20, 2011. 1:36 PM
You'd get very uneven edges, tool wears out quickly and it's very tricky making small pads as they might just fly off from the force of the blade... I've seen it done a few times, not pretty but works for pcb:s that has no small traces and such.
pourcirm (author) in reply to perfoOct 20, 2011. 8:47 AM
I am actually actively working on trying to plan out a homemade CNC machine. My goal is to create the PCBs with this method and then trying to program the CNC to drill all my holes for me. If I can accomplish that I'd have an almost completely automated system for creating my PCBs.
perfo in reply to pourcirmOct 20, 2011. 11:42 AM
If you make a home CNC then why bother etching? A milled board would be better. I've fiddled with cnc contraptions using the motors and drivers out of a printer but it still seems to me providing you can get enough torque it should be easy enough to convert a printer in to a CNC. The trick would be to intercept the print on signal to move the Z axis. So when it thinks it is printing black it lowers the miller and cuts. Use the colour cartridge as the drill and black as mill then it would do everything just by colouring the PCB template.
pourcirm (author) in reply to perfoOct 20, 2011. 12:01 PM
The main reason I'm working on this project is because I had everything on hand basically and the cost was really low. I'm currently job-hunting so I don't have a large CNC fund at the moment. I have the motors and driver board which I've purchased over time, but I don't have the money to throw in on the rest of the parts currently. I figured if I could make better PCBs with this printer for a while it'd be worth the effort and the project gives me something to do with a bit of spare time.
I do like your thoughts on a printer CNC combo though. Might take a bit of work and planning, but it could be possible if you could intercept the right signals and program them into a driving circuit for the Z axis.
chasiscorto in reply to pourcirmOct 21, 2011. 2:48 PM
Hi guys! There's a lot of useful information around here. Thanks for doing some like this, is very interesting and encouraging to see someone getting onto this and publishing how to do it. I'm working on a desktop CNC router myself for a while now and my first approach was using printers' stepper motors and print head's rods to build it. I found some problems with that approach and I'm using a different one now using steppers from sparkfun and drawer's rails. I don't know how would it be that of making a z axis "add-on" on a printer but I suspect this author will do some like that later (and I'm hoping to see it). Now, I know I prefer to use the router I'm building to mill and do the drillings of my PSBs but doing the silkscreen with this modded printer sounds great, don't you think?
ddparker says: Oct 20, 2011. 12:08 PM
I need to comment on your terminology, screw aka bolt, nut is what your spacers are.
pourcirm (author) in reply to ddparkerOct 20, 2011. 12:23 PM
You are correct. Thanks for pointing that out. I wrote a few of these pages late at night and they've got a lot of information packed in them so I expected people to point things like that out over time.
tcarney57 says: Oct 20, 2011. 12:07 PM
An excellent effort!
I might add one suggestion with regard to etching times and sharpness. I used to work for a university research lab making proto boards. I had worked previously in large-scale PC production, so when I found the lab's habit was to use 2oz copper, I tried hard to convince them that 1oz was entirely adequate and that it would allow for sharper and narrower traces. I pulled out my trusty copy of Coombs' Printed Circuit Handbook (then--and maybe still--the PCB equivalent to the Bible) to prove the sectional area of even 10 mil sneak-through traces ("dog bones") was good up to 1.0A--far more than any digital (or even most analog) circuits require. Nothing doing, they said.
So, if you have a choice of material, my suggestion is that you choose 1oz clad when possible. I always used catalized persulfate etchant (@ 120°F) and it worked very well with the 1oz material. Yes, about 2 minutes in a spray-type etcher.
pourcirm (author) in reply to tcarney57Oct 20, 2011. 12:21 PM
The 1 oz clad is definitely the best choice for this I agree. It etches the most evenly thus far and I'm hoping with some of the improvements I'm making I can get some perfect boards going this weekend.
buteman says: Oct 20, 2011. 10:37 AM
Like this, although I don't think I will try it as have a HP printer spare. Just wonder if you might use a piece of double sided board as your spacer which might give a more precise clearance.
wa7jos says: Oct 20, 2011. 7:18 AM
How about a hybrid solution between this and the TTF method?
