Convex Glass Tile from Bottles
 by asdterror
Featured
Step 1: Jig? Yes Please!
There are really good bottle cutting jigs out there, but I loath to purchase, store, and ultimately yard-sale a specialized tool.  So here is the simple, flexible, and repeatable setup I use to cut glass cylinders:
Scott1975 says: Jan 6, 2013. 3:27 PM
If you used a polyurethane expanding foam, Like maybe a six or eight pound mix, after the bottom and top of the bottle have been removed. That should give it enough support and fit snugly enough. If you fashioned a handle with wood it would give better leverage and could be reused on the same sized bottles.
TJBrooks says: Jan 6, 2013. 6:33 AM
We recently acquired a wet tile saw and want to use it to cut glass wine/liquor/beer bottles into uniform tiles for a kitchen backsplash. It came with a 10" continuous rim diamond blade. It cuts tile very well. Our results of cutting bottles are as follows:
1) thin walled wine bottle chipped/fractured
2) medium walled wine bottle cut fairly well until last 3/8" which cracked and left jagged protrusion
3) thick walled champaign bottle cut through very well with only minor roughness
4) pre-scoring by rotating the bottle before pushing it through the blade might have helped but there were too many other variables to state a definite result. Rapidity of the it seemed to make little difference in the result of any of the above cuts.
We viewed a few you tube videos online before attempting this experiment. Since our results were disappointing we are seeking your guidance.
1) are there special blades you would recommend for bottles?
2) are there any tricks of the trade for cutting stops from bottles for backsplash tiles? The thick champagne bottle was the only one we successfully cut strips from.
3) what material would you recommend we make a bean bag out of to support the bottle necks to eliminate movement throughout the cut?
Our goal is to have multi-colored 1"x2" tiles.
Mindmapper1 says: Sep 19, 2012. 6:22 AM
when i was taught to cut glass many years ago i was told that the idea of the oil was to keep the score line open. as far as i understand things glass is technically liquid and the oil works like putting oil on a stick and running it through a puddle the oil will top the water molecules joining back together. anyway whatever the oli does it works!
keeping the cutter in oil when not in use is also a good idea.
shuja.shaher says: Jan 13, 2012. 9:16 AM
great!!!!!!!!!!!!
once you make a bottle to a tile world of options open up
I am not good at glass work
but I am rearing to go
lemonie says: Jan 10, 2010. 3:57 AM
Where do you use the oil? You mention washing it off, but I don't see where it comes in.
L
RadBear in reply to lemonieJan 10, 2010. 9:34 AM
You would use it to lubricate the cutting wheel of the glass cutter.
lemonie in reply to RadBearJan 10, 2010. 12:14 PM
A very small drop. Glass-cutters break-up the surface by localised pressure, I guess an oiled surface would retain the glass-dust?
L
RadBear in reply to lemonieJan 11, 2010. 3:36 PM
I typically roll the cutter blade through a small puddle of oil ( a couple of drops) to coat it lightly. I'm sure it retains the dust but my understanding is that the oil keeps the blade from getting snagged in the score mark it has just made so you can score the glass in one continuos motion. If you score glass multiple times it doesn't break cleanly.
lemonie in reply to RadBearJan 12, 2010. 12:06 PM
Oh yes, one cut only.
L
bricabracwizard in reply to lemonieMar 15, 2011. 5:45 PM
The oil also keeps the blade edge sharp for longer
DreMMoore says: Feb 20, 2011. 5:01 PM
I cannot wait to try this out! I have collected various blue and green liquor and wine bottles to make a kitchen back splash in my house. When I have time to get it started I will post my pics. Which leads me to a question: Has anyone tried using thinset or some kind of mortar to attach these tiles to a wall? I'm wondering how well they adhere since there is come curve to the glass.
arkrite says: Jan 27, 2011. 3:35 PM
Brilliant instructable and also everyones ideas about different effects. The waste is what I really want to comment on. The bottle bottoms can be laid within a square frame and epoxed together to for an old English cottage style window, like something out of Hansel and Gretal.
