3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Cookie Tray Laptop Stand
Make a passive cooling laptop stand from a cookie tray. This idea was inspired by KoolSink laptop stands and their ridiculously expensive price. The result is not as polished but I bet it works just as well and costs a whole lot less.
Step 1What you need
What you need
1 x Cookie Tray
2 x Rubber bumps
2 x Stick mount cup hooks
Cookie Tray:
I got mine (Wilton Aluminum Cookie Sheet 12 1/2 x 16 1/2 x 1/4 Inches Deep) from Amazon for around $16. I chose an Aluminum one for better heat properties. I also chose a larger one as I might upgrade my laptop to a 15" later on.
Note: The cookie tray I got was thinner than I hoped so it would curve when the weight of the laptop is on it. But fear not, I have a solution, read on!
Rubber bumps:
I over paid for my 3M Rubber bumps from Amazon. Any kind will do, Walmart has them for cheap.
Stick mount cup hooks:
I just needed something to lift the back of the laptop stand a little. There are plenty of things that will do this. I happen to have some of these hooks from a previous project, they came from Walmart.
10 comments
Nov 16, 2008. 6:59 AMCann0n says:
i'd cut holes in it to induce ventilation
Dec 27, 2008. 9:48 AMbengerszewski says:
that just reduces the area of heatsink material (Aluminum).
Jan 5, 2009. 8:50 PMalexanderm says:
Having airflow increases the effectiveness of said heatsink area. Besides, some laptops pull air in through the bottom, and vent it out the back. In these cases, adding vent holes would increase cooling efficiency.
May 2, 2010. 12:22 PMChowmix12 says:
The Idea is debatable.. but I think heat-sinks are  meant to have more surface area, not just area.. so holes would take out more SA, but then again, more ventilation..
Jun 8, 2009. 8:36 PMtigerstickfigure says:
I just used an insulated cookie sheet (it has a hollow sealed chamber inside)! It really spreads the heat out, and it has a built-in lip (no bending necessary).
Jul 30, 2008. 12:30 AMll.13 says:
Instead of using the hooks to raise the back, how about bending the tray? -nice i'Ble
Apr 15, 2009. 5:16 PMtemp says:
do you have a vice? Cause if you do you can take two pieces of long angle aluminum or iron etc. and put the tray between them Then bend it over the edge of the angle iron.
Nov 13, 2008. 10:59 PMweazul says:
normally I'm constructive only but I couldn't resist
Mar 13, 2009. 1:48 AMlukkbox says:
loooooooooooooooooool it's about 9am here so it took a second for me to get that one loooooooooooooooooooooooool!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:elcheapo