The key to the TTF method is the second step of adding the green TRF paper on top of the toner.
Will the TRF stick to your resist ink? If it will, that should greatly improve the quality of the traces.
The other thing TRF does is make the resist VERY tough. I etch using a small sponge and just rub the ferric chloride across the board rather than the "bath" method. I can get through 1 oz copper in about 5 minutes this way, and you can watch the process and apply etching where it is needed. I get great results down to 8 mil traces with hardly ever a void.
pourcirm (author) in reply to wa7josOct 20, 2011. 8:50 AM
I've seen a few people online post hybrid methods before and it's something I've considered as a late solution to my pinhole problems, but I'd really like to create something self contained and automatic. It's a solution to consider though if things don't go as planned in my next few tests here.
As for the etching I've built a new heated and aerated etching tank this week to try and get a more consistent etch, but if I have problems with that the sponge method is something I'm going to try.
kidharris says: Oct 19, 2011. 11:06 PM
Did you check your printer settings to be sure that you are printing in the best quality possible?
Have you tried reprinting it 2 or more times to make the ink thicker?
pourcirm (author) in reply to kidharrisOct 20, 2011. 8:45 AM
I've tried a few different print settings and finally settled in on the ones that give me the best quality. If I use the Best Photo quality on a paper type of matte I think it was then it lays down a thick even layer of ink printed very nicely. I am considering double printing it though as a test further down the list of things to try.
As for the aluminum or possibly steel I'm just going by what I was told it was could be either I'm not 100% sure.
kidharris in reply to kidharrisOct 19, 2011. 11:14 PM
PS. Your anodized aluminum sure looks a lot like galvanized steel to me.
If you check out some engraving supply sites they sell a thin double sided tape that releases easily for holding down your boards that may make setting up easier.
behael says: Oct 19, 2011. 12:54 PM
It is a very nice instrutable. But I have question/doubt: In order to avoid pinholes, have you already tought about printing it twice (a thicker ink layer)? Or another kind of ink, like sublimation ink (from thermo sublimation transfer process)?
pourcirm (author) in reply to behaelOct 19, 2011. 1:08 PM
I have a whole list of things I'm hoping will get rid of the pinholes. First is trying an accelerated etching to see if that stops the ink degradation. I'm getting good coverage of the board once I tweak the print settings right, but double printing and other inks are on that list a bit further down if some of the earlier solutions don't work right away.
eelectronica says: Oct 18, 2011. 5:28 PM
Thanks for writing this instructable.
I've been using the C86/C84/C66/C64 printers for a long while now since they are cheap and easy to resurrect/clean if you know what you need to do.
You did a good choice using the C86 (the flasgship of that series) sicne you can completely take apart the print head (see photo attached) and clean it, no matter how clogged it is. It's not much more efford than the method you used but you'll be able to get all dried ink from inside the head to avoid future clotting.
I really really recommend a strong ultrasonic cleaner. without ultrasonic it will be hard to free completely clogged heads.
then even more important then cleaning the heads:
clean the vacuum pump (!!!!!!!) with 30% of all the C86/C84/C66/C64 printers i got (i have 20) the vacuum pump tube was clogged with a solid mess of dried ink. not cleaning the pump will result in clogged nozzles in no time.
Also regarding the printing process: if you use the printer solely for PCB printing and want more ink applied, put ink in all 4 cadridges. also an interesting but little known fact is that you can change the amount of ink being printed by fiddling around with the driver settings. i think i used the "OHP transparent" setting in windows combined with some other mode. now i use linux and it's easier to set how mcuh ink is being printed out.
just my thoughts.
thanks for writing this instructable, i really know how mcuh work you put into this. it convinced me to finally mod my C86 printers for PCB/t-shirt printing.
pourcirm (author) in reply to eelectronicaOct 19, 2011. 9:31 AM
Thanks for all the suggestions and service information that should really help me keep this thing running for a long time. I may also have to look into filling all 4 cartridges at some point.
rewolff says: Oct 18, 2011. 7:05 AM
2.8 mm copper is REALLY thick. That'd be about twice the thickness of the board.
