3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Cook Up an Edible Magnifying Glass
Hello, fellow mad scientists!  Are you sad that the state blew up your high-precision optics lab with attached glassworks when they stormed your volcano fortress after you released a plague of self-replicating Tribbles upon the House of Representatives when they refused to grant low-interest loans to budding mad scientists?  Are your blood sugar levels dipping dangerously below the recommended levels for unbalanced geniuses?  Tired of not being able to read all the fine print on the medication your court-appointed psychiatrist gave you?  (Anti-paranoia medication may cause paranoia?  Really?)
Fear not, for I have a solution to all three problems- and, even better, the solution is a a solution: a  solution of sugar and water!   We shall make our very own magnifying glass...out of hard candy!
How it works:
Light moves at different speeds through different materials.  When it changes materials, depending on the angle it hit that material, it changes direction- something called refraction.   A lens refracts light so that it makes things your looking at seem bigger or smaller, depending on the type of lens.
Here's an analogy:  Imagine it's a really hot day, and you are at the pool, and you take a jump off the high dive.  Air whistles past as you fall faster, faster- SMACK! Suddenly, you hit the water and slow waaaay down.  You swim for the bottom as fast as you can, but you can never swim as fast as you were falling.
Light works the same way.  When it is traveling through the air, lighting up your world, it just zips along.  And suddenly, when it hits a pane of glass, it slows down so much you'd think it was a kid doing a cannonball.
The angle that light hits glass is also important.  It's just like you if you dive off a diving board.  If you dive straight in, you go straight down.  However, if you dive at an angle, the surface of the water deflects you in a different direction.  Don't believe me?  Try belly-flopping.  You'll be certain that the water is trying to deflect you right out of the pool.  And we've deflected off the subject enough- let's get back to lenses.
So we're going to make a lens.  All you need is some transparent substance, like glass or plastic, and a mold for the lens.
We shall make a plano-convex lens , which is a fancy Latin name for  a lens with a flat bottom and a curved top.    And as for the transparent material, well, my  transparent material of choice is inexpensive, easily accessible, easily polished, lightweight, low-melting-point, non-toxic, biodegradable, edible, and delicious.
In other words: hard candy.
We'll cook up a batch of hard candy, pour it in the mold, polish it, and voila!  Instant magnifying glass.
Supplies:
Food supplies:
1 3/4 cups Sugar
1 cup Water
1/2 cup Corn syrup (optional)
1/4 tsp Cream of Tartar (optional)
flavoring (optional)
2 16oz boxes of Corn Starch
No-stick cooking spray
cooking supplies:
smallish saucepan
candy thermometer (somewhat optional)
1-inch deep cake pan  (or bowl, or something suitably deep)
candy-pouring crucible: either make one or use a glass measuring cup
other supplies
spherical object  ( I used a ladle)
A couple children (optional, for the polishing step)
An air-conditioned home without much moisture in the air or a nice, clear, NOT humid day.  (Ever wonder why hard candies get chewy over time?  They're hygroscopic, which means they absorb water like mad.  When candy absorbs water, it gets chewy and sticky, which is not something hard-candy manufacturers like, which is why they recommend making your candy on a nice, cool, clear day.)
I am indebted to the following instructables:
http://www.instructables.com/id/Sugar-Glass/
http://www.instructables.com/id/Corn-Starch-Candy-Molds/
Step 1Making the Mold
Making the Mold
I like to set up the mold before making the candy, because making hard candy and pouring requires quick work and you don't want to be distracted trying to make your mold while you've got molten candy on your hands.
Take your  one-inch deep pan and fill it full of corn starch.  My particular pan is an eight-inch diameter pan, and it took two 16-oz boxes to fill it.
Level it off a bit so that it's full, but not overflowing.
Take your round object- in my case, my two-inch-in-diameter ladle- and press it deep into the corn starch.  Like a meteor hitting the earth, you're going to displace a lot of starch, so it will sort of mound up over before leaving a big crater.  The bottom of the crater will probably be somewhat cracked or have imperfections.  No problem- simply spin your spherical object in the hole to smooth it out.  That's the advantage of making a round object mold- you don't run into big displacement problems like the instructable here .
And honestly, having a perfect mold does not matter in the slightest- from what I can tell, corn starch is not supposed to be used as a mold for things this big, because huge imperfections show up when you cast your candy if it's too large.  On the other hand, it works in just fine in this specific case, because we get rid of those huge imperfections in the polishing stage later.
I was able to make four molds with my pan.  This recipe has enough candy for six lenses, so you'll either want to get more corn starch or just do something else with the excess candy.
You'll probably have some candy left over at then end: I certainly did: enough for about two more lenses, although I didn't have enough starch to make six molds. Spray a cookie sheet with no-stick spray, and pour the excess onto the sheet, and let it harden. The cooking spray will keep your candy  from sticking to the sheet like glue.
I also made an additional  lens by spraying the inside of my ladle with no-stick spray and filling it with extra candy.
7 comments
Aug 8, 2011. 3:29 AMsunshiine says:
I love this! Thanks for sharing!
Aug 3, 2011. 2:14 PMjessyratfink says:
These look like a lot of fun! I can imagine having a silly Sherlock Holmes party with these.
Aug 3, 2011. 1:51 PMjanw says:
Looks like great fun! Nice instructable too. It would be nice if you could give it the typical detective spyglass look by giving it the typical frame.
Aug 3, 2011. 3:17 PMrimar2000 says:
No, Tararoys, you don't need a biconvex lens to do one of these magnifying glasses. Good Instructable!
Do you know if there is a way to clearer a bit more the sugar?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:Tararoys