Has any one any ideas for the tops??
asdterror (author) in reply to arkriteJan 27, 2011. 10:56 PM
I've thought it'd be pretty cool to wire a TON of them as a kind of chandelier-- one small bulb or LED with a short lead into a single junction. Like a flower.
Some people have talked about modifying this method-- post pics!
arkrite in reply to asdterrorJan 28, 2011. 3:16 AM
Lol..Brilliant. Can you aimagine a bottle room. Windows, lights and walls. Using clear, painted clear, browns and greens and maybe and with a certain amount of difficulty, embossed bottles!!
I still got a ton of work to do on my Land Rover and to rebuild a Lowrider, so I will so enjoy doing thid sort of stuff when I've finished. Thanks for a super Instructable.
TheMightyBeagle says: Jan 26, 2011. 6:13 PM
That's awesome. I had to buy that same glass cutter for another project I was working on. My husband and I are buying our first house now and i've been tossing around kitchen backsplash ideas but i'm a bit of a cheap skate. I love this idea. I might have to try this out. Might take afew cases of beer to get enough tiles for the entire backsplash but I'd take drinking beer and playing in the garage over emptying my wallet any day.
thickneckarts says: Jul 12, 2010. 7:37 AM
I find that my bottles end up with long vertical cracks, from where the bottle was scored, after I heat and cool to separate the 2 parts. This happens more often than not and I have tried just about every "way" to separate the 2 parts with less stress than the previous "way" I tried. Any advice?
fretted in reply to thickneckartsJan 6, 2011. 7:56 PM
http://www.greenpowerscience.com/BOTTLECUTTING.php3
Maybe you could get some ideas from this guy he uses water to cut his bottles
DriX in reply to thickneckartsDec 30, 2010. 12:28 PM
Try without the cooling. I just heat the scored line with a candle, rotating the bottle as I do that, when I see that it's all cut (you can notice the cut done if you look trough the bottle) I just take the two parts and make a little force to separate them with my hands.
I've used that method and it worked from the first time!
asdterror (author) in reply to thickneckartsJul 13, 2010. 7:44 PM
Describe your method, please. Your outcome is unfamiliar to me.... Score once, heat and cool evenly. That should do it. How many bottles have you tried? And have you been using the same tool for each attempt? Try to find a common denominator.....
coopgrl88 says: Dec 22, 2010. 7:24 AM
If you wanted to go a step further, i suppose you could slump the glass to clean it up. Have some kind of metal mold and put the pieces in a kiln, Could make for a different affect. I really do love what you have done, though :)
jomac_uk says: Dec 16, 2010. 10:25 PM
Many years ago, i helped out in a small factory that fitted new gun assemblies to the old fashioned CRT's These tubes were laid face down and near the pin end of the tube neck (like a small bottle) it was scored all the way round the circumference with a glass cutter. Then a home made tool that consisted of a loop of wire, like an upside down letter "U" with the ends connected into a terminal block was used, this wire loop was heated with a low voltage electric current until almost white hot and hooked around the tube neck whilst the neck was slowly rotated until the glass cracked on its own!
I dont see why the same principle cannot be used here?
ferjanyen says: Dec 15, 2010. 9:40 AM
I like this. I cut botles by wraping a few turns if cotton string over the mark, soak the cotton with metholated spirit and ser alight, when hot, after a min or so i dunk the bottle in cold water and it will crack jus on the mark, good luck!!!
(use safety gogles and gloves please)
paqrat says: Dec 15, 2010. 12:33 AM
Oh, forgot to say this before but this is a very, very cool instructable. Good job.
paqrat says: Dec 15, 2010. 12:30 AM
Some months ago I read of a new product called Looking Glass. It is a spray "paint" that puts a mirror finish on glass. On the inside of glass, making it a mirror. Assuming it works as stated wouldn't it look great on these tiles? I have purchased a can of the stuff but I haven't had the chance to try it out yet so cannot say if it works or not.
camp6ell says: Dec 11, 2010. 6:18 AM
i really really like this. do you have any pictures of the tiles installed and grouted?