You need to redo your math on the metric copper thickness. (I think you mean 35 um (micrometer))
pourcirm (author) in reply to rewolffOct 18, 2011. 10:04 AM
Yea I messed that up for sure. I rewrote that area a few times late at night and must have been thinking or doing something else when I wrote that. The boards would never come out right if the copper were that thick.
raalst says: Oct 18, 2011. 2:01 AM
Hi, nice project !
I wondered : can you not put the acid directly on the board ?
maybe the print head can tolerate the acid. the plastic probably can.
that way you would get rid of the masking and instead of pinholes you would have (maybe) just isolated islands of copper. but the actual connections would be
untouched copper, and be 100% no pinholes.
pourcirm (author) in reply to raalstOct 18, 2011. 10:02 AM
That's an interesting idea, but I don't know that this printer could handle it. When you look at the underside of the print head there is actually a metal plate that has tiny holes that the ink is being pushed through. I think if you tried to print the etching solution it would eat away at this plate and ruin the printer.
ozadr1an says: Oct 17, 2011. 4:15 PM
Nice - I have a half modded epson from a while back.. got Page Registration Issues so haven't finished it. The Epson Durabrite works nicely because its a Plasticised Ink, not a 'normal' ink.
BTW, to help with the undercutting during etching, try using the "Sponge Method" on this page http://www.pcbfx.com/main_site/pages/tech_support/no_etching_tank.html ... It works really well for Toner Transfers etc and hardly undercuts at all and works in less than a few minutes...
Just a thought...
pfred2 says: Oct 16, 2011. 12:48 AM
I got to ask. Why'd your "success" board have all of those pinholes in it? Is it the resist, or OK forget it just tell me how long you're etching a board. That'll tell me all I need to know. How many minutes does it take you to etch a board from when you drop it into the tank?
pourcirm (author) in reply to pfred2Oct 16, 2011. 10:25 AM
I was definitely expecting this question to come up at some point so thanks for asking it. Truthfully I think it's mostly the resist. I'm only etching the boards for about 15 minutes maybe less. The resist is strong enough as you start the process, but as you approach that 12 to 15 minute mark those pinholes start to sneak through and the middle traces of the board still were not completely etched. I'm actually looking at building a better etching tank or a new etching method as my next project to avoid those pinholes. With that said I did test the traces on the board with a multimeter and the pinholes don't cause issue with the continuity of the circuit so it is a successful/usable board.
I could probably write quite a bit more about this too if your still curious let me know. The project is definitely something I'm still working on and trying to improve I just thought the information was worth getting out there.
pfred2 in reply to pourcirmOct 16, 2011. 11:44 AM
You should be doing etches in about 2 minutes. Heat your bath and aerate it. 15 minutes there is definitely a problem. I talk a little about my bath setup here:
http://www.instructables.com/id/GM-Arts-Overdrive-Pedal-Build/step5/Acid-Rocks/
Continuity is nice but on some circuits jagged edges can cause interference, like signals use spiked edges to radiate out of. Plus it just looks bad.
pourcirm (author) in reply to pfred2Oct 16, 2011. 11:50 AM
Wow I didn't realize the time was that off. I haven't used Ferric Chloride before this project so that seems to be where my problem is. When I have some free time here next week I'm going to try and get a heating rig like yours together and see what kind of results I get then. Hopefully I can get an even better board for my Instructable.
Thanks for the help.
jmsaltzman in reply to pourcirmOct 17, 2011. 8:02 AM
I don't think aeration or temperature are the problems; they just speed it up and make it a more involved (read: potentially messier and more dangerous) process. I etch with ferric chloride or with HCl and peroxide and just swirl them around until the exposed copper is gone-- keep your eye on the biggest open area of copper and a few lines between traces and wait for them to go, and you're fine.
