Converting an Inkjet Printer to Print PCBs
 by pourcirm
FeaturedContest Winner
Step 2: More Removal of Parts
After removing all the covers there are some parts that you should remove and set aside for later. You'll need to relocate the paper feed sensor because the feeder no longer sends paper in from the top rear of the printer. I'll talk more about how this system works later, but you'll want to remove that sensor from the back of the printer and unplug it from the circuit board. Set this aside and we'll work more with it later.
Next up is the pressure wheels in the center of the printer. You don't really need all three sets and the center set could cause clearance issues when you send a circuit board through the printer. So to avoid this problem I simply removed the roller leaving a clear area for the circuit board to pass through.
Finally you'll want to remove the print head cleaning station. You'll want to be careful here! This station simply pops out from the press fit connectors it's sitting on, but it will have a tubing system connected to it. This tubing is necessary so make sure not to break it or remove it. Once you have those three things removed we can start looking at the heart of modifying this printer, the lifting process.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