Brad I. says: Dec 9, 2010. 6:37 AM
What about safety of the finished product? Is there a method to prevent people from getting cut if they touch it?
halmars in reply to Brad I.Dec 10, 2010. 9:25 AM
Just rub the sharp edges with another piece of (offcut) glass. This will dull the edge quickly at no cost no tools. The bottle neck will provide a handy handle but think safety and wear suitable gloves.
Beergnome in reply to Brad I.Dec 9, 2010. 6:42 PM
Emory cloth should cut down the feather of the glass. also, a dremel tool with a sanding wheel could do the job
Transquesta in reply to Brad I.Dec 9, 2010. 11:47 AM
I would imagine you could 'tumble' the glass in a drum, but you'd lose the distinctive transparency. That leaves individual sanding/filing. :-)
enforcer72 says: Dec 9, 2010. 6:40 PM
I remember cutting and shaping test tubes in high school with a propane torch (much to my father's displeasure as the little propane tanks were expensive back then for the amount of gas you got). I had a good amount of luck scoring and even basic glass blowing using them, but had trouble with them if I tried to heat a large section with the torch, the delineation point of heating would cause problems with the temper of the glass I believe. Causing different characteristics of the glass. some would shatter at the slightest pressure, some were fine and just could not be reshaped. I did find an old propane torch and make a fan attachment to spread the heat, but found an oxy-acetylene torch with a makeshift flame spreader worked well (until I accidentally hit the trigger and blew it apart., I was 14-15...). excellent Instructable and I could see the use for this in remodeling to reuse and re-purpose bottles especially in states without return deposits. I would love to make a backdrop for my counters out of the green bottle pieces.
vincent7520 says: Dec 9, 2010. 11:17 AM
I'll save this idea !…
I also saw a transparent wall made from the bottom of wine bottle … this was pretty interesting, especially because the owner used green, yellow and blue bottles …
(blue wine bottles are very rare these days : they used to sell white wine in Paris 50 years ago or before …
Transquesta in reply to vincent7520Dec 9, 2010. 11:45 AM
Several variants of reisling comes in blue bottles--most of which would be usable for this purpose. :-)
Dweevil says: Dec 9, 2010. 11:06 AM
A crinkled (variegated & cheapo) goldleaf on the back would give bright, changing effects under different lighting.
lotusduck says: Dec 9, 2010. 7:40 AM
Glass tiles at the hardware store just have colored paper taped on the back. If you wanted a variety of green shades or if you had a lot of clear bottles, that could probably work. Spray paint is a good idea obviously, but if you wanted a lot of different colors, it's easier to have a bunch of colors of paper than paint.
Karinsart says: Dec 9, 2010. 7:21 AM
Brilliant!! That turned out really well. I wish I needed to tile somewhere!!
Twetwe says: Dec 9, 2010. 7:19 AM
you can also get a frosted spray paint for glass.
rory_woj says: Dec 8, 2010. 10:02 AM
Very cool. Ive been wanting to do a green glass tile backsplash for a while but couldnt find the right color/price combo. This might just do the trick! Thanks
patricianorma says: Dec 8, 2010. 8:52 AM
That is an awesome idea!
Treasure Tabby says: Dec 7, 2010. 10:17 PM
Oh neat-o and my dad just got one of those cutting wheels to cut I guess tile and other things too. What a recycletastic idea. :D
JuiceWeasel says: Jul 28, 2010. 2:22 AM
To create a frosted effect, you could also sand blast the back of the tiles. Great idea Thanks muchly!
frazeeg in reply to JuiceWeaselDec 5, 2010. 6:53 PM
They also make a paste called Armour Etch that will give glass a frosted look and will probably be less expensive than going to a sandblaster.  Just paint it on, let it sit for a few minutes, and wash off.
