iImage Information
My plan was simple. I wanted to cut up a wall-powered LED light string into pieces then rewire it to run off 12 volts. The alternative was to use a power inverter, but we all know they are terribly inefficient, right? Right? Or are they?
Step 1Figure out the voltages of each LED color
iImage Information
I was all set so I set to figuring out how to split up the string. I ran a 9V battery through a 470 ohm resistor to clip leads (limiting current to no more than 20mA or so). I clipped a volt meter between the 9V negative and the resistor. Without anything inline, it naturally read 9 volts. Then I popped out one of the LED's and put it in parallel to the voltmeter. I flipped it around so it would light up, and then read the meter. The first one was blue and it read 3.0 volts -- that's the voltage drop of the LED. The others are as follows:
Blue: 3.0V
Green: 3.2V
Orange: 2.0V
Red: 5.2V *
Yellow: 2.0V
- Note that the red surprised me at 5 volts ... I was expecting more like 2 volts.
I've often wondered if it would be possible to have one DC power source, say a solar array with battery backups, and run all household lighting (using LEDs) from that.
If the LED's are different voltages, divide them up into strings that total to the same voltage and do the same thing. Like if you have blue, green, red and the voltages are 3.1, 3.0, and 2.0 volts, then wire them up blue-green-red-blue-green-red and get a (3.1+3+2)*2=16.2 V transformer. Something like that anyway.
