Cooking with an Ancient Himalayan Salt Block
 by lmnopeas
Featured
This 'ible will show you how to use a 600+ million year old Himalayan Salt Block as a cooking device.
Originally harvested from the ancient mountains of Pakistan, Himalayan pink salt is considered to be some of the purest and cleanest salt in the world. These salt blocks can be heated or chilled to almost any temperature. I originally used mine as a serving platter for cheese, homemade sushi, oysters and even desserts. You can see an example of where I used my salt block as a serving platter here.
The great thing about these salt blocks is that they are so versatile and available in a wide array of sizes and shapes. I recommend buying two blocks. One for serving, one for cooking. The heating process will cause the salt block to change color and cracks will occur naturally. Also, the salt block will absorb the juices and cause color changes. You should be able to get a few dozen uses out of your salt block once you have cooked with it, but there are cases where salt block have cracked with only a few uses. If this happens, you can still use the salt for a variety of other uses.
When cooking with your salt block, it is not necessary to add seasonings or salt to the food before you cook it. In fact, besides being totally cool, the whole point of cooking with it, is to add a natural salty flavor to the food. The salt block will maintain it's temperature for at least 20 minutes when heated properly. You can actually cook food table side after you heat it, but you will need to protect your hands and table from the salt block. Use a silicone oven mitt and trivet.
This was a really fun cooking experience and I can't wait to try it again.
Step 1: Ingredients & Tools
For this Instructable, you will need the following
Shrimp 6-7 Tail On
1 Egg
dreadengineer says: May 6, 2012. 11:59 AM
A cool idea. But since this is the Internet, I feel compelled to point out a scientific error - this is very far from the purest salt in the world; pure NaCl is a white crystalline powder with no pink color. Table salt is much more pure than a natural salt block. Purity is not really relevant to taste though, and it's unlikely that any of the impurities are harmful, so the idea is still cool.
lmnopeas (author) in reply to dreadengineerMay 6, 2012. 2:21 PM
Thank you, and, yes, you are right about the NaCl being the purest form of salt.
I was using the word "pure" with a bit of literary license and artistic flourish. I didn't mean it in the "industrial, chemical" sense. I meant it in the "closest to its Earthly origins sense." Yes, NaCl is more chemically pure than Himalayan salt in the same way that distilled water is more "pure" than, say, Evian.
What makes Himalayan salt (and other salts derived from natural sources) is, in fact, its "chemical impurity" -- all of the trace minerals give it immense character -- and it is true that it is "pure" in the sense that it has been untouched by human hands and industrial/chemical processes for millions of years.
Broom in reply to lmnopeasMay 9, 2012. 2:31 PM
... until being cut into slabs, packaged, shipped, and displayed in stores.
Broom says: May 9, 2012. 2:30 PM
Yeah, let's give up on definitions! They just get in the way!
Eggs sift silly watermelon bushes. Torpedo glandulary kumquat eschewed. Level onto gravlax.
(But if you insist on using boring old "definitions", what I meant to say was, "Table salt isn't adulterated much, either. And the pink hue has nothing to do with the uneven crystallin structure. And pink salt is not pure; that's just marketing BS.")
reptedjess says: May 6, 2012. 12:46 PM
hmmmmm.... I wonder, are there certain food that are not good for cooking on a salt block? I would imagine, you wouldn't want anything that is going to produce a lot of grease or oil like a steak or burgers. I imagine it would just make a huge mess
lmnopeas (author) in reply to reptedjessMay 6, 2012. 2:25 PM
Since I posted this 'ible I've cooked everything from hamburgers to rack of lamb on my salt block. With thicker pieces of meat, I finish them off in the oven.
Any food that puts off a lot of moisture or has a lot of fat that renders may be problematic (a lot of moisture could cause the salt to dissolve and there are not sides on the salt block to contain any runoff like pan might have).
In general, it's a pretty versatile cooking surface and has a great fun factor when guests come over.
billbillt says: May 6, 2012. 9:39 AM
Wonder info here about this..Great!!...
hmcnally says: May 4, 2012. 8:29 PM
Broken link to saltworks.us.  It should be:
http://www.saltworks.us/himalayan-plates-bricks-blocks.html
lmnopeas (author) in reply to hmcnallyMay 4, 2012. 9:57 PM
Thanks for pointing that out. It should be working now.
canida says: May 4, 2012. 8:11 PM
Neat-o!
I've played with a friend's salt block (we cold-cured some thin-sliced sashimi) but never gotten to cook on it. I can't wait to get one and try it - you make it sound like fun. :)
lmnopeas (author) in reply to canidaMay 4, 2012. 9:57 PM
Thanks! I've had mine for a couple years and this was my first time cooking on it. It was totally fun:)
angelabchua says: May 4, 2012. 11:46 AM
Very cool! I've only recently heard of pink himalayan salt, and to see this cooking block? VERY COOL
lmnopeas (author) in reply to angelabchuaMay 4, 2012. 9:54 PM
Thanks! Keep an eye out. I've seen them in a lot of grocery stores.
ladymargaretrose says: May 4, 2012. 6:36 PM
I want a salt block....WAHHHHHHHHH!!!!! Note to self: Next thing to buy with extra money!!!
desertsniper says: May 4, 2012. 6:19 PM
intresting read thanks! i will keep my eye out for one of these!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