I will admit it might be a little tedious with a bunch of tiles though, and sandblasting will go quicker.
jptrsn in reply to frazeegDec 6, 2010. 6:16 PM
Maybe etch before you cut up the bottle? Wash bottle, pour some in, swish it around, rinse, and you're set! Less tedious than individual tiles, and possibly cheaper than sandblasting.
frazeeg in reply to jptrsnDec 7, 2010. 8:38 AM
Unfortunately the Armour Etch won't "swish" around since it's a paste. It has the consistency of toothpaste. Diluting it to achieve the right viscosity wouldn't work either since the paste has to sit and work on the glass and if it was runny enough it would just slide down and collect in the bottom of the bottle.
Mr.Sanchez says: Dec 6, 2010. 9:28 AM
Helll...yeahhh...i know the "Click" that you were talking...it sounds like Glory...
drewgrey says: Dec 5, 2010. 5:55 PM
I have been looking at glass tile for years and loving them ......except for the price. Thanks for a great solution.
arkar07 says: Nov 24, 2010. 4:14 AM
Good your idea
foobear says: Jan 14, 2010. 9:13 PM
I'd like to see a video of someone using a glass cutter.  Especially the showing how the glass separates part.  I've never had success with them.
This is very cool, thank you
peapeam in reply to foobearNov 17, 2010. 2:38 PM
Look at this video, it probably clears up some things for you (there are lots of videos on YT):
http://www.youtube.com/watch?v=sFXngPx3w3M&NR=1&feature=fvwp
Hope this helps!
cerberustugowar says: Jan 10, 2010. 12:47 PM
neato.   would take a long time to do,  and it would look good if you would smooth up the edges.   Do you think that you would end up seeing air bubbles under the tiles if you left them unpainted ( since you would be spreading the adhiesive with a groved trowel).  be one heck of a story though if you did it all up...  "yeah   i made those tiles out of bottles and I tiled the whole back splash."
asdterror (author) in reply to cerberustugowarJan 13, 2010. 11:09 AM
One's home should be full of stories!  And they shouldn't begin "Pier One was having this sale...".  A home is like the album collection of Rob Gordon in "High Fidelity".  ie: "I got that Technics at a town-wide garage sale in Iowa while on the way to Devil's Backbone (where, whilst wading to the climbing site Mike's nose piercing got infected).  The 103 year-old-couple also threw in some NOS vacuum tubes that were later inspiration for this one etc etc"
Lemonie-- I mentioned using cutting oil in a photo.  I should repeat the instruction in the text above to make it easier to skim the 'ible, and to help people avoid missed instructions.
fritsie123 says: Jan 10, 2010. 3:53 AM
Would it be possible to heat the glass 'tiles' enough to make them flat? Or is that not possible without a professional setup?
ironsmiter in reply to fritsie123Jan 10, 2010. 11:07 PM
heating them up till they lay flat, called "Slumping", isn't the problem... it's the controlled cool down. Both parts are actually best done with a computer controlled kiln, but if you're LUCKY, or very attentive, and have all weekend to watch a kiln cool.... it can be done.
Avoid the "air bubble look" simply by back-buttering the tile, before setting.
Depending on how the break goes, the grout may cover all signs of sharp edges. ESPECIALLY if you're setting the tile in concrete.
lemonie in reply to fritsie123Jan 10, 2010. 12:21 PM
This is one old way of making flat-glass. You put them in a kiln, so if you can make one hot enough you could do it.
L
Kiteman in reply to fritsie123Jan 10, 2010. 5:38 AM
You'd need a furnace or kiln so that they get heated evenly - a blowtorch would cause uneven heating and shatter the glass.
Good idea, though.
peapeam in reply to KitemanNov 17, 2010. 2:41 PM
If somebody should go for that for flat tiles, wouldn't it be easier to cut larger pieces, then divide into separate mosaic tiles after it has been flattened? Just a thought, I have no experience with this (not yet, anyway :) )...
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
