3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Cook/Peel an egg easier and faster
There are ways to cook and peel eggs faster.
Step 1Step 1
Step 1
U need the following
-Egg
-Salt
-Water
9 comments
Apr 5, 2011. 11:58 AMrleibman says:
I find that boiling your eggs gets you rubbery whites and dry yolks (yeech). Sure, easy to peel, but not as good. Ease of peeling is in inverse proportion with good eggs, unfortunately.
I like my eggs "sous vide" (I know, not vacuum sealed, but using the general technique of precise low temperature control), cooked at precisely 65 Celsius for an hour.
But if you want pretty good eggs:
Put the eggs with plenty of water (at least an inch over the top). Heat the water until it boils, the moment it does so (or actually a bit before if you can manage it) turn off the heat and leave the eggs for another 10 minutes.
Store your eggs sideways so that the yolk stays in the middle. If you want to ensure the yolk is in the middle rotate them as they cook.
Older eggs (not old enough that they expire though) are a bit easier to peel.
Apr 6, 2011. 7:03 AMrleibman says:
Proteins in eggs denature (change form) at different temperatures, at 100 Celsius (boiling) you end up with rubbery whites and dry yolks (and can get some sulfurous odor and green/gray yolks!), so you don't want them at that temperature very long. Cooking is a function of time, but much more of temperature. Take a look at the egg chart in this document: http://www.cookingissues.com/wp-content/uploads/2010/02/eggchart2.jpg
Apr 5, 2011. 1:07 PMrleibman says:
Please do :)
Apr 5, 2011. 12:36 PMQuercus austrina says:
Actually, the salt raises the boiling point of the water, cooking the egg faster due to higher heat. Additionally, the smaller volume of water means that more heat transfer is being done by the holding container (pot), boiling the water more quickly. Overall, these are the largest factors in cooking the egg faster.
As for the shell being harder, less overall time in the water (while waiting to come to a boil) means less effect on the shell, hence it is "harder".
Qa
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Blastboy