You might try adhering the resist ink to the copper better by ironing it or putting it through a laminator, wrapped with cheap magazine or catalog paper-- what other folks (like me) print onto when doing toner transfer-- since toner doesn't like sticking to the paper as much as to the copper. (This assumes that your resist ink acts similarly, which I don't know ;) Or, have you sufficiently roughed up the copper, with a light brushing of steel wool? That both helps the resist adhere and speeds up the etching.
pfred2 in reply to jmsaltzmanOct 17, 2011. 11:15 AM
There is nothing I can say here. This is beyond me.
pourcirm (author) in reply to jmsaltzmanOct 17, 2011. 9:42 AM
I think the situation is a combination of the etching time and the resist ink that I'm using. The ink doesn't act quite the same as toner transfer it's actually a liquid heat set ink so I'm using a heat gun to set it really well. When the print is set the coverage is really good and even over the copper. I've cleaned the copper with a Scotchbrite pad too so it's roughed up nicely. I think the problem lies in the length of time spent in the etching solution because when I first put it in the ink is completely covering the copper areas, but the longer it's in the etching solution as I'm waiting for those last few traces to clear up as you said those pinholes start to form.
I'm going to try a few things this week to see if I can get rid of the pinholes and I will definitely update everyone and the Instructable.
michaeloqu in reply to pourcirmOct 20, 2011. 3:48 PM
pourcirm (author) in reply to michaeloquOct 20, 2011. 3:54 PM
That's one of the things I'm working on right now actually. I found some sources that said for proper heat setting of the ink I needed to hit around 220 C which I am definitely not hitting with the heat gun. I'm looking for something cheap to use to get the board to that temperature right now as I'd rather not put it in my home oven and risk something happening to it. I'm thinking either a cheap toaster oven or some type of electric skillet are my best options right now.
pfred2 in reply to pourcirmOct 16, 2011. 1:16 PM
Heat your bath up until it fumes a little about 110F and get some air blowing in it. I hear putting some citric acid in it can make it a lot more aggressive too but I haven't tried that myself. Just heating it and pumping air into it has made it work a lot better for me. Any etch that goes past 10 minutes gets undercut.
parasite66666 says: Oct 17, 2011. 10:26 AM
I've got a C86 sitting around, guess what i'll be using it for ^^
Regarding the "right" ink: How important is the ink type? I live in Germany, so shipping from inksupply won't be cheap. I do have a chip resetter, so would generic pigmented ink be sufficient, too?
pourcirm (author) in reply to parasite66666Oct 17, 2011. 10:55 AM
I've heard of some people using the standard Epson yellow and magenta ink cartridges, but I haven't tried this myself. The key from what I read seems to be that you want a pigmented ink because it almost mimics the toner used in toner transfer. Once you print with the pigmented ink you heat set it so that it forms an almost toner like layer over the copper.
Also this may help. This is a group in Germany who posted a comment on Hack a Day about their similar project and what ink they used. http://shackspace.de/wiki/doku.php?id=project:beta-layout:pcbprinter
Agent24 says: Oct 17, 2011. 7:44 AM
Might help the print quality to use a different driver, such as the one mentioned here: http://tech.groups.yahoo.com/group/Homebrew_PCBs/message/28722
pourcirm (author) in reply to Agent24Oct 17, 2011. 9:42 AM
Thanks for the suggestion I'll look into it.
rimar2000 says: Oct 15, 2011. 8:32 PM
Great instructable, congratulations!
pourcirm (author) in reply to rimar2000Oct 15, 2011. 8:37 PM
Thanks I was hoping people would enjoy the project.
Honus says: Oct 15, 2011. 6:00 PM
Awesome job! I too had read about this a couple of years ago but never got around to tracking down a suitable printer to modify. After reading through this I might have to revisit the idea. :)
pourcirm (author) in reply to HonusOct 15, 2011. 8:37 PM
Thanks a lot. I was in the same situation for a while just thinking about the possibility. I would definitely say go for it. That's the whole reason I documented all the steps I was hoping to help others get similar results. I'm looking forward to creating a lot of PCBs in the future with it.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
